VBA3638
www.VBsemi.com
Dual N-Channel 60 V (D-S) 175 °C MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
• TrenchFET® power MOSFET
• 100 % Rg and UIS tested
60
RDS(on) (Ω) at VGS = 10 V
0.040
RDS(on) (Ω) at VGS = 4.5 V
0.055
ID (A) per leg
7
Configuration
Dual
SO-8 Dual
D1
8
D1
7
D2
6
D2
5
D1
G1
Top View
2
1 G1
S1
D2
G2
4
3 G2
S2
S1
S2
N-Channel MOSFET
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
Drain-Source Voltage
VDS
60
Gate-Source Voltage
VGS
± 20
Continuous Drain Current
TC = 25 °C
TC = 125 °C
Continuous Source Current (Diode Conduction) a
Pulsed Drain Current b
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
Maximum Power Dissipation b
L = 0.1 mH
TC = 25 °C
TC = 125 °C
Operating Junction and Storage Temperature Range
ID
V
7
4
IS
3.6
IDM
28
IAS
18
EAS
16.2
PD
UNIT
4
1.3
A
mJ
W
TJ, Tstg
-55 to +175
°C
SYMBOL
LIMIT
UNIT
RthJA
110
RthJF
34
THERMAL RESISTANCE RATINGS
PARAMETER
Junction-to-Ambient
Junction-to-Foot (Drain)
PCB Mount c
°C/W
Notes
a. Package limited.
b. Pulse test; pulse width ≤ 300 μs, duty cycle ≤ 2 %.
c. When mounted on 1" square PCB (FR4 material).
1
VBA3638
www.VBsemi.com
SPECIFICATIONS (TC = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
Static
Drain-Source Breakdown Voltage
Gate-Source Threshold Voltage
Gate-Source Leakage
Zero Gate Voltage Drain Current
On-State Drain Current a
Drain-Source On-State Resistance a
Forward Transconductance f
VDS
VGS = 0 V, ID = 250 μA
60
VGS(th)
VDS = VGS, ID = 250 μA
1.5
2.0
2.5
VDS = 0 V, VGS = ± 20 V
IGSS
IDSS
ID(on)
RDS(on)
gfs
± 100
VGS = 0 V
VDS = 60 V
1
VGS = 0 V
VDS = 60 V, TJ = 125 °C
50
VGS = 0 V
VDS = 60 V, TJ = 175 °C
150
VGS = 10 V
VDS ≥ 5 V
VGS = 10 V
ID = 4.5 A-
0.028
0.040
VGS = 10 V
ID = 4.5 A, TJ = 125 °C
0.066
VGS = 10 V
ID = 4.5 A, TJ = 175 °C
0.081
VGS = 4.5 V
ID = 4 A-
VDS = 15 V, ID = 4.5 A
0.030
0.055
15
600
750
110
140
V
nA
μA
A
Ω
S
Dynamic b
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
50
62
Total Gate Charge c
Qg
11.7
18
Gate-Source Charge c
Qgs
1.8
2.7
Gate-Drain Charge
c
Gate Resistance
Turn-On Delay
Time c
Rise Time c
Turn-Off Delay Time c
Fall Time c
VGS = 0 V
VDS = 25 V, f = 1 MHz
VGS = 10 V
VDS = 30 V, ID = 5.3 A
Qgd
pF
nC
2.8
4.2
f = 1 MHz
1.3
6
td(on)
7
11
tr
VDD = 30 V, RL = 6.8 Ω
ID ≅ 4.4 A, VGEN = 10 V, Rg = 1 Ω
3.3
5
22.4
33.5
2.1
3.2
28
A
0.75
1.1
V
Rg
td(off)
tf
Ω
ns
Source-Drain Diode Ratings and Characteristics b
Pulsed Current a
ISM
Forward Voltage
VSD
Notes
a. Pulse test; pulse width ≤ 300 μs, duty cycle ≤ 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
2
IF = 2 A, VGS = 0 V
VBA3638
www.VBsemi.com
TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted)
30
30
V GS = 10 V thru 5 V
V GS = 4 V
24
ID - Drain Current (A)
24
18
12
V GS = 3 V
6
18
12
T C = 25 °C
6
T C = 125 °C
T C = - 55 °C
4
6
8
VDS - Drain-to-Source Voltage (V)
10
2
3
4
VGS - Gate-to-Source Voltage (V)
Output Characteristics
5
Transfer Characteristics
0.10
25
RDS(on) - On-Resistance (Ω)
g fs - Transconductance (S)
T C = -55 °C
T C = 25 °C
15
10
T C = 125 °C
0.08
0.06
V GS = 4.5 V
0.04
V GS = 10 V
0.02
5
6
9
12
Transconductance
6
12
18
24
30
On-Resistance vs. Drain Current
1000
10
ID = 5.3 A
C - Capacitance (pF)
800
Ciss
600
400
Coss
200
Crss
V DS = 30 V
6
4
2
40
50
Capacitance
60
4
6
8
Qg - Total Gate Charge (nC)
10
12
Gate Charge
3
VBA3638
www.VBsemi.com
2.0
75
V GS = 10 V
RDS(on) - On-Resistance (Normalized)
ID = 5.3 A
1.7
V GS = 4.5 V
1.4
1.1
0.8
0.5
- 50
- 25
50
75 100 125
TJ - Junction Temperature (°C)
150
ID = 1 mA
72
69
66
63
60
- 50
175
50
75 100 125
150
175
Drain Source Breakdown vs. Junction Temperature
100
0.25
10
0.20
IS - Source Current (A)
On-Resistance vs. Junction Temperature
- 25
T J = 150 °C
1
T J = 25 °C
0.1
0.15
0.10
T J = 150 °C
0.01
0.05
0.001
T J = 25 °C
0.4
0.6
0.8
1.0
1.2
4
8
Source Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
0.6
VGS(th) Variance (V)
0.3
ID = 5 mA
-0.6
ID = 250 μA
-0.9
-1.2
-50
-25
50
75 100
TJ - Temperature (°C)
Threshold Voltage
4
6
VSD - Source-to-Drain Voltage (V)
125
150
175
10
VBA3638
www.VBsemi.com
THERMAL RATINGS (TA = 25 °C, unless otherwise noted)
IDM Limited
Limited by RDS(on)*
10
100 µs
1
1 ms
10 ms
100 ms
1s
10 s, DC
0.1
TC = 25 °C
Single Pulse
0.01
0.01
BVDSS Limited
0.1
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
Notes:
0.1
PDM
0.1
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = R thJA = 110 °C/W
0.02
3. T JM - TA = PDMZthJA(t)
Single Pulse
0.01
10- 4
10- 3
4. Surface Mounted
10- 2
10- 1
1
10
100
600
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
5
VBA3638
www.VBsemi.com
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10- 4
10- 3
10- 2
10- 1
Normalized Thermal Transient Impedance, Junction-to-Foot
6
1
10
VBA3638
www.VBsemi.com
SOIC (NARROW): 8-LEAD
JEDEC Part Number: MS-012
8
6
7
5
E
1
3
2
H
4
S
h x 45
D
C
0.25 mm (Gage Plane)
A
B
e
All Leads
q
A1
L
0.004"
MILLIMETERS
DIM
Min
INCHES
Max
Min
Max
A
1.35
1.75
0.053
0.069
A1
0.10
0.20
0.004
0.008
B
0.35
0.51
0.014
0.020
C
0.19
0.25
0.0075
0.010
D
4.80
5.00
0.189
0.196
E
3.80
4.00
0.150
e
0.101 mm
1.27 BSC
0.157
0.050 BSC
H
5.80
6.20
0.228
0.244
h
0.25
0.50
0.010
0.020
L
0.50
0.93
0.020
0.037
q
0°
8°
0°
8°
S
0.44
0.64
0.018
0.026
ECN: C-06527-Rev. I, 11-Sep-06
DWG: 5498
7
VBA3638
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR SO-8
0.172
(4.369)
0.028
0.022
0.050
(0.559)
(1.270)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
8
0.152
(3.861)
0.047
(1.194)
0.246
(6.248)
(0.711)
VBA3638
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
