VBE1102N
www.VBsemi.com
N-Channel 100-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
RDS(on) ()
100
0.0185 at VGS = 10 V
ID
(A)a
60
Qg (Typ.)
• TrenchFET® Power MOSFET
• 100 % Rg and UIS Tested
38 nC
APPLICATIONS
• Primary Side Switch
• Isolated DC/DC Converter
TO-252
D
G
G
D
S
S
N-Channel MOSFET
Top View
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
100
Gate-Source Voltage
VGS
± 20
TC = 100 °C
TA = 25 °C
45
ID
9.2b
6.8b
TA = 100 °C
IDM
Pulsed Drain Current
Continuous Source-Drain Diode Current
Single Pulse Avalanche Current
Avalanche Energy
TC = 25 °C
TA = 25 °C
L = 0.1 mH
Maximum Power Dissipation
TA = 25 °C
60a
IS
2b
IAS
45
EAS
101
mJ
136.4
68.2
PD
W
3b
1.5b
TA = 100 °C
TJ, Tstg
Operating Junction and Storage Temperature Range
A
140
TC = 25 °C
TC = 100 °C
V
60a
TC = 25 °C
Continuous Drain Current (TJ = 150 °C)
Unit
°C
- 55 to 175
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambient
Symbol
b
Maximum Junction-to-Case
Steady State
Typical
Maximum
RthJA
40
50
RthJC
0.85
1.1
Unit
°C/W
Notes:
a. Package limited.
b. Surface mounted on 1" x 1" FR4 board.
1
VBE1102N
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
100
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
VDS/TJ
VGS(th) Temperature Coefficient
VGS(th)/TJ
Gate-Source Threshold Voltage
ID = 250 µA
VGS(th)
VDS = VGS, ID = 250 µA
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
Drain-Source On-State Resistancea
mV/°C
- 12.5
2.5
5
V
± 100
nA
VDS = 100 V, VGS = 0 V
1
VDS = 100 V, VGS = 0 V, TJ = 125 °C
50
ID(on)
VDS 5 V, VGS = 10 V
RDS(on)
VGS = 10 V, ID = 15 A
gfs
VDS = 15 V, ID = 15 A
Forward Transconductancea
V
110
50
µA
A
0.0185
33
S
Dynamicb
Input Capacitance
Ciss
2400
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
80
Total Gate Charge
Qg
38
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Turn-On Delay Time
VDS = 50 V, VGS = 10 V, ID = 50 A
Rg
f = 1 MHz
VDD = 50 V, RL = 1
ID 50 A, VGEN = 10 V, Rg = 1
tr
td(off)
Fall Time
230
pF
70
14
nC
12
td(on)
Rise Time
Turn-Off Delay Time
VDS = 50 V, VGS = 0 V, f = 1 MHz
tf
1.6
2.5
12
35
8
15
ns
Drain-Source Body Diode Characteristics
IS
Pulse Diode Forward Currenta
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
TC = 25 °C
50
100
IS = 15 A
IF = 50 A, dI/dt = 100 A/µs, TJ = 25 °C
A
0.85
1.5
V
80
120
ns
160
240
nC
57
23
ns
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
VBE1102N
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise note)
100
2.0
VGS = 10 V thru 8 V
1.6
I D - Drain Current (A)
80
VGS = 7 V
60
40
0.8
TC = 25 °C
0.4
VGS = 6 V
TC = 125 °C
TC = - 55 °C
2
3
4
5
4
6
8
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
10
0.036
75
45
R DS(on) - On-Resistance (Ω)
g fs - Transconductance (S)
TC = - 55 °C
60
TC = 25 °C
TC = 125 °C
30
15
0.027
VGS = 10 V
0.018
0.009
0.000
40
60
80
ID - Drain Current (A)
Transconductance
On-Resistance vs. Drain Current
100
3500
0.10
2800
C - Capacitance (pF)
ID = 15 A
0.08
0.06
0.04
TA = 150 °C
Ciss
2100
1400
700
0.02
Coss
TA = 25 °C
4
5
6
7
8
9
10
Crss
60
80
On-Resistance vs. Gate-to-Source Voltage
Capacitance
100
3
VBE1102N
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
ID = 15 A
VDS = 50 V
15
(Normalized)
ID = 20 A
VDS = 80 V
10
5
60
80
1.0
- 25
50
75
100
125
150
Qg - Total Gate Charge (nC)
TJ - Junction Temperature (°C)
Gate Charge
On-Resistance vs. Junction Temperature
175
0.7
TJ = 150 °C
0.2
VGS(th) Variance (V)
10
I S - Source Current (A)
VGS = 10 V
1.5
0.5
- 50
100
100
TJ = 25 °C
1
0.1
0.01
0.001
0.0
2.0
- 0.3
ID = 5 mA
- 0.8
- 1.3
- 1.8
0.2
0.4
0.6
0.8
1.0
- 2.3
- 50
1.2
ID = 250 µA
- 25
VSD - Source-to-Drain Voltage (V)
25
50
75
100
125
150
175
TJ - Temperature (°C)
Source-Drain Diode Forward Voltage
Threshold Voltage
600
300
500
240
Power (W)
Power (W)
400
180
120
200
TA = 25 °C
60
TC = 25 °C
100
0.1
1
10
100
1000
Time (s)
Single Pulse Power, Junction-to-Ambient
4
300
0.001
0.01
0.1
1
Time (s)
Single Pulse Power, Junction-to-Case
10
VBE1102N
www.VBsemi.com
1000
1000
10
1 ms
1
10 ms
100 ms
0.1
1s
10 s
100 s, DC
TA = 25 °C
Single Pulse
0.01
0.1
100
10 µs, 100 µs
Limited
by R DS(on)*
100
1.0
10
100
Limited
by R DS(on)*
1 ms
10 ms
100 ms, DC
1
TC = 25 °C
Single Pulse
0.01
0.1
1.0
10
100
1000
* VGS > minimum VGS at which R DS(on) is specified
Safe Operating Area, Junction-to-Case
Safe Operating Area, Junction-to-Ambient
60
10
50
8
100 µs
10
0.1
1000
10 µs
6
4
2
Package Limited
40
30
50
75
100
125
150
175
TA - Ambient Temperature (°C)
Current Derating**, Junction-to-Ambient
50
75
100
125
150
175
TC - Case Temperature (°C)
Current Derating**, Junction-to-Case
** The power dissipation PD is based on TJ(max.) = 175 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
5
VBE1102N
www.VBsemi.com
4.0
180
3.5
160
140
120
2.5
Power (W)
Power (W)
3.0
2.0
1.5
100
80
60
1.0
40
0.5
50
75
100
125
150
Power Derating**, Junction-to-Ambient
175
50
75
100
125
150
175
Power Derating**, Junction-to-Case
** The power dissipation PD is based on TJ(max) = 175 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
limit.
6
VBE1102N
www.VBsemi.com
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
Notes:
0.1
PDM
t1
0.05
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 50 °C/W
0.02
3. TJM - TA = PDMZthJA(t)
Single Pulse
0.01
10 -4
10 -3
10 -2
4. Surface Mounted
10 -1
1
100
10
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
Normalized Thermal Transient Impedance, Junction-to-Case
7
VBE1102N
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
