VBFB1102M
www.VBsemi.com
N-Channel 100-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
RDS(on) ()
Qg (Max.) (nC)
Qgs (nC)
Qgd (nC)
Configuration
100
VGS = 10 V
0.20
16
4.4
7.7
Single
• Halogen-free According to IEC 61249-2-21
Definition
• Available in Tape and Reel
• Dynamic dV/dt Rating
• Repetitive Avalanche Rated
• 175 °C Operating Temperature
• Fast Switching
• Ease of Paralleling
Available
Available
TO-251
D
G
Drain Connected to
Drain-Tab
G
D
S
N-Channel MOSFET
S
Top View
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current
Currenta
SYMBOL
VDS
VGS
VGS at 10 V
TC = 25 °C
TC = 100 °C
ID
Pulsed Drain
IDM
Linear Derating Factor
Linear Derating Factor (PCB Mount)
EAS
Single Pulse Avalanche Energyb
Avalanche Currenta
IAR
Repetitive Avalanche Energya
EAR
Maximum Power Dissipation
TC = 25 °C
PD
Maximum Power Dissipation (PCB Mount)
TA = 25 °C
Peak Diode Recovery dV/dtc
dV/dt
Operating Junction and Storage Temperature Range
TJ, Tstg
Soldering Recommendations (Peak Temperature)
For 10 s
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11).
b. VDD = 25 V, starting TJ = 25 °C, L = 3.5 mH, Rg = 25 , IAS = 9.2 A (see fig. 12).
c. ISD 9.2 A, dI/dt 110 A/μs, VDD VDS, TJ 175 °C.
LIMIT
100
± 20
12
7.5
37
0.40
0.025
200
9.2
6.0
60
3.7
5.5
- 55 to + 175
300d
UNIT
V
A
W/°C
mJ
A
mJ
W
V/ns
°C
1
VBFB1102M
www.VBsemi.com
THERMAL RESISTANCE RATINGS
PARAMETER
SYMBOL
TYP.
MAX.
Maximum Junction-to-Ambient
RthJA
62
(PCB Mount)a
RthJA
40
Maximum Junction-to-Case (Drain)
RthJC
2.5
UNIT
°C/W
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
VDS
VGS = 0, ID = 250 μA
100
V
VDS/TJ
Reference to 25 °C, ID = 1 mA
0.13
V/°C
VGS(th)
VDS = VGS, ID = 250 μA
1.0
3.0
V
nA
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
Gate-Source Threshold Voltage
Gate-Source Leakage
Zero Gate Voltage Drain Current
Drain-Source On-State Resistance
Forward Transconductance
IGSS
IDSS
RDS(on)
gfs
VGS = ± 20 V
± 100
VDS = 100 V, VGS = 0 V
25
VDS = 80 V, VGS = 0 V, TJ = 150 °C
250
0.20
2.7
S
360
ID = 5.5 Ab
VGS = 10 V
VDS = 50 V, ID = 5.5
Ab
μA
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
VGS = 0 V,
VDS = 25 V,
f = 1.0 MHz, see fig. 5
VGS = 10 V
ID = 9.2 A, VDS = 80 V,
see fig. 6 and 13b
150
34
16
4.4
Gate-Drain Charge
Qgd
7.7
Turn-On Delay Time
td(on)
8.8
Rise Time
Turn-Off Delay Time
Fall Time
Internal Drain Inductance
Internal Source Inductance
tr
td(off)
VDD = 50 V, ID = 9.2 A,
Rg = 18 , RD = 5.2 , see fig. 10b
tf
LD
LS
Between lead,
6 mm (0.25") from
package and center of
die contact
30
19
7.5
9.2
37
pF
nC
ns
D
nH
G
S
Drain-Source Body Diode Characteristics
Continuous Source-Drain Diode Current
Pulsed Diode Forward Currenta
Body Diode Voltage
IS
ISM
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Forward Turn-On Time
ton
MOSFET symbol
showing the
integral reverse
p - n junction diode
A
G
TJ = 25 °C, IS = 9.2 A, VGS = 0
S
Vb
TJ = 25 °C, IF = 9.2 A, dI/dt = 100 A/μsb
1.8
V
110
260
ns
0.53
1.3
μC
Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
b. Pulse width 300 μs; duty cycle 2 %.
2
D
VBFB1102M
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
VGS
15 V
10 V
8.0 V
7.0 V
6.0 V
5.5 V
5.0 V
Bottom 4.5 V
Top
25 °C
101
4.5 V
100
ID, Drain Current (A)
101
175 °C
100
20 µs Pulse Width
TC = 25 °C
10-1
100
101
4
VDS, Drain-to-Source Voltage (V)
91018_01
20 µs Pulse Width
VDS = 50 V
91018_03
101
4.5 V
100
20 µs Pulse Width
TC = 175 °C
10-1
100
101
Fig. 2 - Typical Output Characteristics, TC = 175 °C
6
7
8
9
10
Fig. 3 - Typical Transfer Characteristics
RDS(on), Drain-to-Source On Resistance
(Normalized)
Fig. 1 - Typical Output Characteristics, TC = 25 °C
VGS
Top
15 V
10 V
8.0 V
7.0 V
6.0 V
5.5 V
5.0 V
Bottom 4.5 V
5
VGS, Gate-to-Source Voltage (V)
3.0
2.5
ID = 9.2 A
VGS = 10 V
2.0
1.5
1.0
0.5
0.0
- 60 - 40 - 20 0
20 40 60 80 100 120 140 160 180
TJ, Junction Temperature (°C)
Fig. 4 - Normalized On-Resistance vs. Temperature
3
VBFB1102M
www.VBsemi.com
VGS = 0 V, f = 1 MHz
Ciss = Cgs + Cgd, Cds Shorted
Crss = Cgd
Coss = Cds + Cgd
Capacitance (pF)
600
450
Ciss
300
Coss
150
Crss
101
175 °C
ISD, Reverse Drain Current (A)
750
25 °C
100
91018_05
VDS = 20 V
8
4
8
12
16
5
1.2
10 µs
2
100 µs
10
5
1 ms
2
10 ms
1
QG, Total Gate Charge (nC)
TC = 25 °C
TJ = 175 °C
Single Pulse
2
0.1
0.1
Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage
4
1.1
102
5
For test circuit
see figure 13
4
1.0
2
VDS = 80 V
VDS = 50 V
Operation in this area limited
by RDS(on)
5
91018_06
0.8
VSD, Source-to-Drain Voltage (V)
103
16
0.7
Fig. 7 - Typical Source-Drain Diode Forward Voltage
ID = 9.2 A
12
0.6
91018_07
Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage
VGS = 0 V
10-1
0.5
101
91018_08
2
5
1
2
5
10
2
5
102
2
5
Fig. 8 - Maximum Safe Operating Area
103
VBFB1102M
www.VBsemi.com
RD
VDS
VGS
10
8
D.U.T.
Rg
- VDD
10 V
Pulse width ≤ 1 µs
Duty factor ≤ 0.1 %
6
Fig. 10a - Switching Time Test Circuit
4
VDS
2
90 %
50
75
100
125
150
175
10 %
VGS
TC, Case Temperature (°C)
91018_09
td(on)
Fig. 9 - Maximum Drain Current vs. Case Temperature
td(off) tf
tr
Fig. 10b - Switching Time Waveforms
Thermal Response (ZthJC)
10
1
0 - 0.5
0.2
0.1
t1
0.02
0.01
10-2
10-5
91018_11
PDM
0.1
0.05
Single Pulse
(Thermal Response)
10-4
10-3
t2
Notes:
1. Duty Factor, D = t1/t2
2. Peak Tj = PDM x ZthJC + TC
10-2
0.1
1
10
t1, Rectangular Pulse Duration (s)
Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case
5
VBFB1102M
www.VBsemi.com
L
Vary tp to obtain
required IAS
VDS
VDS
tp
D.U.T.
Rg
I AS
VDD
V DD
VDS
10 V
0.01 Ω
tp
IAS
Fig. 12a - Unclamped Inductive Test Circuit
Fig. 12b - Unclamped Inductive Waveforms
EAS, Single Pulse Energy (mJ)
600
ID
3.8 A
6.5 A
Bottom 9.2 A
Top
500
400
300
200
100
VDD = 25 V
91018_12c
50
75
100
125
150
175
Starting TJ, Junction Temperature (°C)
Fig. 12c - Maximum Avalanche Energy vs. Drain Current
Current regulator
Same type as D.U.T.
50 kΩ
QG
10 V
12 V
0.2 µF
0.3 µF
QGS
QGD
D.U.T.
VG
VDS
VGS
3 mA
Charge
IG
ID
Current sampling resistors
Fig. 13a - Basic Gate Charge Waveform
6
Fig. 13b - Gate Charge Test Circuit
VBFB1102M
www.VBsemi.com
Peak Diode Recovery dV/dt Test Circuit
D.U.T.
Circuit layout considerations
• Low stray inductance
• Ground plane
• Low leakage inductance
current transformer
Rg
dV/dt controlled by Rg
Driver same type as D.U.T.
ISD controlled by duty factor “D”
D.U.T. - device under test
VDD
Driver gate drive
P.W.
Period
D=
P.W.
Period
VGS = 10 Va
D.U.T. lSD waveform
Reverse
recovery
current
Body diode forward
current
dI/dt
D.U.T. VDS waveform
Diode recovery
dV/dt
Re-applied
voltage
Inductor current
VDD
Body diode forward drop
Ripple ≤ 5 %
ISD
Note
a. VGS = 5 V for logic level devices
Fig. 14 - For N-Channel
7
VBFB1102M
www.VBsemi.com
TOĆ251AA
E
A
L2
b2
Dim
A
A1
b
b1
b2
c
c1
D
E
e
L
L1
L2
L3
D
L3
L1
b1
L
b
e
c
A1
Note: Dimension L3 is for reference only.
8
MILLIMETERS
c1
INCHES
Min
Max
Min
Max
2.21
2.38
0.087
0.094
0.89
1.14
0.035
0.045
0.71
0.89
0.028
0.035
0.76
1.14
0.030
0.045
5.23
5.43
0.206
0.214
0.46
0.58
0.018
0.023
0.46
0.58
0.018
0.023
5.97
6.22
0.235
0.245
6.48
6.73
0.255
0.265
2.28 BSC
0.090 BSC
3.89
9.53
0.153
0.375
1.91
2.28
0.075
0.090
0.89
1.27
0.035
0.050
1.15
1.52
0.045
0.060
VBFB1102M
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
