VBM1104N
www.VBsemi.com
N-Channel 100-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
V(BR)DSS (V)
100
rDS(on) (Ω)
ID (A)
0.032 at VGS = 10 V
45
0.035 at VGS = 4.5 V
40
• TrenchFET® Power MOSFETS
• 175 °C Junction Temperature
• Low Thermal Resistance Package
Available
RoHS*
COMPLIANT
D
TO-220AB
G
G D S
S
Top View
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
100
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 175 °C)
TC = 25 °C
TC = 125 °C
Pulsed Drain Current
Avalanche Current
Repetitive Avalanche Energya
Maximum Power Dissipationa
L = 0.1 mH
TC = 25 °C
TA = 25 °Cc
Operating Junction and Storage Temperature Range
ID
Unit
V
45
30
IDM
135
IAR
35
EAR
61
A
mJ
b
PD
127
3.75
W
TJ, Tstg
- 55 to 175
°C
Symbol
Limit
Unit
RthJA
40
RthJC
1.4
THERMAL RESISTANCE RATINGS
Parameter
Junction-to-Ambient
(PCB Mount)c
Junction-to-Case (Drain)
°C/W
Notes:
a. Duty cycle ≤ 1 %.
b. See SOA curve for voltage derating.
c. When Mounted on 1" square PCB (FR-4 material).
* Pb containing terminations are not RoHS compliant, exemptions may apply.
1
VBM1104N
www.VBsemi.com
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
V(BR)DSS
VSS = 0 V, ID = 250 µA
100
VGS(th)
VDS = VGS, ID = 250 µA
1
IGSS
VDS = 0 V, VGS = ± 20 V
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
Gate-Threshold Voltage
Gate-Body Leakage
Zero Gate Voltage Drain Current
On-State Drain Currenta
IDSS
± 100
VDS = 100 ,VVGS = 0 V
1
VDS = 80 V, VGS = 0 V, TJ = 125 °C
50
VDS = 80 V, VGS = 0 V, TJ = 175 °C
250
VDS ≥ 5 V, VGS = 10 V
ID(on)
Drain-Source On-State Resistancea
rDS(on)
75
0.032
VGS = 4.5 V, ID = 3 A
0.035
VGS = 10 V, ID = 5 A, TJ = 125 °C
Forward Transconductance
gfs
VDS = 15 V, ID = 15 A
V
nA
µA
A
Ω
0.050
VGS = 10 V, ID = 3 A, TJ = 175 °C
a
3
0.065
10
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
90
Total Gate Chargec
Qg
35
c
2400
VGS = 0 V, VDS = 25 V, f = 1 MHz
VDS = 50 V, VGS = 10 V, ID = 40 A
Gate-Source Charge
Qgs
Gate-Drain Chargec
Qgd
9
RG
1.7
Gate Resistance
Turn-On Delay Time
c
Rise Timec
Turn-Off Delay Timec
Fall Timec
td(on)
tr
td(off)
VDD = 50 V, RL = 1.25 Ω
ID ≅ 40 A, VGEN = 10 V, RG = 2.5 Ω
tf
pF
270
60
nC
11
Ω
11
45
12
ns
Source-Drain Diode Ratings and Characteristics TC = 25 °Cb
IS
40
Pulsed Current
ISM
120
Forward Voltagea
VSD
Continuous Current
Reverse Recovery Time
Peak Reverse Recovery Current
Reverse Recovery Charge
IF = 30 A, VGS = 0 V
trr
IRM(REC)
Qrr
IF = 30 A, di/dt = 100 A/µs
A
1.0
1.5
V
60
100
ns
5
8
A
0.15
0.4
µC
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
VBM1104N
www.VBsemi.com
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
75
75
VGS = 10 thru 5V
60
45
ID - Drain Current (A)
I D - Drain Current (A)
60
4V
30
45
30
TC = 125 °C
15
15
25 °C
2V
- 55 °C
4
6
8
1
2
3
4
5
6
VGS - Gate-to-Source Voltage (V)
VDS - Drain-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
100
0.10
TC = - 55 °C
r DS(on) - On-Resistance (Ω)
g fs - Transconductance (S)
80
25 °C
60
125 °C
40
0.08
0.06
VGS = 4.5V
0.04
VGS = 10 V
0.02
30
45
60
15
30
60
75
Transconductance
On-Resistance vs. Drain Current
3500
Ciss
2800
C - Capacitance (pF)
45
2100
1400
700
Crss
VDS = 50 V
ID =10 A
16
12
8
4
Coss
60
80
100
40
50
Qg - Total Gate Charge (nC)
Capacitance
Gate Charge
60
70
3
VBM1104N
www.VBsemi.com
2.5
100
VGS = 10 V
ID = 15 A
I S - Source Current (A)
(Normalized)
2.0
1.5
0.8
TJ = 150 °C
10
TJ = 25 °C
0.4
0.0
- 50
- 25
50
75
100
125
150
1
0.9
1.2
TJ - Junction Temperature (°C)
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
Drain-Source Breakdown Voltage (V)
130
100
I Dav (A)
0.6
On-Resistance vs. Junction Temperature
1000
10
IAV (A) at TA = 25 °C
1
IAV (A) at TA = 150 °C
0.1
0.00001
4
0.3
0.0001
0.001
0.01
0.1
1
ID = 10 mA
125
120
115
110
105
100
95
- 50
- 25
50
75
100
125
150
tin (s)
Avalanche Current vs. Time
175
VBM1104N
www.VBsemi.com
THERMAL RATINGS
1000
50
100
40
30
50
75
100
125
150
Limited
by rDS(on)*
10 µs
10
100 µs
1 ms
10 ms
1
0.1
0.1
175
TC - Ambient Temperature (°C)
1
* VGS
Maximum Avalanche and Drain Current
vs. Case Temperature
DC, 100 ms
TC = 25 °C
Single Pulse
10
100
1000
minimum VGS at which rDS(on) is specified
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Case
5
VBM1104N
www.VBsemi.com
TO-220AB
MILLIMETERS
A
E
F
D
H(1)
Q
ØP
3
2
L(1)
1
M*
L
b(1)
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
4.25
4.65
0.167
0.183
0.040
b
0.69
1.01
0.027
b(1)
1.20
1.73
0.047
0.068
c
0.36
0.61
0.014
0.024
D
14.85
15.49
0.585
0.610
E
10.04
10.51
0.395
0.414
e
2.41
2.67
0.095
0.105
e(1)
4.88
5.28
0.192
0.208
F
1.14
1.40
0.045
0.055
H(1)
6.09
6.48
0.240
0.255
J(1)
2.41
2.92
0.095
0.115
L
13.35
14.02
0.526
0.552
L(1)
3.32
3.82
0.131
0.150
ØP
3.54
3.94
0.139
0.155
Q
2.60
3.00
0.102
0.118
ECN: X12-0208-Rev. N, 08-Oct-12
DWG: 5471
Notes
* M = 1.32 mm to 1.62 mm (dimension including protrusion)
Heatsink hole for HVM
C
b
e
J(1)
e(1)
6
VBM1104N
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
