VBM1307/VBL1307
www.VBsemi.com
N-Channel 30 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
• TrenchFET® power MOSFET
30
RDS(on) () at VGS = 10 V
0.0075
RDS(on) () at VGS = 4.5 V
0.0095
ID (A)
• Package with low thermal resistance
• 100 % Rg and UIS tested
70
Configuration
Single
Package
TO-220AB/ TO-263
TO-220AB
D
TO-263
G
S
G
G D S
D S
N-Channel MOSFET
Top View
Top View
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
Drain-Source Voltage
VDS
30
Gate-Source Voltage
VGS
± 20
Continuous Drain Current
TC = 25 °C a
TC = 125 °C
Continuous Source Current (Diode Conduction) a
Pulsed Drain Current
b
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
Maximum Power Dissipation b
L = 0.1 mH
TC = 25 °C
TC = 125 °C
Operating Junction and Storage Temperature Range
ID
V
70
50
IS
70
IDM
250
IAS
33
EAS
54
PD
UNIT
71
23
A
mJ
W
TJ, Tstg
-55 to +175
°C
SYMBOL
LIMIT
UNIT
THERMAL RESISTANCE RATINGS
PARAMETER
Junction-to-Ambient
Junction-to-Case (Drain)
PCB
Mount c
RthJA
50
RthJC
2.1
°C/W
Notes
a. Package limited.
b. Pulse test; pulse width 300 μs, duty cycle 2 %.
c. When mounted on 1" square PCB (FR4 material).
1
VBM1307/VBL1307
www.VBsemi.com
SPECIFICATIONS (TC = 25 °C, unless otherwise noted)
SYMBOL
PARAMETER
TEST CONDITIONS
MIN.
TYP.
VDS
VGS = 0 V, ID = 250 μA
30
VGS(th)
VDS = VGS, ID = 250 μA
1.0
VDS = 0 V, VGS = ± 20 V
MAX.
UNIT
Static
Drain-Source Breakdown Voltage
Gate-Source Threshold Voltage
Gate-Source Leakage
Zero Gate Voltage Drain Current
On-State Drain Current a
Drain-Source On-State Resistance a
Forward Transconductance b
Dynamic
IGSS
IDSS
ID(on)
RDS(on)
gfs
2.5
VGS = 0 V
VDS = 30 V
VGS = 0 V
VDS = 30 V, TJ = 125 °C
50
VGS = 0 V
VDS = 30 V, TJ = 175 °C
150
VGS = 10 V
VDS 5 V
70
VGS = 10 V
ID = 20 A
0.007
VGS = 10 V
ID = 20 A, TJ = 125 °C
0.010
VGS = 10 V
ID = 20 A, TJ = 175 °C
0.014
VGS = 4.5 V
ID = 15 A
0.010
100
1850
2200
VDS = 15 V, ID = 15 A
± 100
V
nA
1
μA
A
S
b
Input Capacitance
Ciss
VGS = 0 V
Output Capacitance
Coss
260
400
Reverse Transfer Capacitance
Crss
95
200
Total Gate Charge c
Qg
46
Gate-Source
Charge c
Gate-Drain Charge c
Gate Resistance
Turn-On Delay Time c
Rise Time c
Turn-Off Delay
Qgs
Fall Time c
VDS = 20 V, ID = 50 A
Qgd
Rg
f = 1 MHz
td(on)
tr
Time c
VGS = 10 V
VDS = 25 V, f = 1 MHz
td(off)
VDD = 20 V, RL = 0.4
ID 50 A, VGEN = 10 V, Rg = 1
tf
Source-Drain Diode Ratings and Characteristics
pF
75
10
8
nC
1.3
2.8
4.5
9
15
19
30
26
40
10
15
200
A
0.87
1.5
V
ns
b
Pulsed Current a
ISM
Forward Voltage
VSD
IF = 30 A, VGS = 0 V
Notes
a. Pulse test; pulse width 300 μs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
VBM1307/VBL1307
www.VBsemi.com
TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted)
Axis Title
250
100
10000
VGS = 10 V thru 6 V
80
150
VGS = 4 V
100
50
1000
60
1st line
2nd line
VGS = 5 V
2nd line
ID - Drain Current (A)
2nd line
200
40
100
TC = 25 °C
TC = 125 °C
VGS = 3 V
TC = -55 °C
8
12
16
4
6
8
VDS - Drain-to-Source Voltage (V)
2nd line
VGS - Gate-to-Source Voltage (V)
2nd line
Output Characteristics
Transfer Characteristics
10
Axis Title
10000
Axis Title
0.010
10000
TC = -55 °C
1000
TC = 125 °C
80
100
40
2nd line
RDS(on) - On-Resistance (Ω)
1000
120
1st line
2nd line
2nd line
gfs - Transconductance (S)
VGS = 4.5 V
TC = 25 °C
160
10
40
0.006
VGS = 10 V
100
0.004
0.002
0.000
10
10
On-Resistance vs. Drain Current
Axis Title
1000
100
Crss
Coss
12
18
24
30
10000
ID = 50 A
VDS = 20 V
8
1000
6
1st line
2nd line
1000
1500
2nd line
Ciss
500
100
10
10000
1st line
2nd line
2nd line
C - Capacitance (pF)
80
Transconductance
Axis Title
6
60
2nd line
2500
2nd line
2000
1st line
2nd line
200
4
100
2
40
2nd line
Qg - Total Gate Charge (nC)
2nd line
Capacitance
Gate Charge
50
3
VBM1307/VBL1307
www.VBsemi.com
Axis Title
Axis Title
100
10000
10000
ID = 30 A
TJ = 150 °C
10
VGS = 10 V
1000
1.7
VGS = 4.5 V
1.3
100
0.9
0.5
50
TJ = 25 °C
0.1
100
0.01
0.001
10
-50 -25
1000
1
10
75 100 125 150 175
0.2
0.4
0.8
1.0
1.2
VSD - Source-to-Drain Voltage (V)
2nd line
On-Resistance vs. Junction Temperature
Source Drain Diode Forward Voltage
Axis Title
Axis Title
0.6
10000
0.04
10000
1000
0.03
0.02
100
TJ = 150 °C
0.01
4
10
6
8
ID = 5 mA
-0.6
ID = 250 μA
-1.4
10
10
-50 -25
50
75 100 125 150 175
2nd line
TJ - Temperature (°C)
2nd line
On-Resistance vs. Gate-to-Source Voltage
Threshold Voltage
Axis Title
55
10000
ID = 1 mA
52
1000
49
1st line
2nd line
2nd line
100
-1.0
TJ = 25 °C
-0.2
1st line
2nd line
2nd line
VGS(th) Variance (V)
0.2
1st line
2nd line
2nd line
0.6
TJ - Junction Temperature (°C)
2nd line
0.05
46
100
43
40
10
-50 -25
50
75 100 125 150 175
2nd line
Drain Source Breakdown vs. Junction Temperature
4
1st line
2nd line
2nd line
IS - Source Current (A)
2.1
1st line
2nd line
2nd line
RDS(on) - On-Resistance (Normalized)
2.5
VBM1307/VBL1307
www.VBsemi.com
THERMAL RATINGS (TA = 25 °C, unless otherwise noted)
Axis Title
1000
10000
IDM limited
100 μs
10
ID limited
1000
1 ms
10 ms
100 ms, 1 s, 10 s, DC
1
Limited by RDS(on) (1)
1st line
2nd line
2nd line
100
100
0.1
TC = 25 °C
Single pulse
0.01
0.01
(1)
BVDSS limited
0.1
1
10
100
10
1000
VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
Axis Title
1
Duty Cycle = 0.5
1000
Notes:
0.2
1st line
2nd line
Normalized Effective Transient
Thermal Impedance
10000
PDM
0.1
0.1
t1
0.05
t2
t1
t2
100
0.02
Single pulse
0.01
0.0001
0.001
0.01
0.1
1
10
100
10
1000
Square Wave Pulse Duration (s)
2nd line
Normalized Thermal Transient Impedance, Junction-to-Ambient
5
VBM1307/VBL1307
www.VBsemi.com
Axis Title
1
Duty Cycle = 0.5
1000
0.2
1st line
2nd line
Thermal Impedance
10000
0.1
0.1
100
0.05
0.02
Single pulse
0.01
0.0001
10
0.001
0.01
0.1
1
10
2nd line
Normalized Thermal Transient Impedance, Junction-to-Case
Note
• The characteristics shown in the two graphs
- Normalized Transient Thermal Impedance Junction to Ambient (25 °C)
- Normalized Transient Thermal Impedance Junction to Case (25 °C)
are given for general guidelines only to enable the user to get a “ball park” indication of part capabilities. The data are extracted from single
pulse transient thermal impedance characteristics which are developed from empirical measurements. The latter is valid for the part
mounted on printed circuit board - FR4, size 1" x 1" x 0.062", double sided with 2 oz. copper, 100 % on both sides. The part capabilities
can widely vary depending on actual application parameters and operating conditions.
6
VBM1307/VBL1307
www.VBsemi.com
TO-220AB
MILLIMETERS
A
E
F
D
H(1)
Q
ØP
3
2
L(1)
1
M*
L
b(1)
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
4.25
4.65
0.167
0.183
0.040
b
0.69
1.01
0.027
b(1)
1.20
1.73
0.047
0.068
c
0.36
0.61
0.014
0.024
D
14.85
15.49
0.585
0.610
E
10.04
10.51
0.395
0.414
e
2.41
2.67
0.095
0.105
e(1)
4.88
5.28
0.192
0.208
F
1.14
1.40
0.045
0.055
H(1)
6.09
6.48
0.240
0.255
J(1)
2.41
2.92
0.095
0.115
L
13.35
14.02
0.526
0.552
L(1)
3.32
3.82
0.131
0.150
ØP
3.54
3.94
0.139
0.155
Q
2.60
3.00
0.102
0.118
ECN: X12-0208-Rev. N, 08-Oct-12
DWG: 5471
Notes
* M = 1.32 mm to 1.62 mm (dimension including protrusion)
Heatsink hole for HVM
C
b
e
J(1)
e(1)
7
VBM1307/VBL1307
www.VBsemi.com
TO-263AB
A
(Datum A)
3
A
4
4
L1
B
A
E
c2
H
Gauge
plane
4
0° to 8°
5
D
B
Detail A
Seating plane
H
1
2
C
3
C
L
L3
B
A1
L4
Detail “A”
Rotated 90° CW
scale 8:1
L2
B
A
2 x b2
c
2xb
E
0.010 M A M B
± 0.004 M B
2xe
Plating
5
b1, b3
Base
metal
c1
(c)
D1
4
5
(b, b2)
Lead tip
View A - A
INCHES
MILLIMETERS
4
E1
Section B - B and C - C
Scale: none
MILLIMETERS
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
DIM.
MIN.
MAX.
MIN.
MAX.
A
4.06
4.83
0.160
0.190
D1
6.86
0.270
A1
0.00
0.25
0.000
0.010
E
9.65
10.67
0.380
0.420
b
0.51
0.99
0.020
0.039
E1
6.22
0.245
b1
0.51
0.89
0.020
0.035
e
b2
1.14
1.78
0.045
0.070
H
14.61
2.54 BSC
15.88
0.575
0.100 BSC
0.625
b3
1.14
1.73
0.045
0.068
L
1.78
2.79
0.070
0.110
c
0.38
0.74
0.015
0.029
L1
1.65
0.066
c1
0.38
0.58
0.015
0.023
L2
1.78
0.070
c2
1.14
1.65
0.045
0.065
L3
D
8.38
9.65
0.330
0.380
L4
0.25 BSC
4.78
5.28
0.010 BSC
0.188
0.208
ECN: S-82110-Rev. A, 15-Sep-08
DWG: 5970
Notes
1. Dimensioning and tolerancing per ASME Y14.5M-1994.
2. Dimensions are shown in millimeters (inches).
3. Dimension D and E do not include mold flash. Mold flash shall not exceed 0.127 mm (0.005") per side. These dimensions are measured at the
outmost extremes of the plastic body at datum A.
4. Thermal PAD contour optional within dimension E, L1, D1 and E1.
5. Dimension b1 and c1 apply to base metal only.
6. Datum A and B to be determined at datum plane H.
7. Outline conforms to JEDEC outline to TO-263AB.
8
VBM1307/VBL1307
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR D2PAK: 3-Lead
0.420
0.355
0.635
(16.129)
(9.017)
(10.668)
0.145
(3.683)
0.135
(3.429)
0.200
0.050
(5.080)
(1.257)
Recommended Minimum Pads
Dimensions in Inches/(mm)
9
VBM1307/VBL1307
Disclaimer
www.VBsemi.com
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
