VBM2610N
www.VBsemi.com
P-Channel 60-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
- 60
RDS(on) (Ω)
ID (A)
0.062 at V GS = - 10 V
- 20
0.074 at VGS = - 4.5 V
- 15
• TrenchFET® Power MOSFET
• 100 % UIS Tested
Qg (Typ)
12.5
APPLICATIONS
• Load Switch
S
TO-220AB
G
D
G D S
Top View
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted
Parameter
Gate-Source Voltage
Continuous Drain Current (TJ = 175 °C)
TC = 25 °C
TC = 100 °C
Symbol
Limit
Unit
VGS
± 20
V
- 20
ID
- 12
IDM
- 60
Continuing Source Current (Diode Conduction)
IS
- 12
Avalanche Current
IAS
- 12
Pulsed Drain Current
Single Pulse Avalanche Energy
Maximum Power Dissipation
L = 0.1 mH
TC = 25 °C
TA = 25 °C
EAS
7.2
mJ
60a
PD
W
2b
TJ, Tstg
Operating Junction and Storage Temperature Range
A
- 55 to 175
°C
THERMAL RESISTANCE RATINGS
Parameter
Junction-to-Ambientb
Junction-to-Case
Symbol
t ≤ 10 sec
Steady State
RthJA
RthJC
Typical
Maximum
62
75
5
6
Unit
°C/W
Notes:
a. See SOA curve for voltage derating.
b. Surface Mounted on 1" x 1" FR-4 boad.
1
VBM2610N
www.VBsemi.com
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min
V(BR)DSS
VGS = 0 V, ID = - 250 µA
- 60
VGS(th)
VDS = VGS, ID = - 250 µA
- 1.0
IGSS
VDS = 0 V, VGS = ± 20 V
Typa
Max
- 2.0
- 3.0
Unit
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Gate-Body Leakage
IDSS
Zero Gate Voltage Drain Current
On-State Drain Currentb
-1
VDS = - 60 V, VGS = 0 V, TJ = 125 °C
- 50
VDS = - 60 V, VGS = 0 V, TJ = 175 °C
- 150
ID(on)
Drain-Source On-State Resistance
b
rDS(on)
± 100
VDS = - 5 V, VGS = - 10 V
- 10
0.100
VGS = - 10 V, ID = - 5 A, TJ = 125 °C
0.200
VGS = - 10 V, ID = - 5 A, TJ = 175 °C
0.300
Forward Transconductance
Dynamic
gfs
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Timec
td(on)
Turn-Off Delay Timec
td(off)
Turn-On Delay
Rise Timec
Fall Timec
tr
nA
µA
A
VGS = - 4.5 V, ID = - 2 A
b
V
Ω
0.120
VDS = - 15 V, ID = - 5 A
8
VDS = - 25 V, VGS = 0 V, f = 1 MHz
120
S
850
pF
90
13
VDS = - 30 V, VGS = - 10 V, ID = - 8.4 A
2.3
f = 1 MHz
8.0
nC
3.2
VDD = - 30 V, RL = 3.57 Ω
ID ≅ - 8.4 A, VGEN = - 10 V, RG = 2.5 Ω
tf
Ω
5
10
14
25
15
25
7
12
ns
b
Source-Drain Diode Ratings and Characteristics (TC = 25 °C)
Pulsed Current
ISM
Forward Voltageb
VSD
Reverse Recovery Time
trr
Qrr
- 20
IF = - 2 A, VGS = 0 V
IF = - 8 A, di/dt = 100 A/µs
- 0.9
A
- 1.3
V
50
80
ns
80
120
nC
Notes:
a. Guaranteed by design, not subject to production testing.
b. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
VBM2610N
www.VBsemi.com
TYPICAL CHARACTERISTICS 25 °C unless noted
TC = - 55 °C
VGS = 10 thru 6 V
25 °C
16
ID - Drain Current (A)
I D - Drain Current (A)
24
5V
18
12
4V
12
125 °C
8
4
6
3V
0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5
4
6
8
10
VGS - Gate-to-Source Voltage (V)
VDS - Drain-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
12
0.150
TC = - 55 °C
0.125
25 °C
rDS(on) - On-Resistance (Ω)
g fs - Transconductance (S)
10
125 °C
8
6
4
2
VGS = 4.5 V
0.100
VGS = 10 V
0.075
0.050
0.025
4
6
8
10
8
16
Transconductance
On-Resistance vs. Drain Current
V GS - Gate-to-Source Voltage (V)
1400
1200
C - Capacitance (pF)
12
Ciss
1000
800
600
400
Coss
200
Crss
VDS = 30 V
ID = 8.4 A
16
12
8
4
40
Capacitance
50
60
10
15
Qg - Total Gate Charge (nC)
Gate Charge
3
VBM2610N
www.VBsemi.com
2.3
2.0
10
VGS = 10 V
ID = 50 A
TJ = 150 °C
I S - Source Current (A)
(Normalized)
1
1.7
1.4
1.1
0.1
TJ = 25 °C
0.01
0.8
0.5
- 50
0.001
- 25
50
75
100
125
150
175
0.0
TJ - Junction Temperature (°C)
0.2
0.4
0.6
0.8
1.0
VSD - Source-to-Drain Voltage (V)
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
THERMAL RATINGS
10
100
8
10
10 µs
6
4
100 µs
1 ms
1
10 ms
100 ms, DC
0.1
TC = 25 °C
Single Pulse
0.01
2
0.001
50
75
100
125
150
TC - Case Temperature (°C)
Drain Current vs. Case Temperature
4
*Limited by rDS(on)
175
0.1
1
10
100
*VGS
minimum VGS at which rDS(on) is specified
Safe Operating Area
VBM2610N
www.VBsemi.com
THERMAL RATINGS
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-−4
10- 3
10- 2
10- 1
1
10
100
600
100
600
Square Wave Pulse Duration (sec)
Normalized Thermal Transient Impedance, Junction-to-Ambient
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-−4
10- 3
10- 2
10- 1
1
10
Normalized Thermal Transient Impedance, Junction-to-Case
5
VBM2610N
www.VBsemi.com
TO-220AB
MILLIMETERS
A
E
DIM.
F
D
H(1)
Q
ØP
3
2
L(1)
1
M*
L
b(1)
MIN.
MAX.
INCHES
MIN.
MAX.
A
4.25
4.65
0.167
0.183
b
0.69
1.01
0.027
0.040
b(1)
1.20
1.73
0.047
0.068
c
0.36
0.61
0.014
0.024
D
14.85
15.49
0.585
0.610
E
10.04
10.51
0.395
0.414
e
2.41
2.67
0.095
0.105
e(1)
4.88
5.28
0.192
0.208
F
1.14
1.40
0.045
0.055
H(1)
6.09
6.48
0.240
0.255
J(1)
2.41
2.92
0.095
0.115
L
13.35
14.02
0.526
0.552
L(1)
3.32
3.82
0.131
0.150
ØP
3.54
3.94
0.139
0.155
Q
2.60
3.00
0.102
0.118
ECN: X12-0208-Rev. N, 08-Oct-12
DWG: 5471
Notes
* M = 1.32 mm to 1.62 mm (dimension including protrusion)
Heatsink hole for HVM
C
b
e
J(1)
e(1)
6
VBM2610N
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
