VBQF1303
www.VBsemi.com
N-Channel 30 V (D-S) MOSFET
FEATURES
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % Rg and UIS Tested
• Compliant to RoHS Directive 2002/95/EC
PRODUCT SUMMARY
VDS (V)
30
RDS(on) () Typ.
Qg (Typ.)
ID (A)
0.004 at VGS = 4.5 V
50
0.005 at VGS = 2.5 V
45
33.5 nC
APPLICATIONS
DFN 3x3 EP
Motor Control
Industrial
Load Switch
ORing
D
Bottom View
Top View
Top View
1
8
2
7
3
6
4
5
G
S
N-Channel MOSFET
Pin 1
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current (TJ = 150 °C)
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
Limit
ID
IDM
Pulsed Drain Current (t = 300 µs)
Continuous Source-Drain Diode Current
TC = 25 °C
TA = 25 °C
IS
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
L = 0.1 mH
IAS
EAS
TC = 25 °C
TC = 70 °C
Maximum Power Dissipation
TA = 25 °C
TA = 70 °C
Operating Junction and Storage Temperature Range
Soldering Recommendations (Peak Temperature)
Unit
30
± 20
50 a, e
40 a, e
22b, c
15b, c
150
35
3.3b, c
33
3.7b, c
2.4b, c
- 55 to 150
260
PD
TJ, Tstg
V
A
mJ
W
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambientb, d
Maximum Junction-to-Case (Drain)
t 10 s
Steady State
Symbol
RthJA
RthJC
Typical
24
1.9
Maximum
33
2.4
Unit
°C/W
Notes:
a. Based on TC = 25 °C.
b. Surface mounted on 1" x 1" FR4 board.
c. t = 10 s.
d. Maximum under steady state conditions is 90 °C/W.
e. Calculated based on maximum junction temperature. Package limitation current is 80 A.
1
VBQF1303
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
30
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
VDS/TJ
V
30
ID = 250 µA
mV/°C
VGS(th) Temperature Coefficient
VGS(th)/TJ
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS , ID = 250 µA
1.5
V
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
nA
VDS = 30 V, VGS = 0 V
1
VDS = 30 V, VGS = 0 V, TJ = 55 °C
10
Gate-Source Leakage
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward Transconductancea
RDS(on)
gfs
VDS 5 V, VGS = 10 V
- 5.6
0.5
30
µA
A
VGS 4.5 V, ID = 10 A
0.0040
VGS 2.5 V, ID = 7 A
0.0050
VDS = 15 V, ID = 10 A
65
S
b
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
3065
VDS = 15 V, VGS = 0 V, f = 1 MHz
td(off)
pF
360
VDS = 15 V, VGS = 10 V, ID = 10 A
68
102
33.5
51
7.7
VDS = 15 V, VGS = 4.5 V, ID = 10 A
f = 1 MHz
VDD = 15 V, RL = 1.5
ID 10 A, VGEN = 4.5 V, Rg = 1
0.3
0.7
1.4
24
45
24
45
32
60
tf
12
24
td(on)
14
28
tr
td(off)
nC
13.8
td(on)
tr
406
ID 10 A, VGEN = 10 V, Rg = 1
tf
13
26
33
60
8
16
ns
Drain-Source Body Diode Characteristics
IS
Pulse Diode Forward Current
ISM
Body Diode Voltage
VSD
TC = 25 °C
35
A
70
IS = 3 A, VGS 0 V
0.7
1.1
V
Body Diode Reverse Recovery Time
trr
21
40
ns
Body Diode Reverse Recovery Charge
Qrr
10
nC
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
IF = 10 A, dI/dt = 100 A/µs, TJ = 25 °C
9
12
ns
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
VBQF1303
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
10
70
VGS = 10 V thru 4 V
8
42
ID - Drain Current (A)
56
VGS = 3 V
28
VGS = 2 V
6
TC = 25 °C
4
2
14
TC = - 55 °C
TC = 125 °C
1
1.5
2
VDS - Drain-to-Source Voltage (V)
6.0
4.5
7.5
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
4500
0.0100
3600
C - Capacitance (pF)
0.0120
0.0080
VGS = 4.5 V
0.0060
Ciss
2700
1800
VGS = 10 V
0.0040
900
Coss
Crss
0.0020
24
36
48
60
10
15
30
On-Resistance vs. Drain Current and Gate Voltage
Capacitance
10
1.8
ID = 10 A
RDS(on) - On-Resistance (Normalized)
ID = 10 A
RDS(on) - On-Resistance (Ω)
3.0
1.5
8
VDS = 15 V
6
VDS = 10 V
VDS = 20 V
4
2
28
42
Qg - Total Gate Charge (nC)
Gate Charge
56
70
1.6
VGS = 10 V
1.4
1.2
VGS = 4.5 V
1.0
0.8
0.6
- 50
- 25
50
75
100
125
150
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
3
VBQF1303
www.VBsemi.com
0.015
100
ID = 10 A
0.012
TJ = 150 °C
IS - Source Current (A)
10
TJ = 25 °C
1
0.1
0.01
0.009
0.006
TJ = 125 °C
0.003
TJ = 25 °C
0.001
0.000
0.0
0.2
0.4
0.6
0.8
1.0
1.2
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
6
8
10
On-Resistance vs. Gate-to-Source Voltage
0.4
100
0.2
80
ID = 5 mA
Power (W)
VGS(th) - Variance (V)
4
- 0.2
60
40
- 0.4
ID = 250 μA
- 0.8
- 50
- 25
50
75
100
125
150
0.01
TJ - Temperature (°C)
10
100
Single Pulse Power, Junction-to-Ambient
100
IDM Limited
10
1
Time (s)
Threshold Voltage
100 μs
ID Limited
1 ms
1
Limited by RDS(on)*
10 ms
100 ms
1s
0.1
10 s
TA = 25 °C
Single Pulse
DC
BVDSS Limited
0.01
0.01
0.1
1
10
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area, Junction-to-Ambient
4
0.1
100
VBQF1303
www.VBsemi.com
100
80
60
40
Limited by Package
50
75
100
125
150
TC - Case Temperature (°C)
65
2.0
52
1.6
39
1.2
Power (W)
Power (W)
Current Derating*
26
13
0.8
0.4
50
75
100
125
150
50
75
100
125
TA - Ambient Temperature (°C)
Power, Junction-to-Case
150
* The power dissipation PD is based on TJ(max.) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
5
VBQF1303
www.VBsemi.com
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
Notes:
0.1
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = R thJA = 81 °C/W
0.02
3. T JM - TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
0.0001
0.001
0.01
0.1
1
Square Wave Pulse Duration (s)
10
100
1000
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
0.0001
0.001
0.01
0.1
Normalized Thermal Transient Impedance, Junction-to-Case
6
1
10
VBQF1303
www.VBsemi.com
7
VBQF1303
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
