VBQF1310
VBQF1310
    VBSEMI(微碧)
    DFN-8-EP(3x3)
    MOSFETs N-沟道 30V 30A DFN-8-EP(3x3)
VBQF1310 数据手册
VBQF1310 www.VBsemi.com N-Channel 30-V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) 0.010 at V 30 ID (A)a RDS(on) (Ω) 0.018 at V GS = 10 V GS = 4.5 V • Halogen-free • TrenchFET® Power MOSFET • 100 % Rg and UIS Tested Qg (Typ.) 30 26.5 nC RoHS COMPLIANT 25 APPLICATIONS • DC/DC Conversion - Low-Side Switch • Notebook PC • Gaming DFN 3x3 EP Top View Bottom View Top View D 1 8 2 7 3 6 4 5 G S Pin 1 N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted Parameter Drain-Source Voltage Gate-Source Voltage Continuous Drain Current (TJ = 150 °C) Symbol VDS VGS TC = 25 °C TC = 70 °C TA = 25 °C TA = 70 °C Single Pulse Avalanche Current Avalanche Energy ID TC = 25 °C TA = 25 °C IS L = 0.1 mH IAS EAS TC = 25 °C TC = 70 °C Maximum Power Dissipation TA = 25 °C TA = 70 °C Operating Junction and Storage Temperature Range Unit V 21.5b, c 17.1b, c 100 13 IDM Pulsed Drain Current Continuous Source-Drain Diode Current Limit 30 ± 20 30 22.6 A 3.1b, c 10 mJ 5 16.7 10.7 PD 3.7b, c 2.4b, c - 55 to 150 TJ, Tstg W °C THERMAL RESISTANCE RATINGS Parameter Maximum Junction-to-Ambientb, d Maximum Junction-to-Foot (Drain) t ≤ 10 s Steady State Symbol RthJA RthJF Typical 27 6 Maximum 34 7.5 Unit °C/W Notes: a. Based on TC = 25 °C. b. Surface Mounted on 1" x 1" FR4 board. c. t = 10 s. d. Maximum under Steady State conditions is 85 °C/W. 1 VBQF1310 www.VBsemi.com SPECIFICATIONS TJ = 25 °C, unless otherwise noted Parameter Symbol Test Conditions Min. VDS VGS = 0 V, ID = 1 mA 30 Typ. Max. Unit Static Drain-Source Breakdown Voltage ΔVDS/TJ VDS Temperature Coefficient V 27 ID = 250 µA mV/°C VGS(th) Temperature Coefficient ΔVGS(th)/TJ Gate-Source Threshold Voltage VGS(th) VDS = VGS , ID = 250 µA 3.0 V Gate-Source Leakage IGSS VDS = 0 V, VGS = ± 20 V ± 100 nA Zero Gate Voltage Drain Current IDSS VDS = 30 V, VGS = 0 V 1 VDS = 30 V, VGS = 0 V, TJ = 55 °C 10 On-State Drain Currenta ID(on) Drain-Source On-State Resistancea Forward Transconductancea RDS(on) gfs VDS ≥ 5 V, VGS = 10 V - 5.6 1.0 30 µA A VGS = 10 V, ID = 15 A 0.010 VGS = 4.5 V, ID = 10 A 0.018 VDS = 15 V, ID = 15 A 75 Ω S Dynamicb Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Rg Gate Resistance 650 VDS = 15 V, VGS = 0 V, f = 1 MHz VDS = 15 V, VGS = 10 V, ID = 10 A tr Rise Time td(off) Turn-Off Delay Time Fall Time Turn-On Delay Time 20 9 nC 0.7 f = 1 MHz 0.2 1.1 8 VDD = 15 V, RL = 1.5 Ω ID ≅ 10 A, VGEN = 4.5 V, Rg = 1 Ω 16 2.2 30 17 35 15 td(on) 14 30 VDD = 15 V, RL = 1.5 Ω ID ≅ 10 A, VGEN = 10 V, Rg = 1 Ω tf Ω 16 7 td(off) Fall Time 10 4.5 tf tr Rise Time Turn-Off Delay Time pF 2.1 VDS = 15 V, VGS = 4.5 V, ID = 10 A td(on) Turn-On Delay Time 236 20 50 100 16 30 8 18 ns Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current a IS Pulse Diode Forward Current ISM Body Diode Voltage VSD TC = 25 °C 13 100 IS = 3 A 1.2 A V Body Diode Reverse Recovery Time trr 40 ns Body Diode Reverse Recovery Charge Qrr 20 nC Reverse Recovery Fall Time ta Reverse Recovery Rise Time tb IF = 10 A, dI/dt = 100 A/µs, TJ = 25 °C 12.5 7.5 ns Notes: a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 % b. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2 VBQF1310 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted Axis Title 50 50 VGS = 10 V thru 4 V 40 30 20 VGS = 3 V 1000 30 1st line 2nd line 2nd line ID - Drain Current (A) ID - Drain Current (A) 40 10000 20 100 TC = 25 °C 10 10 TC = 125 °C TC = -55 °C 0 10 0 0 0 0.5 1 1.5 VDS - Drain-to-Source Voltage (V) 1 2 2 3 4 VGS - Gate-to-Source Voltage (V) 2nd line Transfer Characteristics Output Characteristics 840 0.025 RDS(on) - On-Resistance (Ω) Ciss C - Capacitance (pF) 630 0.020 VGS = 4.5 V 0.015 VGS = 10 V Coss 210 0.010 Crss 0.005 0 0 10 20 30 40 50 0 6 12 18 VDS - Drain-to-Source Voltage (V) On-Resistance vs. Drain Current Capacitance 1.65 VDS = 8 V RDS(on) - On-Resistance (Normalized) ID = 14.4 A 8 6 VDS = 15 V, 24 V 4 2 0 0 24 ID - Drain Current (A) 10 VGS - Gate-to-Source Voltage (V) 420 2 4 6 Qg - Total Gate Charge (nC) Gate Charge 8 10 30 VGS = 10 V, 14.4 A VGS = 4.5 V, 13 A 1.4 1.15 0.9 0.65 - 50 - 25 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 3 VBQF1310 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 0.025 100 R DS(on) - On-Resistance (Ω) IS - Source Current (A) ID = 15 A TJ = 150 °C 10 TJ = 25 °C 1 0.020 0.015 0.010 0.005 0.1 0.0 0.3 0.6 0.9 1.2 TJ = 25 °C 0.000 0 VSD - Source-to-Drain Voltage (V) 1 2 3 4 5 6 7 8 9 10 VGS - Gate-to-Source Voltage (V) Source-Drain Diode Forward Voltage On-Resistance vs. Gate-to-Source Voltage 200 1.85 ID = 250 μA 160 Power (W) 1.35 1.10 0.85 0.60 - 50 120 80 40 - 25 0 25 50 75 100 125 0 0.001 150 TJ - Temperature (°C) 0.1 Single Pulse Power 100 Limited by IDM Limited by RDS(on)* 10 100 μs 1 ms 1 10 ms 100 ms 10 s, 1 s 0.1 DC TA = 25 °C BVDSS Limited 0.01 0.1 1 10 100 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Safe Operating Area, Junction-to-Ambient 4 0.01 1 Single Pulse Power, Junction-to-Ambient Time (s) Threshold Voltage ID - Drain Current (A) VGS(th) (V) 1.60 10 VBQF1310 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 35 20 Package Limited 15 Power (W) ID - Drain Current (A) 28 21 10 14 5 7 0 0 0 25 50 75 100 TC - Case Temperature (°C) Current Derating a 125 150 0 25 50 75 100 TC - Case Temperature (°C) 125 150 Power, Junction-to-Case Note a. The power dissipation PD is based on TJ max. = 25 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit. 5 VBQF1310 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 Notes: 0.1 PDM 0.1 t1 0.05 t2 1. Duty Cycle, D = t1 t2 2. Per Unit Base = RthJA = 69 °C/W 0.02 3. TJM - TA = PDMZthJA(t) Single Pulse 4. Surface Mounted 0.01 0.0001 0.001 0.01 0.1 1 10 100 1000 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Ambient 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 0.05 0.02 Single Pulse 0.1 0.0001 0.001 0.01 0.1 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Case 6 1 VBQF1310 www.VBsemi.com 7 VBQF1310 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VBQF1310 价格&库存
很抱歉,暂时无法提供与“VBQF1310”相匹配的价格&库存,您可以联系我们找货
