SS8050
SS8050
    WPMTEK(维攀微)
    SOT-23
    通用三极管 NPN 1.5A 25V SOT-23
SS8050 数据手册
Integrated in OVP&OCP products provider SS8050 SOT-23 Plastic-Encapsulate Transistors TRANSISTOR (NPN) FEATURES Complimentary to SS8550 MARKING:Y1 MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Parameter Value Units (符号) (参数名称) (额定值) (单位) VCBO Collector-Base Voltage (集电极-基极电压) 40 V VCEO Collector-Emitter Voltage (集电极-发射极电压) 25 V VEBO Emitter-Base Voltage (发射极-基极电压) 5 V IC Collector Current -Continuous (集电极电流) 1.5 A PC Collector Power Dissipation (耗散功率) 0.625 W Tj Junction Temperature (结温) 150 ℃ Tstg Storage Temperature (储存温度) -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃unless otherwise specified) Parameter (参数名称) Symbol (符号) Test conditions (测试条件) MIN TYP MAX (最小值) (典型值) (最大值) UNIT (单位) Collector-base breakdown voltage 集电极-基极击穿电压 V(BR)CBO IC= 100μA, IE=0 40 V Collector-emitter breakdown voltage 集电极-发射极击穿电压 V(BR)CEO IC= 1mA, IB=0 25 V Emitter-base breakdown voltage 发射极-基极击穿电压 V(BR)EBO IE=100μA, IC=0 5 V Collector cut-off current 集电极-基极截止电流 ICBO VCB=20 V , IE=0 1 μA Collector cut-off current 集电极-发射极截止电流 ICEO VCE=15V , 10 μA Emitter cut-off current 发射极-基极截止电流 IEBO VEB=5V , IC=0 1 μA DC current gain 直流电流增益 hFE VCE=1V, IC= 100mA IB=0 80 400 Collector-emitter saturation voltage 集电极-发射极饱和压降 VCE(sat) IC=800mA, IB= 80mA 0.5 V Base-emitter saturation voltage 发射极-基极饱和压降 VBE(sat) IC=800mA, IB= 80mA 1.2 V CLASSIFICATION OF Range Rve.A_Aug,2017 7 80-100 hFE 100-200 -1- 200-400 400-600 www.wpmtek.com Integrated in OVP&OCP products provider SS8050 Typical Characteristics Rve.A_Aug,2017 7 -2- www.wpmtek.com
SS8050 价格&库存
很抱歉,暂时无法提供与“SS8050”相匹配的价格&库存,您可以联系我们找货
SS8050
  • 20+0.10703
  • 200+0.08543
  • 600+0.07344
  • 3000+0.05616
  • 9000+0.04990
  • 21000+0.04655
库存:1634
