SK32 THRU SK3200
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 200 Volts Forward Current - 3.0 Amperes
FEATURES
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
0.110(2.80)
0.100(2.54)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
MECHANICAL DATA
0.096(2.42)
0.078(1.98)
0.060(1.52)
0.030(0.76)
Case: JEDEC DO-214AC molded plastic body
Terminals: leads solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.002 ounce, 0.07 grams
0.008(0.203)MAX.
0.208(5.28)
0.188(4.80)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SYMBOLS SK32 SK33
VRRM
VRMS
VDC
21
30
SK34 SK35 SK36
40
28
40
50
35
50
60
42
60
SK38 SK310 SK3150SK3200 UNITS
80
56
80
100
70
100
200
150
200
150
105
150
VOLTS
VOLTS
VOLTS
I(AV)
3.0
Amps
IFSM
100.0
Amps
VF
0.55
IR
CJ
RθJA
TJ,
TSTG
0.70
0.85
0.5
0.95
0.2
2.0
300
500
55.0
-65 to +125
-65 to +150
-65 to +150
Volts
mA
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
2014-03 01版
http://www.microdiode.com
FIG. 1- FORWARD CURRENT DERATING CURVE
3.0
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
SK32-SK36
SK38-SK3200
0.6
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES SK32 THRU SK3200
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
80
60
40
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SK32-SK34
SK35-SK36
SK38-SK3150
SK3200
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
50
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.2
0.4
0.6
0.8
1.0
1.2
1.4
60
80
100
1.6
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
PERCENT OF PEAK REVERSE VOLTAGE,%
1000
TJ=25 C
100
SK32-SK34
SK35-SK3200
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
2014-03 01版
100
t,PULSE DURATION,sec.
很抱歉,暂时无法提供与“SK34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.09765
- 100+0.09072
- 300+0.08379
- 500+0.07687
- 2000+0.07341
- 5000+0.07133
