BZX84C2V4-BZX84C43
Surface mount zener diode
FEATURES
z
Planar Die Construction
z
300mW Power Dissipation
Zener Voltages from 2.4V - 43V
z
z
Ultra-Small Surface Mount Package Power Dissipation
SOT-23
Maximum Ratings(Ta=25℃ unless otherwise specified)
Characteristic
Symbol
Value
Unit
VF
Pd
0.9
300
V
mW
RθJA
417
Junction Temperature
Tj
150
℃ /W
Storage Temperature Range
Tstg
-55~+150
Forward Voltage (Note 2)
Power Dissipation(Note 1)
@ IF = 10mA
Thermal Resistance from Junction to Ambient
www.slkormicro.com
1
BZX84C2V4-BZX84C43
ELECTRICAL CHARACTERISTICS Ta=25℃ unless otherwise specified
Maximum Zener
ZenerVoltage Range (Note 2)
Type
Number
Impedance
VZ@IZT
IZT
ZZT@IZT
ZZK@IZK
(Ω)
Temperature
Reverse
Coefficent of
Current
(Note 3)
Code
Maximum
Zener
voltage
@ IZT=5mA
IZK
IR
mV/°C
VR
Nom(V)
Min(V)
Max(V)
(mA)
(mA)
(μA)
(V)
Min
Max
BZX84C2V4
Z11
2.4
2.20
2.60
5
100
600
1.0
50
1.0
-3.5
BZX84C2V7
Z12
2.7
2.5
2.9
5
100
600
1.0
-3.5
BZX84C3V0
Z13
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
BZX84C3V3
Z14
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
BZX84C3V6
Z15
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
BZX84C3V9
Z16
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
BZX84C4V3
Z17
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
BZX84C4V7
Z1
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
BZX84C5V1
Z2
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
BZX84C5V6
Z3
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
BZX84C6V2
Z4
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
BZX84C6V8
Z5
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
BZX84C7V5
Z6
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
BZX84C8V2
Z7
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
BZX84C9V1
Z8
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
BZX84C10
Z9
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
BZX84C11
Y1
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
BZX84C12
Y2
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
BZX84C13
Y3
13
12.4
14.1
5
30
170
1.0
0.1
8.0
BZX84C15
Y4
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
BZX84C16
Y5
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
BZX84C18
Y6
18
16.8
19.1
5
BZX84C20
Y7
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
BZX84C22
Y8
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
BZX84C24
Y9
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
BZX84C27
Y10
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
BZX84C30
Y11
30
28.0
32.0
2
BZX84C33
Y12
33
31.0
35.0
2
BZX84C36
Y13
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
BZX84C39
Y14
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
BZX84C43
Y15
43
40.0
46.0
2
100
700
1
0.1
32
45
80
80
Notes: 1. Valid provided that device terminals are kept at ambient temperature.
2. Tested with pulses, period=5ms,pulse width =300μs.
3. f = 1kHZ.
www.slkormicro.com
2
225
300
325
1.0
0.5
0.5
0.1
0.1
0.1
12.6
21.0
23.1
7.0
12.4
24.4
27.4
10
11.0
16.0
29.4
33.4
12
BZX84C2V4-BZX84C43
100
Ta =25℃
PD =300mW
Pulsed
1
43
39
36
33
30
27
1
0.5
1
2
3
4
5
6
7
8
9
10
0.5
10
11
15
VZ, ZENER VOLTAGE (V)
25
30
35
40
50
Typical Leakage Current
100
Pulsed
TYPICAL Ta VALUES
35
45
Temperature Coefficients
40
FOR BZX84CXXX SERIES
10
30
IR, LEAKAGE CURRENT (uA)
θVZ, TEMPERATURE COEFFICIENT (mV/℃)
24
10
18
10
9.1
8.2
7.5
6.2
6.8
5.1
5.6
4.7
2.4
10
PD =300mW
11
12
13
IZ, ZENER CURRENT (mA)
Pulsed
15
16
Ta =25℃
Zener Characteristics(11 V to 43 V)
Zener Characteristics(VZ Up to 10 V)
100
25
VZ @ IZT
15
10
5
1
0.1
0.01
Ta=100℃
1E-3
Ta=25℃
-5
1E-4
8
12
16
28
32
36
40
5
VZ, NOMINAL ZENER VOLTAGE (V)
10
15
45
Ta=25℃
f=1MHz
ZZT, DYNAMIC IMPEDANCE(Ω)
100
1V BIAS
BIAS AT
50% OF VZ NOM
10
IZ(AC)=0.1IZ(DC)
IZ=1mA
0V BIAS
C, CAPACITANCE (pF)
40
1000
Ta=25℃
1
f=1kHz
100
IZ=5mA
10
1
1
10
100
1
Power Derating Curve
300
PD
250
200
150
100
50
50
75
AMBIENT TEMPERATURE
www.slkormicro.com
100
Ta
10
350
(mW)
35
Effect of Zener Voltage on Zener Impedance
Typical Capacitance
1000
POWER DISSIPATION
30
125
150
3
100
很抱歉,暂时无法提供与“BZX84C16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.181683000+0.02351
- 6000+0.160586000+0.02078
- 9000+0.149799000+0.01938
- 15000+0.1376415000+0.01781
- 21000+0.1304521000+0.01688
- 30000+0.1234430000+0.01597
- 国内价格
- 50+0.12172
- 500+0.09548
- 3000+0.08090
- 6000+0.07215
- 24000+0.06459
- 51000+0.06048
- 国内价格 香港价格
- 1+0.974121+0.12603
- 10+0.5844810+0.07562
- 100+0.35583100+0.04604
- 500+0.25602500+0.03313
- 1000+0.223361000+0.02890
- 国内价格
- 50+0.11157
- 600+0.08752
- 1200+0.08621
- 3000+0.07415
