SS26B
SS26B
    SLKOR(萨科微)
    SMB(DO-214AA)
    肖特基二极管 正向压降(Vf):700mV @ 2A 直流反向耐压(Vr):60V 平均整流电流(Io):2A
SS26B 数据手册
SS22B-SS210B SURFACE MOUNT SCHOTTKY BARRIER DIODES VOLTAGE RANGE: 20 - 100V CURRENT: 2.0 A Features ! ! ! ! ! Schottky Barrier Chip Ideally Suited for Automatic Assembly Low Power Loss, High Efficiency For Use in Low Voltage Application Guard Ring Die Construction B Mechanical Data ! ! ! ! ! SMB(DO-214AA) A Case: SMB/DO-214AA, Molded Plastic Terminals: Solder Plated, Solderable per MIL-STD-750, Method 2026 Polarity: Cathode Band or Cathode Notch Marking: Type Number Weight: 0.093 grams (approx.) C D J H Maximum Ratings and Electrical Characteristics G E Dim Min Max A 3.30 3.94 B 4.06 4.70 C 1.91 2.21 D 0.15 0.31 E 5.00 5.59 G 0.10 0.20 H 0.76 1.52 J 2.00 2.62 All Dimensions in mm TA = 25C unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL(see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range Storage temperature range Symbol SS22B SS23B SS24B SS25B SS26B SS28B SS210B VRRM VRMS VDC 30 21 30 40 28 40 50 35 50 60 42 60 80 56 80 100 70 100 V V V I(AV) 2.0 A IFSM 50.0 A VF 0.50 0.85 0.70 0.5 IR 20 10 CJ RθJA 220 TJ, TSTG -65 to +125 180 75.0 -65 to +150 Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas www.slkormicro.com 20 14 20 Unit 1 -65 to +150 V mA pF C/W C C FIG. 1- FORWARD CURRENT DERATING CURVE FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 2.0 1.6 Single Phase Half Wave 60Hz Resistive or inductive Load 1.2 0.8 SS22B-SS24B SS25B-SS210B 0.4 0 0 25 50 75 50 £PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES SS22B-SS210B 100 125 150 40 30 20 10 175 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C 100 NUMBER OF CYCLES AT 60 Hz FIG. 4-TYPICAL REVERSE CHARACTERISTICS FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 50 1,000 INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES TJ=25 C INSTANTANEOUS FORWARD CURRENT,AMPERES 10.0 1 SS22B-SS24B SS25B-SS26B SS28B-SS210B 0.1 100 TJ=100 C 10 TJ=75 C 1 0.1 TJ=25 C 0.01 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 1.6 INSTANTANEOUS FORWARD VOLEAGE, VOLTS FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE 2000 JUNCTION CAPACITANCE, pF 1000 TJ=25 C 100 SS22B-SS24B SS25B-SS210B 100 10 1 0.1 0.01 0.1 1 10 10 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS www.slkormicro.com t,PULSE DURATION,sec. 2 100
SS26B
物料型号:SS210B, SS28B, SS26B, SS25B, SS24B, SS23B, SS22B
器件简介:这些二极管是表面安装的肖特基势垒二极管,适用于单相、半波、60Hz的电阻性或感性负载。对于电容性负载,需要将电流降低20%。
引脚分配:文档中提到了阳极带或阳极缺口来表示极性,并有型号编号的标记。
参数特性:包括最大重复峰值反向电压、最大有效值电压、最大直流阻断电压、在TL(见图1)时的最大平均正向整流电流、8.3ms单半正弦波峰值正向浪涌电流(JEDEC方法)、在2.0A时的最大瞬时正向电压、在额定直流阻断电压下25°C时的最大直流反向电流、在100°C时的典型结电容等。
功能详解:文档提供了正向电流降额曲线、最大非重复峰值正向浪涌电流、典型瞬时正向特性、典型反向特性和典型瞬态热阻抗等图表。
应用信息:这些二极管非常适合自动组装,并且适用于低电压应用。
封装信息:封装类型为SMB/DO-214AA,模塑塑料,重量约为0.093克。
SS26B 价格&库存
很抱歉,暂时无法提供与“SS26B”相匹配的价格&库存,您可以联系我们找货
SS26B
  • 1+0.25480
  • 100+0.24470
库存:5
