XL6005E1
XL6005E1
    XLSEMI(芯龙)
    TO-252-5
    180KHz 60V 4A开关电流升压LED恒流驱动器
XL6005E1 数据手册
Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Features General Description n n n The XL6005 regulator is fixed frequency PWM Boost (step-up) LED constant current driver, capable of driving Series 1W/3W/5W LED units with excellent line and load regulation. The regulator is simple to use because it includes internal frequency compensation and a fixed-frequency oscillator so that it requires a minimum number of external components to work. The XL6005 could directly drive 11 Series 1W LED units at VIN>12V . n n n n n n n n n n n Wide 3.6V to 32V Input Voltage Range 0.22V FB adjustable LED drive current Directly drive 11 Series 1W LED at VIN>=12V Fixed 180KHz Switching Frequency Max. 4A Switching Current Capability Up to 94% efficiency Excellent line and load regulation EN PIN TTL shutdown capability & With PWM Dimming Function Internal Optimize Power MOSFET Built in Soft-Start Function Built in Frequency Compensation Built in Thermal Shutdown Function Built in Current Limit Function Available in TO252-5L package The PWM control circuit is able to adjust the duty ratio linearly from 0 to 95%. An enable function, an over current protection function is built inside. An internal compensation block is built in to minimize external component count. Applications n n n n LED Lighting Boost constant current driver Monitor LED Backlighting 7’ to 15’ LCD Panels Figure1. Package Type of XL6005 Rev 1.5 www.xlsemi.com 1 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Pin Configurations Figure2. Pin Configuration of XL6005 (Top View) Table 1 Pin Description Pin Number 1 Pin Name GND 2 EN 3 SW 4 VIN 5 FB Description Ground Pin. Enable Pin. Drive EN pin low to turn off the device, drive it high to turn it on. Floating is default high. Power Switch Output Pin (SW). Supply Voltage Input Pin. XL6005 operates from a 3.6V to 32V DC voltage. Bypass Vin to GND with a suitably large capacitor to eliminate noise on the input. Feedback Pin (FB). The feedback threshold voltage is 0.22V. Rev 1.5 www.xlsemi.com 2 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Function Block Figure3. Function Block Diagram of XL6005 Typical Application Circuit Figure4. XL6005 Typical Application Circuit Rev 1.5 www.xlsemi.com 3 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Ordering Information Order Information XL6005E1 Marking ID XL6005E1 Package Type TO252-5L Packing Type Supplied As 2500 Units on Tape & Reel XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant. Absolute Maximum Ratings(Note1) Parameter Symbol Vin VFB VEN VOutput PD Value -0.3 to 36 -0.3 to Vin -0.3 to Vin -0.3 to 60 Internally limited Unit V V V V mW Input Voltage Feedback Pin Voltage EN Pin Voltage Output Switch Pin Voltage Power Dissipation Thermal Resistance (TO252-5L) (Junction to Ambient, No Heatsink, Free Air) Operating Junction Temperature Storage Temperature Lead Temperature (Soldering, 10 sec) ESD (HBM) RJA 50 ºC/W TJ TSTG TLEAD -40 to 125 -65 to 150 260 >2000 ºC ºC ºC V Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operation is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Rev 1.5 www.xlsemi.com 4 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 XL6005 Electrical Characteristics Ta = 25℃;unless otherwise specified. Symbol Parameter Test Condition Min. Typ. Max. Unit 209 220 231 mV - 92 - % System parameters test circuit figure4 Feedback Voltage VFB Efficiency ŋ Vin = 5V to 12V, Vout=24V Iload=100mA Vin=12V ,Vout=24V Iout=1A Electrical Characteristics (DC Parameters) Vin = 12V, GND=0V, Vin & GND parallel connect a 100uf/50V capacitor; Iout=100mA, Ta = 25℃; the others floating unless otherwise specified. Parameters Symbol Test Condition Min. Typ. 3.6 Max. Unit 32 V Input operation voltage Vin Shutdown Supply Current ISTBY VEN=0V 70 100 uA Quiescent Supply Current Iq VEN =2V, VFB =Vin 2.5 5 mA 180 216 Khz Oscillator Frequency Fosc Switch Current Limit IL VFB =0 4 Output Power NMOS Rdson Vin=12V, ISW=4A 110 VEN High (Regulator ON) Low (Regulator OFF) 1.4 0.8 IH VEN =2V (ON) 3 10 uA IL VEN =0V (OFF) 3 10 uA DMAX VFB=0V 90 EN Pin Threshold EN Pin Input Leakage Current Max. Duty Cycle 144 Rev 1.5 A 120 mohm V % www.xlsemi.com 5 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Schottky Diode Selection Table Current 1A 3A Surface Through VR (The same as system maximum input voltage) Mount Hole 20V 30V 40V 50V 1N5817 1N5818 1N5819 √ √ 1N5820 1N5821 1N5822 √ MBR320 MBR330 MBR340 MBR350 MBR360 SK32 SK33 SK34 SK36 30WQ03 30WQ04 30WQ05 31DQ03 31DQ04 31DQ05 SR305 SR306 √ √ √ 5A √ 60V SK35 √ SR302 SR303 SR304 √ 1N5823 1N5824 1N5825 √ SR502 SR503 SR504 SR505 SR506 √ SB520 SB530 SB540 SB550 SB560 50WQ03 50WQ04 50WQ05 Typical System Application for VIN=12V to driver 11 x 1W series LED units Figure5. XL6005 System Parameters Test Circuit (12V ~11 x 1W LED) Rev 1.5 www.xlsemi.com 6 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Typical System Application for VIN>=12V to driver 6 x 3W series LED units Figure6. XL6005 System Parameters Test Circuit (12V ~ 6 x 3W LED) Typical System Application for VIN>=24V to driver 11 x 3W series LED units Figure7. XL6005 System Parameters Test Circuit (24V ~ 11 x 3W LED) Rev 1.5 www.xlsemi.com 7 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Typical System Application for VIN>=12V to driver 11 series x 40 parallel White LED Array Figure8. XL6005 System Parameters Test Circuit (12V ~ 11 x 40 White LED) Typical System Application for SEPIC Buck-Boost LED Driver Figure9. XL6005 System Parameters Test Circuit (Buck-Boost LED Driver) Rev 1.5 www.xlsemi.com 8 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Typical System Application for VIN>=12V to driver 6 x 3W series LED units With Dimming Function Figure10. XL6005 System Parameters Test Circuit (12V ~ 6 x 3W LED with Dimming Function) Rev 1.5 www.xlsemi.com 9 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Package Information TO252-5L Rev 1.5 www.xlsemi.com 10
XL6005E1 价格&库存
很抱歉,暂时无法提供与“XL6005E1”相匹配的价格&库存,您可以联系我们找货
XL6005E1
  • 1+3.35500
  • 100+2.58500
  • 1250+2.25500
  • 2500+2.13400
库存:2601
XL6005E1
    • 1+2.98010
    库存:17
    XL6005E1
    • 1+3.92000
    • 10+3.17520
    • 30+2.80280
    • 100+2.43040
    库存:226
    XL6005E1
    • 1+2.20990
    库存:73
    XL6005E1
    • 50+2.07171
    • 500+2.03616
    库存:37
    XL6005E1
    • 2500+1.87000
    库存:10000
