0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors
DF37 Series
■Further reduction of the board space.
●Comparison of board mounting space
2.98mm
DF37
8.22mm
Fig.1
■Features
Header
1. Reduced size and board-occupied area
With the mated height of 0.98/1.5mm, width of
2.98mm and length of 8.22mm (30 positions) the
connectors are one of the smallest in its class. Also
2.6mm depth short-lead type is available. (Fig.1)
Sufficiently large flat areas allow pick-up with
vacuum nozzles of automatic placement
equipment.
2. Reliable electrical and mechanical
connection
Despite its small mated height, unique contact
configuration, with a 2-point contacts and effective
mating length of 0.25mm, assures highly reliable
connection while confirming a complete mating with
a definite tactile feel.
0.98
Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF30
4.56mm
30 positions, 0.4 mm pitch, 0.98 mm height
Receptacle
Lock
Fig.2
●Splatter protection
Contact areas
3. Self alignment
Recognizing the difficulties of mating extremely small
connectors in limited spaces, the connectors will selfalign within 0.3mm.
4. Physical shock and vibration protection
2-point contact assures electrical connection in a
shock or vibration applications. (Fig.2)
5. Solder wicking prevention
Nickel barriers (receptacles) and unique forming of the
contacts (headers) prevent un-intentional solder
wicking.
Contact areas are not exposed to the outside
penetration of the flux or other physical particles.
Contact areas
6. Contamination protection
Insulator walls protect the contact areas against flux
splatter or other physical particles contamination. (Fig.3)
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2016.8④
1
DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors
■Product Specifications
Current rating
0.3A
Voltage rating
30V AC, DC
Operating
-35°C to +85°C (Note 1)
temperature range
Operating
RH 20% to 80%
humidity range
Ratings
Item
Specification
1.Insulation resistance 50Mø min
2.Withstanding voltage No flashover or insulation breakdown
3.Contact resistance
100mø max.
No electrical discontinuity of 1μs or longer
4.Vibration
No damage or parts dislocation
Contact resistance : 100mø max.,
5.Humidity
Insulation resistance : 25Mø min.
Insulation resistance : 50Mø min.
6.Temperature cycle
7.Durability
No deformation of components affecting
8.Resistance to
performance
soldering heat
Storage
-10°C to +60°C (Note 2)
temperature range
Storage
RH 40% to 70% (Note 2)
humidity range
Conditions
100V DC
100V AC / 1minute
20mV AC, 1kHz, 1mA
Frequency : 10 to 55 Hz, single amplitude of 0.75
mm, 2 hours, 3 axis
96 hours at 40 ±2°C and humidity of 90 to 95%
-55°C ➝ 5 to 35°C ➝ 85°C ➝ 5 to 35°C
Time: 30 min. ➝ 10 min. ➝ 30 min. ➝ 10 min.
5 cycles
10 cycles
Reflow : At the recommended temperature profile
Manual soldering : 350°C for 3 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use.
The operating temperature and humidity range covers the non-conducting condition of connectors after
board mounting and the temporary storage conditions of transportation, etc.
■Materials / Finish
Receptacle
Part
Material
Finish
Remarks
Insulator
LCP
Color: Black
UL94V-0
Header
Part
Material
Finish
Remarks
Contacts
Phosphor bronze
Gold plated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacles
DF 37 # - (**) - * DS - 0.4 V (**)
1
1 Series name
2 Configuration
2
3
4
6
7
8
5 Connector style
: DF37
DS : Receptacle
6 Contact pitch : 0.4mm
7 Terminal type V : SMT vertical mount
NB : With metal fittings
NC : Without metal fittings
SB : Short-lead type with metal fittings
3 Stacking height
8 Packaging
(51) Stacking height 0.98mm : Embossed tape packaging (8,000 pcs/reel)
Blank : 0.98mm, 1.5 : 1.5mm
4 Number of contacts
●Headers
5
(51) Stacking height 1.5mm : Embossed tape packaging (5,000 pcs/reel)
(53) : Embossed tape packaging (1,000 pcs/reel)
DF 37 # - * DP - 0.4 V (**)
1
1 Series name
2 Configuration
: DF37
3 Number of contacts
2
3
4
5
6
7
4 Connector style
DP : Header
5 Contact pitch : 0.4mm
6 Terminal type V : SMT vertical mount
7 Packaging
(51) : Embossed tape packaging (8,000 pcs/reel)
Note : The short-lead type is only available for the receptacle side (with hardware).
2
A
B
■Receptacles(Stacking Height=0.98mm)
Vacuum pick-up area : C
0.15
0.08
0.98
2.98
2.32
P=0.4
BRecommended metal mask dimensions
D -0.05
B±0.02
0.23±0.01
BRecommended PCB mounting pattern
B±0.02
P=0.4±0.02
3.28 +0.05
P=0.4±0.02
E +0.05
D -0.05
B±0.02
2.28±0.01
3.28±0.01
0.23±0.01
With metal fittings
B±0.02
P=0.4±0.02
3.28±0.01
2.28±0.01
P=0.4±0.02
E +0.05
With metal fittings
3.28 +0.05
0.96
(With metal fittings only)
0.23±0.02
0.23±0.02
●With metal fittings
Part No.
DF37NB-10DS-0.4V(51)
DF37NB-16DS-0.4V(51)
DF37NB-20DS-0.4V(51)
DF37NB-24DS-0.4V(51)
DF37NB-30DS-0.4V(51)
DF37NB-34DS-0.4V(51)
DF37NB-40DS-0.4V(51)
DF37NB-44DS-0.4V(51)
DF37NB-50DS-0.4V(51)
DF37NB-60DS-0.4V(51)
DF37NB-70DS-0.4V(51)
Unit : mm
HRS No.
684-3301-6 51
684-3302-9 51
684-3303-1 51
684-3304-4 51
684-3305-7 51
684-3082-4 51
684-3306-0 51
684-3407-7 51
684-3307-2 51
684-3308-5 51
684-3409-2 51
No. of Contacts
10
16
30
34
40
44
50
60
70
A
4.22
5.42
6.22
7.02
8.22
9.02
10.22
11.02
12.22
14.22
16.22
B
1.6
2.8
3.6
4.4
5.6
6.4
7.6
8.4
9.6
11.6
13.6
HRS No.
684-3309-8 51
684-3310-7 51
684-3311-0 51
684-3312-2 51
684-3313-5 51
684-3083-7 51
684-3314-8 51
684-3324-1 51
684-3315-0 51
684-3316-3 51
684-3084-0 51
No. of Contacts
10
16
30
34
40
44
50
60
70
A
4.22
5.42
6.22
7.02
8.22
9.02
10.22
11.02
12.22
14.22
16.22
B
1.6
2.8
3.6
4.4
5.6
6.4
7.6
8.4
9.6
11.6
13.6
●Without metal fittings
Part No.
DF37NC-10DS-0.4V(51)
DF37NC-16DS-0.4V(51)
DF37NC-20DS-0.4V(51)
DF37NC-24DS-0.4V(51)
DF37NC-30DS-0.4V(51)
DF37NC-34DS-0.4V(51)
DF37NC-40DS-0.4V(51)
DF37NC-44DS-0.4V(51)
DF37NC-50DS-0.4V(51)
DF37NC-60DS-0.4V(51)
DF37NC-70DS-0.4V(51)
C
0.8
1.2
1.6
2
2.4
2.8
3.2
3.6
D
3.7
4.9
5.7
6.5
7.7
8.5
9.7
10.5
11.7
13.7
15.7
E
4.46
5.66
6.46
7.26
8.46
9.26
10.46
11.26
12.46
14.46
16.46
Unit : mm
C
0.8
1.2
1.6
2
2.4
2.8
3.2
3.6
Note 1 : Tape and reel packaging (8,000 pcs/reel). Order by number of reels.
Note 2 : This connector is NOT polarized.
3
A
B
■Receptacles(Stacking Height=1.5mm)
2.98
2.32
P=0.4
1.5
0.08
0.15
0.96
(With metal fitting only)
D -0.05
B±0.02
0.23±0.01
B±0.02
P=0.4±0.02
3.28 +0.05
3.28 +0.05
P=0.4±0.02
E +0.05
D -0.05
B±0.02
2.28±0.01
3.28±0.01
0.23±0.01
With metal fittings
B±0.02
P=0.4±0.02
3.28±0.01
2.28±0.01
P=0.4±0.02
E +0.05
With metal fittings
0.23±0.02
0.23±0.02
Unit : mm
Part No.
HRS No.
DF37NB(1.5)-24DS-0.4V(51) 684-3602-2 51
No. of Contacts
24
A
7.02
B
4.4
No. of Contacts
24
30
34
40
50
60
70
A
7.02
8.22
9.02
10.22
12.22
14.22
16.22
B
4.4
5.6
6.4
7.6
9.6
11.6
13.6
Part No.
DF37NC(1.5)-24DS-0.4V(51)
DF37NC(1.5)-30DS-0.4V(51)
DF37NC(1.5)-34DS-0.4V(51)
DF37NC(1.5)-40DS-0.4V(51)
DF37NC(1.5)-50DS-0.4V(51)
DF37NC(1.5)-60DS-0.4V(51)
DF37NC(1.5)-70DS-0.4V(51)
Unit : mm
HRS No.
684-3603-5 51
684-3604-8 51
684-3618-0 51
684-3606-3 51
684-3610-0 51
684-3613-9 51
684-3614-1 51
Note 1 : Tape and reel packaging (5,000 pcs/reel). Order by number of reels.
4
C
2
C
2
2.4
2.8
3.2
3.6
D
6.5
E
7.26
A
■Receptacles(DF37SB)
2.6
B
A
2.32
P=0.4
0.08
0.96
E +0.05
D -0.05
B±0.02
3±0.01
1.84±0.01
P=0.4±0.02
0.23±0.01
1.1+0.05
E +0.05
D -0.05
B±0.02
P=0.4±0.02
2.9 +0.05
0.98
0.15
0.23±0.02
Part No.
DF37SB-20DS-0.4V(51)
DF37SB-24DS-0.4V(51)
DF37SB-30DS-0.4V(51)
DF37SB-34DS-0.4V(51)
DF37SB-40DS-0.4V(51)
DF37SB-50DS-0.4V(51)
Unit : mm
HRS No.
684-3502-8 51
684-3503-0 51
684-3504-3 51
684-3505-6 51
684-3506-9 51
684-3507-1 51
No. of Contacts
30
34
40
50
A
6.22
7.02
8.22
9.02
10.22
12.22
B
3.6
4.4
5.6
6.4
7.6
9.6
C
1.6
2
2.4
2.8
D
5.7
6.5
7.7
8.5
9.7
11.7
E
6.46
7.26
8.46
9.26
10.46
12.46
5
■Headers
A
B
1.98
1.46
P=0.4
0.58
0.08
0.76
0.15
B±0.02
P=0.4±0.02
2.28±0.01
1.26±0.01
2.28±0.01
1.26±0.01
0.68 +0.05
E +0.05
D-0.05
B±0.02
P=0.4±0.02
With metal fittings
0.23±0.02
0.23±0.02
B±0.02
P=0.4±0.02
2.28 +0.05
0.68+0.05
E +0.05
D-0.05
B±0.02
P=0.4±0.02
2.28 +0.05
With metal fittings
0.23±0.02
0.23±0.02
Part No.
DF37B-10DP-0.4V(51)
DF37B-16DP-0.4V(51)
DF37B-20DP-0.4V(51)
DF37B-24DP-0.4V(51)
DF37B-30DP-0.4V(51)
DF37B-34DP-0.4V(51)
DF37B-40DP-0.4V(51)
DF37B-44DP-0.4V(51)
DF37B-50DP-0.4V(51)
DF37B-60DP-0.4V(51)
DF37B-70DP-0.4V(51)
Unit : mm
HRS No.
684-3037-0 51
684-3057-7 51
684-3008-1 51
684-3009-4 51
684-3010-3 51
684-3064-2 51
684-3011-6 51
684-3408-0 51
684-3012-9 51
684-3013-1 51
684-3014-4 51
No. of Contacts
10
16
30
34
40
44
50
60
70
A
3.14
4.34
5.17
5.94
7.14
7.94
9.14
9.94
11.14
13.14
15.14
B
1.6
2.8
3.6
4.4
5.6
6.4
7.6
8.4
9.6
11.6
13.6
HRS No.
684-3039-5 51
684-3058-0 51
684-3024-8 51
684-3025-0 51
684-3026-3 51
684-3085-2 51
684-3027-6 51
684-3089-3 51
684-3028-9 51
684-3029-1 51
684-3030-0 51
No. of Contacts
10
16
30
34
40
44
50
60
70
A
3.14
4.34
5.17
5.94
7.14
7.94
9.14
9.94
11.14
13.14
15.14
B
1.6
2.8
3.6
4.4
5.6
6.4
7.6
8.4
9.6
11.6
13.6
Part No.
DF37C-10DP-0.4V(51)
DF37C-16DP-0.4V(51)
DF37C-20DP-0.4V(51)
DF37C-24DP-0.4V(51)
DF37C-30DP-0.4V(51)
DF37C-34DP-0.4V(51)
DF37C-40DP-0.4V(51)
DF37C-44DP-0.4V(51)
DF37C-50DP-0.4V(51)
DF37C-60DP-0.4V(51)
DF37C-70DP-0.4V(51)
2
2.4
2.8
3.2
3.6
Unit : mm
6
C
0.8
1.2
1.6
C
0.8
1.2
1.6
2
2.4
2.8
3.2
3.6
D
2.62
3.82
4.62
5.42
6.62
7.42
8.62
9.42
10.62
12.62
14.62
E
3.38
4.58
5.38
6.18
7.38
8.18
9.38
10.18
11.38
13.38
15.38
BEmbossed Carrier Tape Dimensions
Ø1
1
0.
+ 0
.5
8±0.1
2±0.1 4±0.1
F
1.75±0.1
●Receptacle (less than 70 positions)
F-F
Unit : mm
E±0.15
0.3±0.1
Part No.
A
DF37#(1.5)-24DS-0.4V(51) 7.5
B
16
C
D
17.5 21.5
E
24
25.5 29.5 1.75
32
33.5 37.5
DF37#(1.5)-30DS-0.4V(51)
A±0.1
DF37#(1.5)-34DS-0.4V(51)
DF37#(1.5)-40DS-0.4V(51) 11.5
B±0.3
DF37#(1.5)-60DS-0.4V(51)
DF37#(1.5)-70DS-0.4V(51) 14.2
# : NB or NC
G
F
G
G-G
Unreeling direction
8±0.1
2±0.1 4±0.1
.1
+00
5
F-F
E±0.15
0.3±0.1
28.4±0.1
B±0.3
A±0.1
F
1.75±0.1
●Receptacle (70 positions)
Ø1.
G
G
G-G
F
Unreeling direction
Unit : mm
●Reel Dimensions
Unreeling direction
DF37#-16DS-0.4V(51)
DF37#-20DS-0.4V(51)
A
B
7.5
16
C
D
E
17.5 21.5
Ø80±1
DF37#-24DS-0.4V(51)
Ø380±2
Part Number Label
3±
Part No.
DF37#-10DS-0.4V(51)
Ø1
DF37#(1.5)-50DS-0.4V(51)
DF37#-30DS-0.4V(51)
DF37#-34DS-0.4V(51)
DF37#-40DS-0.4V(51)
1.23
11.5
24
25.5 29.5
C±0.5
DF37#-60DS-0.4V(51)
D±1
DF37#-70DS-0.4V(51) 14.2
32
33.5 37.5
DF37#-44DS-0.4V(51)
DF37#-50DS-0.4V(51)
# : NB or NC, SB
7
E
A±0.1
.1
+00
2±0.1 4±0.1
F
F
E-E
1±0.15
0.3±0.1
B±0.3
5
Ø1.
8±0.1
1.75±0.1
●Header
E
Unreeling direction
F-F
Unit : mm
Unreeling direction
Ø80±1
Ø380±2
Ø1
3±
Part Number Label
0.2
●Reel Dimensions
C±0.5
D±1
8
Part No.
A
DF37#-10DP-0.4V(51) 5.5
DF37#-16DP-0.4V(51)
DF37#-20DP-0.4V(51) 7.5
DF37#-24DP-0.4V(51)
DF37#-30DP-0.4V(51)
DF37#-34DP-0.4V(51)
DF37#-40DP-0.4V(51)
DF37#-44DP-0.4V(51) 11.5
DF37#-50DP-0.4V(51)
DF37#-60DP-0.4V(51)
DF37#-70DP-0.4V(51)
B
12
C
13.5
D
17.5
16
17.5
21.5
24
25.5
29.5
# : B, C
BUsage Recommendations
1.Recommended temperature
profile
Temperature (ç)
250ç
250
220ç
200
60sec max
180ç
150
150ç
90~120sec
100
50
Room temperature
100
150
200
250
300
Time (sec.)
Note 1: Up to 2 cycles of Reflow soldering are possible under the
same conditions, provided that there is a return to normal
temperature between the first and second cycle.
Note 2: The temperature profile indicates the board surface
temperature at the point of contacts with the connector
terminals.
2.Recommended manual soldering
3.Recommended screen thickness and
open area ratio (Pattern area ratio)
4.Board warpage
Manual soldering : 340±10ç for 3 seconds
Thickness : 0.12mm
Open area ratio : Receptacle:80%(NB/NC), Plug : 70%
Maximum of 0.02mm at the connector center, with both ends of the
connector as reference points.
5.Cleaning conditions
Cleaning is not recommended. When cleaning, please evaluate as it
can deteriorate the performance including mechanical operation and
environmental resistance.
6.Precautions
■ Mating and un-mating of the connectors when not soldered on the
boards is not recommended as this may cause deformation of the
terminals, damage to the contacts or insulators.
■ Mated connectors should not carry weight of the board by
themselves. Provide some other support of the boards.
■ When mating/un-mating do not twist or lift by the corners. Apply the
forces evenly across the entire length and width of the connectors
taking care NOT to damage or deform soldered terminations.
■ Exercise extreme caution when mating/ un-mating when the
connector is mounted on a nonrigid (flexible) substrate.
Slight discoloration on the insulating materials will not affect form, fit
or function of the connectors.
■ Do NOT pull on the flexible substrate.
9
BHandling Precautions when Mating Connectors
Keep the connectors parallel to each other
when positioning. The connectors will selfalign in horizontal directions.
Do not attempt to mate the connectors starting
at one end or side.
Press-down even until fully mated.
10
BHandling Precautions When Un-mating Connectors
Lift even, keeping both connectors parallel to
each other
When handling, circumstances may prevent
the connectors from being kept parallel when
un-mating. One end may be lifted as shown.
However, to use this procedure the connector
must be mounted on sufficiently rigid circuit
board.
Any deflection of the board dur ing this
operation may result in damage to the
connector or solder joints.
Do not attempt to start the un-mating of the
connectors from one side or corner.
Failure to exercise caution when un-mating
the connectors mounted on the non-rigid FPC
may also result in connector breakage.
It is the responsibility of the user to perform
verification of the repeated mating / un-mating
cycles with the connectors mounted on the
applicable FPC.
When the rigidity of the FPC is low, there is a
r isk that the connector could break as
illustrated in the diagram at left.
Please use the connectors after performing a
check of repeated operation with the FPC that
the customer will be using.
Evaluative results of FPC rigidity and various
items are available. Please inquire.
11
Powered by TCPDF (www.tcpdf.org)
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
Regus La Garenne Colombes,Place de La Belgique,
71 Boulevard National La Garenne Colombes, 92250, France
Phone : +33 (0) 1 7082 3170
Fax : +33 (1) 7082 3101
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
1601, Henderson Metropolitan, NO.300, East Nanjing
Road, Huangpu District, Shanghai, China 200001
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
250, Huimanggongwon-ro, Siheung-si,
Gyeonggi-do, Korea, 15083
Phone : +82-31-496-7000 or 7124
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
10 Anson Road #26-16, International Plaza Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
079903, Singapore
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
MALAYSIA:
PENANG REPRESENTATIVE OFFICE
1-21-01, Suntech @ Penang Cybercity (1164), Lintang
Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia.
Phone : +604-619-2564
Fax : +604-619-2574
12
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
THAILAND:
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Phone : +66-2-686-1255
Fax : +66-2-686-3433
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 08/2016. Contents are subject to change without notice for the purpose of improvements.
