WNM2020
WNM2020
Http://www.sh-willsemi.com
N-Channel, 20V, 0.90A, Small Signal MOSFET
VDS (V)
Rds(on) (ȍ)
D
0.220@ VGS=4.5V
0.260@ VGS=2.5V
S
0.320@ VGS=1.8V
G
SOT-23
Descriptions
The WNM2020 is N-Channel enhancement MOS
Field Effect Transistor. Uses advanced trench
technology and design to provide excellent RDS (ON)
D
3
with low gate charge. This device is suitable for use
in DC-DC conversion, power switch and charging
circuit. Standard Product WNM2020 is Pb-free and
Halogen-free.
1
G
2
S
Features
Pin configuration (Top view)
z
Trench Technology
z
Supper high density cell design
z
Excellent ON resistance
z
Extremely Low Threshold Voltage
z
Small package SOT-23
3
W28*
2
1
W28 = Device Code
Applications
= Month (A~Z)
Marking
Order information
z
DC-DC converter circuit
z
Small Signal Switch
z
Load Switch
z
Level Shift
Device
Package
Shipping
WNM2020-3/TR
SOT-23
3000/Reel&Tape
z
Will Semiconductor Ltd.
1
2015/08/25 – Rev. 1.5
WNM2020
Absolute Maximum ratings
Parameter
Symbol
10 S
Steady State
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
±6
Continuous Drain Current a
Maximum Power Dissipation a
Continuous Drain Current b
Maximum Power Dissipation b
TA=25°C
TA=70°C
TA=25°C
TA=70°C
TA=25°C
TA=70°C
TA=25°C
TA=70°C
ID
PD
ID
PD
Unit
V
0.90
0.83
0.72
0.66
0.38
0.32
0.24
0.20
0.79
0.71
0.63
0.57
0.29
0.24
0.19
0.15
A
W
A
W
Pulsed Drain Current c
IDM
1.4
A
Operating Junction Temperature
TJ
-55 to 150
°C
Lead Temperature
TL
260
°C
Storage Temperature Range
Tstg
-55 to 150
°C
Thermal resistance ratings
Parameter
Junction-to-Ambient Thermal Resistance a
Junction-to-Ambient Thermal Resistance b
Junction-to-Case Thermal Resistance
Symbol
t 10 s
Steady State
t 10 s
Steady State
Steady State
RșJA
RșJA
RșJC
Typical
Maximum
270
325
320
385
360
420
425
520
260
300
a
Surface mounted on FR4 Board using 1 square inch pad size, 1oz copper
b
Surface mounted on FR4 board using minimum pad size, 1oz copper
c
Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1%
d
Repetitive rating, pulse width limited by junction temperature TJ=150°C.
2
Unit
°C/W
WNM2020
Electronics Characteristics (Ta=25oC, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
OFF CHARACTERISTICS
Drain-to-Source Breakdown Voltage
BVDSS
VGS = 0 V, ID = 250uA
Zero Gate Voltage Drain Current
IDSS
VDS =16 V, VGS
Gate-to-source Leakage Current
IGSS
VDS = 0 V, VGS =±5V
VGS(TH)
VGS = VDS, ID = 250uA
V
=0V
1
uA
±5
uA
0.58
0.85
V
VGS = 4.5V, ID = 0.55A
220
310
VGS = 2.5V, ID = 0.45A
260
360
VGS = 1.8V, ID = 0.35A
320
460
VDS = 5 V, ID = 0.55A
2.0
ON CHARACTERISTICS
Gate Threshold Voltage
Drain-to-source On-resistance
Forward Transconductance
RDS(on)
gFS
0.45
m
S
CHARGES, CAPACITANCES AND GATE RESISTANCE
Input Capacitance
CISS
50
Output Capacitance
COSS
Reverse Transfer Capacitance
CRSS
Total Gate Charge
QG(TOT)
Threshold Gate Charge
QG(TH)
VGS = 4.5 V, VDS = 10 V,
0.06
Gate-to-Source Charge
QGS
ID = 0.55A
0.15
Gate-to-Drain Charge
QGD
VGS = 0 V, f = 100 kHz, VDS =
pF
13
10 V
8
1.15
nC
0.23
SWITCHING CHARACTERISTICS
Turn-On Delay Time
td(ON)
22
Rise Time
tr
VDD=10V,
Turn-Off Delay Time
td(OFF)
ID =0.55A, RG=6Ω
Fall Time
tf
80
VGS=4.5V,
ns
700
380
BODY DIODE CHARACTERISTICS
Forward Voltage
VSD
VGS = 0 V, IS = 0.35A
3
0.5
0.7
1.5
V
WNM2020
Typical Characteristics (Ta=25oC, unless otherwise noted)
2.0
VGS= 2.5V ~5.0V
IDS-Drain to Source Current(A)
IDS-Drain-to-Source Current (A)
4
VGS=2.0V
3
2
VGS=1.5V
1
0.4
0.8
1.2
1.6
VDS=5V
1.6
o
T=-50 C
1.2
o
T=25 C
o
T=125 C
0.8
0.4
0.0
0.0
2.0
0.4
Output characteristics
1.6
2.0
1600
350
RDS(on)- On-Resistance (m:)
RDS(on)- On-Resistance(m:)
1.2
Transfer characteristics
400
VGS=1.8V
300
250
VGS=2.5V
200
VGS=4.5V
150
100
0.4
0.8
1.2
1.6
1200
800
400
2.0
1.0
IDS-Drain-to-Source Current(A)
1.5
2.0
2.5
3.0
3.5
4.0
4.5
VGS-Gate-to-Source Voltage(V)
On-Resistance vs. Drain current
On-Resistance vs. Gate-to-Source voltage
320
0.8
VGS(TH) Gate Threshold Voltage (V)
VGS=4.5V, ID=0.55A
0.8
VDS-Drain-to-Source Voltage(V)
280
240
200
160
120
-50
-25
0.6
0.5
0.4
0.3
0.2
-50
25
50
75 100 125 150
o
Temperature( C)
On-Resistance vs. Junction temperature
ID=250uA
-25
50
75 100 125 150
o
Temperature ( C)
Threshold voltage vs. Temperature
4
WNM2020
60
0.8
F=100kHz
50
C - Capacitance(pF)
ISD-Source to Drain Current(A)
VGS=0V
40
Ciss
Coss
Crss
30
4
6
8
10
0.6
o
T=150 C
o
0.4
T=25 C
0.2
0.1
0.2
VDS Drain-to-Source Voltage (V)
Capacitance
0.3 0.4 0.5 0.6 0.7 0.8
VSD-Source-to-Drain Voltage(V)
0.9
Body diode forward voltage
ID - Drain Current (A)
10
1
10 ms
100 ms
0.1
Limited by RDS(on)
1s
10 s
DC
0.01
TA = 25 °C
Single Pulse
0.001
0.1
1
10
VDS - Drain-to-Source Voltage (V)
100
Safe operating power
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
Notes:
0.1
PDM
0.1
0.05
t1
t2
1. Duty Cycle, D =
0.02
t1
t2
2. Per Unit Base = RthJA = 320 °C/W
3. TJM - TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10-4
10-3
10-2
10-1
1
Square Wave Pulse Duration (s)
10
100
600
Transient thermal response (Junction-to-Ambient)
5
WNM2020
Package outline dimensions
SOT-23
Symbol
Dimensions in millimeter
Min.
Typ.
Max.
A
0.900
1.025
1.150
A1
0.000
0.050
0.100
A2
0.900
0.975
1.050
b
0.300
0.400
0.500
c
0.080
0.115
0.150
D
2.800
2.900
3.000
E
1.200
1.300
1.400
E1
2.250
2.400
2.550
1.900
2.000
e
e1
0.950TYP
1.800
L
0.550REF
L1
0.300
0.500
0e
8e
6
很抱歉,暂时无法提供与“WNM2020-3/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.31790
- 200+0.20460
- 1500+0.17820
- 3000+0.15840
- 国内价格
- 20+0.36310
- 200+0.29830
- 600+0.25132
- 2000+0.21255
