SY8104I
High Efficiency, Fast Response, 4.0A, 18V Input
Synchronous Step Down Regulator
General Description
Features
The SY8104I is a high efficiency 500kHz
synchronous step-down DC/DC regulator, which is
capable of delivering up to 4A load current. It can
operate over a wide input voltage range from 4.2V to
18V and integrate main switch and synchronous
switch with very low RDS(ON) to minimize the
conduction loss.
The SY8104I adopts the instant PWM architecture to
achieve fast transient responses for high step down
applications and high efficiency at light loads. In
addition, it operates at pseudo-constant frequency of
500kHz to minimize the size of inductor and
capacitor.
Ordering Information
Low RDS(ON) for Internal Switches
(Top/Bottom): 55mΩ/36mΩ
4.2-18V Input Voltage Range
4A Output Current Capability
500kHz Switching Frequency Minimize the
External Components
Stable with 22µF COUT and 0.68µH Inductor
Instant PWM Architecture to Achieve Fast
Transient Responses
Internal Soft-Start Limits the Inrush Current
Cycle-by-cycle Peak/Valley Current Limitation
Hic-cup Mode Output Short Circuit Protection
Thermal Shutdown with Auto Recovery
Output Auto Discharge Function
Compact Package: TSOT23-6
Applications
SY8104 □(□□)□
Temperature Code
Package Code
Optional Spec Code
Ordering Number
SY8104IADC
Package type
TSOT23-6
Note
Set Top Box
Portable TV
DSL Modem
LCD TV
IP CAM
Networking
Typical Application
Efficiency vs. Output Current
CBS 100nF
100
L 3.9µH
BS
IN
SY8104I
CIN
10µF
95
VOUT : 3.3V
LX
EN
FB
GND
90
RH
100k
CFF
100pF
RL
22.1k
Figure1. Schematic Diagram
COUT
22µF
Efficiency (%)
VIN : 4.2~18V
85
80
75
70
VIN=5V,VOUT=3.3V
Inductor and COUT Selection Table
COUT [µF]
L
[µH]
4.7
10
22
2×22
0.68
1.2
2.0
1.5
3.3
3.9
2.2
5
4.7
Note: ‘☆ ’ means recommended for most applications.
VOUT
[V]
SY8104I Rev0.9B
© 2018 Silergy Corp.
VIN=12V,VOUT=3.3V
65
VIN=18V,VOUT=3.3V
60
0.01
0.1
1
10
Output Current (A)
Figure2. Efficiency vs. Output Current
Silergy Corp. Confidential- Prepared for Customer Use Only
1
All Rights Reserved.
SY8104I
Pinout (top view)
FB
1
6
BS
EN
2
5
LX
GND
3
4
IN
(TSOT23-6)
Top mark: dLxyz (Device code: dL, x=year code, y=week code, z= lot number code)
Pin Name
Pin Number
FB
1
EN
2
Pin Description
Feedback pin. Connect this pin to the center point of the output resistor divider (as
shown in Figure 1) to program the output voltage: VOUT=0.6×(1+RH/RL).
Enable control pin. Pull high to turn on. Do not leave it floating.
GND
3
Power ground pin.
IN
4
LX
5
BS
6
Input pin. Decouple this pin to the GND pin with at least a 10µF ceramic
capacitor.
Inductor pin. Connect this pin to the switching node of inductor.
Boot-strap pin. Supply high side gate driver. Connect a 0.1µF ceramic capacitor
between BS and LX pin.
Block Diagram
IN
Current Sense
Internal
Power
BS
Input
UVLO
4.15V
PWM
Control &
Protect
Logic
EN
1.2V
FB
LX
Current Sense
0.6V
Internal
SST
Thermal
Protection
GND
Figure3. Block Diagram
SY8104I Rev0.9B
2
SY8104I
Absolute Maximum Ratings (Note 1)
Supply Input Voltage ------------------------------------------------------------------------------------------------ -0.3V to 19V
LX, EN Voltage----------------------------------------------------------------------------------------------- -0.3V to VIN + 0.3V
FB, BS-LX Voltage---------------------------------------------------------------------------------------------------- -0.3V to 4V
Power Dissipation, PD @ TA = 25°C TSOT23-6, ----------------------------------------------------------------------- 2.0W
Package Thermal Resistance (Note 2)
θ JA ------------------------------------------------------------------------------------------------------- 50°C/W
θ JC ------------------------------------------------------------------------------------------------------- 6.3°C/W
Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 150°C
Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C
Storage Temperature Range -------------------------------------------------------------------------------------- -65°C to 150°C
Dynamic LX Voltage in 10ns Duration (Note3) ---------------------------------------------------------- IN+3V to GND-5V
Recommended Operating Conditions (Note 3)
Supply Input Voltage -------------------------------------------------------------------------------------------------- 4.2V to 18V
Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range -------------------------------------------------------------------------------------- -40°C to 85°C
SY8104I Rev0.9B
3
SY8104I
Electrical Characteristics
(VIN = 12V, VOUT = 3.3V, L = 3.9µH, COUT = 22µF, TA = 25°C, IOUT = 1A unless otherwise specified)
Parameter
Input Voltage Range
Input UVLO Threshold
Input UVLO Hysteresis
Quiescent Current
Shutdown Current
Feedback Reference Voltage
FB Input Current
Output Discharge Resistance
Top FET RON
Bottom FET RON
EN Rising Threshold
EN Falling Threshold
Min ON Time
Min OFF Time
Turn On Delay
Soft-start Time
Switching Frequency
Symbol
VIN
VUVLO
VHYS
IQ
ISHDN
VREF
IFB
RDIS
RDS(ON)1
RDS(ON)2
VEN,R
VEN,F
tON,MIN
tOFF,MIN
tON,DLY
tSS
FSW
Top FET Current Limit
ILIM,TOP
Bottom FET Current Limit
Output Under Voltage
Protection Threshold
Output UVP Delay
UVP Hiccup ON Time
UVP Hiccup OFF Time
Thermal Shutdown
Temperature
Thermal Shutdown Hysteresis
ILIM,BOT
Test Conditions
Min
4.2
IOUT=0, VFB=VREF×105%
EN=0
VFB=3.3V
591
-50
1.08
0.9
from EN high to LX start switching
VOUT from 0 to 100%
VOUT=3.3V, CCM
1
Typ
0.3
200
5
600
50
55
36
1.2
1.0
50
100
0.5
1.7
500
Max
18
4.15
280
10
609
50
105
55
1.32
1.1
2.4
Unit
V
V
V
µA
µA
mV
nA
Ω
mΩ
mΩ
V
V
ns
ns
ms
ms
kHz
5.5
A
4
A
VUVP
0.33
VREF
tUVP,DLY
tUVP,ON
tUVP,OFF
100
2.5
9
µs
ms
ms
TSD
150
˚C
THYS
15
˚C
Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are
stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for
extended periods may affect device reliability.
Note 2: θ JA is measured in the natural convection at T A = 25°C on a 2OZ four-layer Silergy evaluation board.
Paddle of TSOT23-6 package is the case position for SY8104I θ JC measurement.
Note 3: The device is not guaranteed to function outside its operating conditions.
SY8104I Rev0.9B
4
SY8104I
TSOT23-6 Package Outline & PCB Layout
Top view
Side view
Front view
Recommended Pad Layout
Notes:
All dimensions in millimeter and exclude mold flash & metal burr.
SY8104I Rev0.9B
5
SY8104I
Taping & Reel Specification
1. Taping orientation
Feeding direction
2. Carrier Tape & Reel specification for packages
Reel
Size
Package types
Tape width
(mm)
Pocket
pitch(mm)
Reel size
(Inch)
Trailer
length(mm)
Leader length
(mm)
Qty per
reel
8
4
7
400
160
3000
TSOT23-6
3. Others: NA
SY8104I Rev0.9B
6
很抱歉,暂时无法提供与“SY8104IADC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.03800
- 30+2.92800
- 100+2.70800
- 500+2.48800
- 1000+2.37800
