KBP4005 thru KBP410
山东晶导微电子有限公司
Jingdao Microelectronics
REVERSE VOLTAGE - 50 to 1000 Volts
FORWARD CURRENT - 4.0 Amperes
GLASS PASSIVATED BRIDGE RECTIFIERS
KBP
FEATURES
Rating to 1000V PRV
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic
technique
The plastic material has UL flammability classification
94V#0
MECHANICAL DATA
Polarity : As marked on body
Weight : 0.05 ounces, 1.52 grams
Mounting position : Any
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
SYMBOL
KBP
4005
KBP
401
KBP
402
KBP
404
KBP
406
KBP
408
KBP
410
UNIT
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
600
800
1000
V
CHARACTERISTICS
Maximum DC Blocking Voltage
Maximum Average Forward Rectified
(With heatsink)
(Without heatsink)
Current @TC=105°C
Peak Forward Surge Current
@ Tj = 25 ℃
8.3ms single half sine-wave
@ Tj =25 ℃
1.0ms single half sine-wave
Maximum Forward Voltage at 4.0A DC
Maximum DC Reverse Current at rated
Blocking Voltage
@Tj=25°C
@Tj=125°C
2
I(AV)
4.0
2.0
A
IFSM
75
A
IFSM
150
A
VF
1.1
V
IR
5.0
500
uA
I t Rating for fusing (3ms≦t ≦8.3ms)
I t
2
26.5
A S
Typical Junction Capacitance per element (Note 1)
CJ
50
pF
RΘJC
RΘJL
RΘJA
RΘJC
RΘJL
RΘJA
10
12
30
12
18
40
TJ, TSTG
-55 to 150
Typical thermal resistance
(Unit mounted on 75mmx75mmx1.6mm Copper plate heatsink.)
Typical thermal resistance (without heatsink)
Operation and Storage Temperature Range
2
°C/W
°C/W
°C
Note : (1) Measured at 1.0MHz and applied reverse voltage of 4.0V DC.
1
Version: 0
KBP4005 thru KBP410
山东晶导微电子有限公司
FIG.1- FORWARD CURRENT DERATING CURVE
FIG.2- MAXIMUM NON-REPETITIVE SURGE
CURRENT
5
PEAK FORWARD SURGE CURRENT, (A)
AVERAGE FORWARD CURRENT, (A)
120
With heatsink_75*75*1.6 mm Copper plate
4.5
4
3.5
3
2.5
2
Without heatsink
1.5
1
0.5
RESISTIVE OR INDUCTIVE LOAD
100
80
60
40
Pulse width 8.3ms Single Half Sine-Wave
50
75
100
125
150
175
1
10
CASE TEMAERATURE, (°C)
FIG.3- TYPICAL JUNCTION CAPACITANCE
FIG.4- TYPICAL FORWORD CHARACTERISTICS
100
INSTANTANEOUS FORWARD CURRENT, (A)
100
10
Tj=25°C, f=1MHz
1
10
Tj=125°C
Tj=25°C
1
PULSE WIDTH 300us
0.1
1
10
100
0.4
REVERSE VOLTAGE, (V)
0.6
0.8
1
1.2
1.4
1.6
INSTANTANEOUS FORWARD VOLTAGE, (V)
FIG.5- TYPICAL REVERSE CHARACTERISTICS
1000
INSTANTANEOUS REVERSE CURRENT, (uA)
CAPACITANCE, (pF)
100
NUMBER OF CYCLES AT 60Hz
Tj=125°C
100
10
Tj=100°C
1
0.1
Tj=25°C
0.01
60
80
100
120
PERCENT OF RATED PEAK REVERSE VOLTAGE, (%)
2
Version: 0
山东晶导微电子有限公司
KBP4005 thru KBP410
KBP Package Outline Dimensions
KBP
MIN.
MAX.
A
14.25
14.75
B
3.35
3.65
C
10.20
10.60
D
14.25
14.73
d
1.40
1.70
E
1.80
2.20
DIM.
F
0.80
1.10
G
3.56
4.06
H
0.35
0.55
I
1.22
1.42
J
0.76
0.86
K
2.7 x 45° (Typ)
L
3°
M
2°
All Dimensions in millimeter
3
Version: 0
很抱歉,暂时无法提供与“KBP410”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.65780
- 50+0.43890
- 500+0.39600
- 国内价格
- 5+0.82422
- 50+0.63726
- 150+0.54378
- 500+0.47367
- 国内价格
- 5+0.73322
- 50+0.58763
- 150+0.51473
- 500+0.46008
- 2500+0.41645
- 5000+0.39453
