山东晶导微电子有限公司
US5AC THRU US5MC
Jingdao Microelectronics
Surface Mount Ultrafast Recovery Rectifier
Reverse Voltage – 50~1000 V
PINNING
Forward Current – 5 A
PIN
DESCRIPTION
1
Cathode
2
Anode
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
2
1
Top View
Marking Code: US5A~US5M
Simplified outline SMC symbol
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 217mg / 0.0077oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
Parameter
US5AC
US5BC
US5DC
US5GC
US5JC
US5KC
US5MC Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 100 °C
I F(AV)
5
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
120
A
Maximum Instantaneous Forward Voltage at 5 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Operating and Storage Temperature Range
1.3
1.65
V
IR
5
100
μA
Cj
50
pF
t rr
Typical Thermal Resistance (2)
1.0
50
75
ns
RθJA
35
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMC-U-US5AC~US5MC-5A1000V
Page 1 of 3
山东晶导微电子有限公司
US5AC THRU US5MC
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
20ns/div
Set time Base for 20ns/div
Fig.3 Typical Reverse Characteristics
7.0
300
6.0
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
5.0
4.0
3.0
2.0
1.0
50
75
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
T J =125°C
100
125
150
40
Case Temperature (°C)
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
80
100
Fig.5 Typical Junction Capacitance
Fig.4 Typical Forward Characteristics
T J =25°C
1.0
US5AC~US5DC
US5GC
0.1
60
% of PIV.VOLTS
US5JC~US5MC
0.01
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.001
1.0
1.5
0.1
Instaneous Forward Voltage (V)
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
US5AC THRU US5MC
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
Type number
Marking code
US5AC
US5A
US5BC
US5B
US5DC
US5D
US5GC
US5G
US5JC
US5J
US5KC
US5K
US5MC
US5M
mm
Unit :
(mil)
2017.01
JD702221B20
Page 3 of 3
很抱歉,暂时无法提供与“US5MC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40954
- 100+0.32789
- 300+0.28707
- 3000+0.25640
- 6000+0.23188
- 9000+0.21968
- 国内价格
- 10+0.38010
- 100+0.30310
- 300+0.26090
- 3000+0.23250
- 6000+0.20920
- 9000+0.19800
- 国内价格
- 10+0.37541
- 100+0.30056
- 600+0.26314
- 1200+0.25919
- 3000+0.23503
- 国内价格
- 1+0.37180
- 200+0.23980
- 1500+0.20900
- 3000+0.18480
- 国内价格
- 20+0.68940
- 100+0.41120
- 800+0.28780
- 3000+0.20560
- 6000+0.19540
- 30000+0.18090
