KJKF222M2FF7035A075E 数据手册
规格承认书
Specification for approval
客户名称:
(Customer Name)
产品名称:
Y2 安规电容
(Product Name)
客户料号:
(Customer part number)
科尼盛料号:
(KNSCHA number)
型号规格:
(Specifications)
拟 制
(Fiction)
Y2 222M/300VAC P=7.5mm Y5V
制 造
(Manufacture)
客
户
(Customer)
Approval
Approval
审 核
(Chief)
核
准
(Approval)
检 验
(Inspect)
审 核
(Chief)
东莞市科尼盛电子有限公司
DONG GUAN KNSCHA ELECTRONICS CO.,LTD.
No. 8th floor, A3 building, R&D center (Phase I),
Songshan Lake Intelligent Valley, Liaobu Town, Dongguan City.
TEL:0769-83698067 81035570
FAX: 0769-83861559
Email:sales@knscha.com Website: http://www.knscha.com
核
准
(Approval)
交流陶瓷电容器规格书
Specifications for a.c. ceramic capacitors
JK 系列 Y2 电容器
JK Series Y2 Capacitors
Edition A0
October 9,2015
BULANC DANRY
RoHS H.F.
REACH
ADD: No.2 Technology Rd. Chang An Tang Ind. Area Dongkeng Town DONGGUAN, GUANGDONG 523459 CHINA
修订履历 Revision history
版本
Edition
A0
修订时间
Revision time
June 11,2015
修订摘要
Revision content
首次制作 The first draft
2 of 18
www.ajc.com.hk
修订人
Revision People
BULANC DANRY
AJC-3-015 A0
June 11,2015
The certificates with seal are validity.
目录 Directory
封面 Cover.............................................................................................................. 1
修订履历 Revision history..................................................................................... 2
目录 Directory.........................................................................................................3
1. 范围 Scope......................................................................................................... 4
2. 目的 Object....................................................................................................... 4
3. 引用标准 Normative references.................................................................... 4-5
4. 术语和定义 Terms and definitions................................................................ 5-6
5. 编码说明 How to order..................................................................................... 6
6. 认证标准和档案号码 Approval standard and file number.............................. 6
7. 电容器结构图 The constituent parts of capacitor............................................ 7
8. 外型图及尺寸代码 Figure and code of dimension........................................... 7
9. 容量和尺寸表 Capacitance and dimension...................................................... 8
10. 温度特性曲线 Temperature characteristic of capacitor................................. 8
11. 环 境 管 理 物 质 含 量 控 制 要 求 Requirements for concentration limits for
certain hazardous substances.................................................................................. 9
12. 性能与试验 Performance and test...................................................................9
13. 标志图案 Marking design..............................................................................14
14. 包装 Packing.................................................................................................. 15
15. 贮存 Storage................................................................................................... 16
16. 敬告和警告 Cautions and warnings............................................................. 17
17. 交流陶瓷电容器常识 General knowledge for AC ceramic capacitors....... 17
3 of 18
www.ajc.com.hk
AJC-3-015 A0
June 11,2015
1. 范围 Scope
Y2 交流陶瓷电容器适用于工作电压不超过 1000VAC,频率不超过 100Hz 的电子电气
设 备 中 。 Y2 a.c ceramic capacitors are used in electrical and electronic equipment and
connected an a.c main with nominal voltage not exceeding 1000va.c, and with a nominal
frequency not exceeding 100Hz.
2. 目的 Object
规定 Y2 交流陶瓷电容器优先额定值和特性,试验和测量方法以及性能要求。The
principal object of this standard is to prescribe preferred ratings and characteristics and to
select the appropriate tests and measuring methods and to give general performance
requirements for Y2 a.c. ceramic capacitors.
IEC 60384-1:2008-07 Edition 4.0 (GB/T 2693-2001)
电子设备用固定电容器 第 1 部分 总规范
Fixed capacitors for use in electronic equipment-Part 1: Generic specification
IEC 60384-14:2013-06 Edition 4.0 (GB/T 14472-1998)
电子设备用固定电容器 第 14 部分 分规范 抑制电源电磁干扰用固定电容器
Fixed capacitors for use in electronic equipment-Part 14:Sectional specification
Fixed capacitors for electromagnetic interference suppression and connection to
the supply mains
GB/T 5169.5-1997 (IDT IEC 60695-2-2:1991)电工电子产品着火危险试验
第 2 部分:试验方法 第 2 篇:针焰试验
Fire hazard testing for electronic products Part 2: Test methods
Section 2: Needle-flame test
GB/T 2828.1-2003 (IDT ISO 2859-1:1999) 计数抽样检验程序
第 1 部分 按接受限(AQL)检索的逐批检验抽样计划
Sampling procedures for inspection by attributesPart 1: Sampling schemes indexed by acceptance quality limit(AQL)for
lot-by-lot inspection
GB/T 2471-1995 (IDT IEC 63:1963):电阻器和电容器优先数系
Preferred number series for resistors and capacitors
GB/T 2691-1994 (IDT IEC 62:1992):电阻器和电容器的标志代码
Marking codes for resistors and capacitors
GB/T 26572-2011:电子信息产品中有毒有害物质的限量要求
Requirements for concentration limits for certain hazardous substances in
electronic information products
SJ/T 11364-2006:电子信息产品污染控制标识要求
Marking for control of pollution caused by electronic information products
GB/T 26125-2011:电子信息产品中有毒有害物质的检测方法
Testing methods for hazardous substances in electronic information products
2011/65/EU (RoHS2.0):电子电气设备中限制使用某些有害物质指令
The Restriction of the use of certain Hazardous Substances in electrical and
4 of 18
www.ajc.com.hk
AJC-3-015 A0
June 11,2015
2012/19/EU (WEEE2.0):废旧电子电气设备指令
Waste Electrical and Electronic Equipment
2013/2/EU:欧盟关于包装和包装废弃物指令
Europe parliament and council directive on packaging and packaging waste
No1907/2006(REACH):化学品注册、评估、许可和限制(高关注物质)
Registration, Evaluation, Authorization and Restriction of Chemicals(SVHC)
4.1 交流电容器 a.c. capacitor
主要设计用于交流电压的一种电容器
注:交流电容器可以用在与电容器额定电压交流有效值相同电压的直流电源。
Capacitor designed essentially for application with a power-frequency alternating voltage.
NOTE : a.c. capacitor may be used on d.c. supplies having the same voltage as the a.c.
r.m.s. rated voltage of the capacitor.
4.2 Y 类电容器 capacitor of class Y
一种适用于在电容器失效时会导致电击危险的场合的电容器。Capacitor of a type
suitable for use in situations where failure of the capacitor could lead to danger of electric
shock.
4.3 额定电压 rated voltage
电容器在额定频率下的交流有效值,或直流工作电压。该电压可以在下限类别温度
和上限类别温度之间的任一温度下连续施加到电容器的引出端上。Either the r.m.s.
operating voltage of rated frequency or the d.c. operating voltage, which may be applied
continuously to the terminations of a capacitor at any temperature between the lower and the
upper category temperatures.
4.4 损耗角正切 tangent of loss angle(tanδ)
在规定频率的正弦电压下,电容器的损耗功率除以电容器的无功功率。The power loss
of the capacitor divided by the reactive power of the capacitor at a sinusoidal voltage at a
specified frequency.
4.5 上限类别温度 upper category temperature
电容器在连续工作时的最高表面温度。Maximum surface temperature for which the
capacitor has been designed to operate continuously.
4.6 下限类别温度 lower category temperature
电容器在连续工作时的最低表面温度。Minimum surface temperature for which the
4.7 气候类别 climatic category
电容器的气候类别用字母(标准 DIN40040:例 FME)或数字(标准 IEC68-1:例
55/85/21)来表示。第一个字母或第一段两位数字代表下限类别温度;第二个字母或第
二段两位数字代表上限类别温度,第三个字母或第三段两位数字代表稳态湿热的天数。
The climatic category which the capacitor belong to is expressed in numbers (IEC
60068-1e.g.:25/125/21).The
first
number
represents
the
lower
category
temperature(e.g.:-25 ℃ ); the second number represents the upper category temperature
(e.g.:+125℃) and the third number represents the number of days relevant to the damp heat
test (e.g.:21days)
5 of 18
www.ajc.com.hk
AJC-3-015 A0
June 11,2015
4.8 电容量随温度变化 temperature characteristic of capacitor
电容器在不超出类别温度范围的给定温度范围内所出现的电容量最大可逆变化。
此 变 化 表 示 为 相 对 于 20 ℃时 电 容 量的 百 分 比。 The maximum reversible variation of
capacitance produced over a given temperature range within the category temperature range,
normally expressed as a percentage of the capacitance related to a reference temperature of
20℃.
JK
F
222
M
2F
F7
250
A
060
E
Series
Dielectric
Capacitance
Tolerance
Rate voltage
Leads spacing
Leads length
Lead Type
Dielectric
E:
JK: Y2
B: Y5P
222:2200PF
K: ±10%
2E: 250V
F0: 10mm
200: 20mm
A: Straight
diameter
Blue
F: Y5V
101:100PF
M: ±20%
2F: 300V
F7: 7.5mm
028: 2.8mm
C: outside k
060: 6.0mm
epoxy
E: Y5U
103:10000PF
125: 12.5mm
resin
容量代码用三位数表示,前两位表示有效数字,后一位表示有效数字后面零的个数。
Codes for capacitance shall be find expression in three numbers. The first two digits are
significant, and the third digit is number of zero.
6. Approval standard and file number
Table 1
Testing and
Certification
Institute
VDE
UL
CQC
STANDARD NO.
DIN EN 60384-14
(VDE 0565-1-1):
2014-04
EN60384-14:2013-08
IEC 60384-14(ed.4)
CLASS TYPE W.V
C.C P.F.C
JK
X1 400VAC
Y2 125/250/300VAC
25/125/21/B
JK
UL 60384-14 2014-07
X1 400VAC
CSA E60384-14 2014-10
Y2 125/250/300VAC
CSA E60384-1 2014-10
25/125/21/B
IEC 60384-14:2005
JK
X1 400VAC
Y2 300VAC
25/125/21/B
6 of 18
www.ajc.com.hk
Issued/
FILE NO. MARK
Revised
day
40043092
2015-10-06
E477850
2015-09-22
CQC1500
1132574
2015-10-15
AJC-3-015 A0
June 11,2015
Design1
Table 2
NO.
1
2
3
4
5
部位名称
constituent
包封层
Coating
陶瓷介质
Ceramic medium
焊接点
Solder
电极
Electrode
引脚
Lead Frame
材料
material
环氧树脂
Epoxy resin
陶瓷
Ceramic
焊锡
Soldering tin
银浆
Silver oxide
CP 线
CP wire
code of dimension
Design2
TYPE A:直脚 Straight
TYPE D:前后弯 Front and back curve
TYPE C:外 K 脚 Outside Kink
TYPE E:平膊 Flat shoulder
7 of 18
www.ajc.com.hk
AJC-3-015 A0
June 11,2015
9. Capacitance and dimension
JK series – CLASS Y2
Part Number
Temp
Char
JKB101K□□□□□□
JKB151K□□□□□□
JKB221K□□□□□□
JKB271K□□□□□□
JKB331K□□□□□□
JKB471K□□□□□□
JKB561K□□□□□□
Y5P
(B)
±10%
JKB681K□□□□□□
JKB821K□□□□□□
JKB102K□□□□□□
JKF102M□□□□□□
JKF152M□□□□□□
JKF222M□□□□□□
JKF332M□□□□□□
JKF392M□□□□□□
JKF472M□□□□□□
JKF562M□□□□□□
JKF682M□□□□□□
JKF103M□□□□□□
Y5V
(F)
+22%
-82%
Table 3
Cap Value
(Pf)
100
150
220
270
330
470
560
680
820
1000
1000
1500
2200
3300
3900
4700
5600
6800
10000
CAP
TOL
K
±10%
M
±20%
D
±1.0
6.0
6.0
6.0
6.0
6.0
6.5
7.0
7.5
8.5
9.0
6.0
6.0
6.5
8.0
8.5
9.0
10.0
11.0
13.5
DIMENSIONS(mm)
F
T
d
±0.8
±0.8
±0.05
7.5
or
10
7.5
or
10
3.5
0.55
3.5
0.55
10
Design3
B
E
F
-100
+125
8 of 18
www.ajc.com.hk
AJC-3-015 A0
June 11,2015
11. 环境管理物质含量控制要求
Table 4
物质名称
Substances
镉及镉化合物
Cadmium and cadmium compounds
铅及铅化合物
Lead and lead compounds
汞及汞化合物
Mercury and mercury compounds
六价铬及六价铬化合物
Hexavalent chromium compounds
多溴联苯 PBBS
Polubrominated biphenyls
多溴联苯醚 PBDES
Polubrominated diphenylethers
镉+铅+汞+六价铬(包装材料)
Cd+Pb+ Hg + Cr+6(packing materials)
氯 Cl
溴 Br
氯+溴 Cl+Br
REACH 高关注物质
SVHC
限制含量
concentration (unit: ppm)
KJKF222M2FF7035A075E 价格&库存
很抱歉,暂时无法提供与“KJKF222M2FF7035A075E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16553
- 100+0.16305
- 400+0.13442
- 1000+0.10716
- 5000+0.09679
- 10000+0.08781
- 国内价格
- 20+0.18060
- 200+0.14550
- 1000+0.11580
- 2000+0.10460
- 10000+0.09490
- 20000+0.08960
- 国内价格
- 20+0.18058
- 200+0.14665
- 1000+0.11690
- 2000+0.10560
- 10000+0.09580
- 20000+0.09049
