GT36549
GT36549
    JCHL(晶创和立)
    PHOTORES_3.6X2.4MM_SM
    耐压:100V,功率:50mW,波长:560nm,工作温度:-30~+70℃
GT36549 数据手册
深圳市晶创和立科技有限公司 Photoconductive Cell GT36549 PACKAGE DIMENSIONS unit(mm) ABSOLUTE MAXIMUM RATINGS Parameter Rating Power Dissipation at 25℃ Voltage (AC or DC) Temperature Range Operating and Storage Units 50 mW 100 V ℃ -30 to +70 ELECTRO-OPTICAL CHARACTERICTICS @25℃ Resistance(Ohms) 10Lux Spectral Dark(10sec) Sensitivity(γ) Response lg(R10/R100) Peak(nm) Min 50K Max Min 150K 5M 560 0.65 Light Resistance: Measured at 10 Lux with standard light A (2856K color temperature) and 60-90minutes illumination  at 400-600 Lux prior testing.  Dark Resistance:Measurd 10 seconds after closed 10 Lux.  The error of γ is ± 0.15. Reflow soldering: use lead-free medium temperature solder paste (℃) Preheating temperature 140~170 ℃ 60~120 s Peak temperature 210~225℃ 5 s This product is suitable for medium temperature 200℃ 30~40 s medium temperature solder paste, which is for solder paste (melting point 151-172 ℃ . The specification shows the reflow soldering curve of reference only and can be adjusted appropriately Heating rate according to specific conditions. (s) Recommended reflow curve 地址:深圳市龙华区民治街道牛栏前港深国际中心9楼C913 电话:0755-23210829   传真:0755-23210825 网址:www.szjchl.com     邮箱:mk0622@163.com 深圳市晶创和立科技有限公司 Photoconductive Cell GT36549 Recommended pad dimensions: unit(mm) Pad Carrier Tape: unit(mm) Material: PS,black antistatic Number of tapes:2000 pcs Per Reel+the begin and end are empty 24 pcs Reel specification: 7-inch black split rubber reel Reel size: 177x60x12.4mm 地址:深圳市龙华区民治街道牛栏前港深国际中心9楼C913 电话:0755-23210829   传真:0755-23210825 网址:www.szjchl.com     邮箱:mk0622@163.com Distance from case:more than 3mm
GT36549 价格&库存
很抱歉,暂时无法提供与“GT36549”相匹配的价格&库存,您可以联系我们找货
GT36549
  • 5+1.16698
  • 50+0.92002
  • 400+0.68218
  • 800+0.67536
库存:593
GT36549
  • 5+1.28607
  • 50+1.01391
  • 150+0.89727
  • 500+0.75179
库存:1589
