山东晶导微电子股份有限公司
ES1ALWS THRU ES1JLWS
Jingdao Microelectronics co.LTD
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 50 to 600 V
PINNING
Forward Current – 0.5 A
PIN
FEATURES
• Easy pick and place
• For surface mounted applications
• Low profile package
• Built-in strain relief
• Superfast recovery times for high efficiency
DESCRIPTION
1
Cathode
2
Anode
2
1
Simplified outline SOD-323 and symbol
MECHANICAL DATA
▪Case: SOD-323
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪A pprox. Weight: 5.48mg / 0.00019oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
Parameter
ES1ALWS ES1BLWS ES1CLWS ES1DLWS ES1ELWS ES1GLWS ES1JLWS
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
150
200
300
400
600
V
Maximum RMS voltage
V RMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
V DC
50
100
150
200
300
400
600
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
Peak Forward Surge Current 8.3 ms
Single Half Sine Wave Superimposed
on Rated Load
VF
Maximum Forward Voltage at 0.5 A
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
I FSM
(1)
Operating and Storage Temperature Range
0.5
A
15
A
1.25
1
1.68
V
IR
5
100
μA
Cj
15
pF
t rr
35
ns
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
2019.01
SOD323-E-ES1ALWS~ES1JLWS-0.5A600V
Page 1 of 3
山东晶导微电子股份有限公司
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
300
0.6
0.5
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
0.4
0.3
0.2
0.1
Single phase half-wave 60 Hz
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
Case Temperature (°C)
80
100
Fig.5 Typical Junction Capacitance
T J =25°C
1.0
ES1ALWS~ES1DLWS
ES1ELWS/ES1GLWS
ES1JLWS
0.01
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
0.1
60
% of PIV.VOLTS
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.001
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2019.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
8
mil
The recommended mounting pad size
Marking
Type number
1.2
(47)
1.4
(55)
1.2
(47)
Marking code
ES1ALWS
ES1BLWS
ESL
1.2
(47)
ES1CLWS
ES1DLWS
ES1ELWS
ESM
ES1GLWS
Unit: mm
(mil)
2019.01
JD901183B0
ES1JLWS
ESH
Page 3 of 3
很抱歉,暂时无法提供与“ES1JLWS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.47630
- 200+0.15950
- 1500+0.09911
- 3000+0.07865
- 国内价格
- 20+0.19365
- 200+0.15866
- 600+0.13922
- 3000+0.12766
- 9000+0.11751
- 21000+0.11200
- 国内价格
- 20+0.15969
- 300+0.12761
- 1200+0.10989
- 3000+0.09920
- 国内价格
- 20+0.14722
- 300+0.11206
- 1200+0.09254
- 3000+0.08082
