MSB40M
MSB40M
    JINGDAO(晶导微电子)
    UMSB
    4A表面安装玻璃钝化桥式整流器 VR=1KV IR=5μA UMSB
MSB40M 数据手册
山东晶导微电子有限公司 MSB40B THRU MSB40M Jingdao Microelectronics 4A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: PINNING • Glass Passivated Chip Junction PIN • Reverse Voltage - 100 to 1000 V DESCRIPTION 1 Output Anode(+) 2 Output Cathode(-) • High Surge Current Capability 3 Input Pin(~) • Designed for Surface Mount Application 4 Input Pin(~) • Forward Current - 4.0 A 1 MECHANICAL DATA • Case: UMSB • Terminals: Solderable per MIL-STD-750, Method 2026 2 4 • A pprox. Weight: 0.234g / 0.00825oz 3 UMSB Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols MSB40B Parameter MSB40D MSB40G MSB40J MSB40K MSB40M Units Maximum Repetitive Peak Reverse Voltage V RRM 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 100 200 400 600 800 1000 V Average Rectified Output Current IO 4.0 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) I FSM 95 A Maximum Forward Voltage at 4.0 A VF 1.1 V IR 5 100 μA Cj 50 pF T j , T stg -55 ~ +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage @ T A =25 °C @ T A =125 °C Typical Junction Capacitance(Note1) Operating and Storage Temperature Range Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. 2017.04 UMSB-A-MSB40B~MSB40M-4A1KV Page 1 of 3 山东晶导微电子有限公司 MSB40B THRU MSB40M Jingdao Microelectronics Fig.2 Typical Reverse Characteristics 5.0 4.0 3.0 2.0 1.0 Resistive or Inductive Load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Rectified Output Current (A) Fig.1 Average Rectified Output Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Case Temperature (°C) T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) 100 T J =25°C 10 1 0.5 1.0 1.5 2.0 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 133 114 95 76 57 38 19 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2017.04 Page 1 of 3 山东晶导微电子有限公司 MSB40B THRU MSB40M Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 4 leads UMSB E C A e D b L ∠ALL ROUND E1 VM A UMSB mechanical data A C D E E1 L e b max 1.5 0.29 7.0 7.6 8.9 1.6 5.3 1.15 min 1.3 0.17 6.2 7.1 8.4 1.0 4.9 0.95 max 59 12 276 299 350 55 209 45 min 51 7 244 280 331 31.5 193 37 UNIT ∠ mm 10° mil Marking Type number 2017.04 Marking code MSB40B MB40B MSB40D MB40D MSB40G MB40G MSB40J MB40J MSB40K MB40K MSB40M MB40M JD705209B5 Page 1 of 3
MSB40M 价格&库存
很抱歉,暂时无法提供与“MSB40M”相匹配的价格&库存,您可以联系我们找货
MSB40M
  • 5+0.89230
  • 50+0.71864
  • 150+0.63180
  • 500+0.56668
  • 3000+0.51452
  • 6000+0.48849
库存:11716
MSB40M
    • 1+0.59280
    库存:5
    MSB40M
    • 5+0.80968
    库存:5
