山东晶导微电子有限公司
SSL545BF
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 45V
Forward Current - 5.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Simplified outline SMBF and symbol
MECHANICAL DATA
• Case: SMBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 5 7mg / 0.002oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
Parameter
SSL545BF
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
45
V
Maximum RMS voltage
V RMS
32
V
Maximum DC Blocking Voltage
V DC
45
V
Maximum Average Forward Rectified Current
at T c = 100 °C
I F(AV)
5
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
150
A
Maximum Instantaneous Forward Voltage at 5 A
VF
0.45
V
IR
1
50
mA
Cj
800
pF
RθJA
37
°C/W
Operating Junction Temperature Range
Tj
-55 ~ +150
°C
Storage Temperature Range
T stg
-55 ~ +150
°C
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =100 °C
Typical Junction Capacitance
(1)
Typical Thermal Resistance
(2)
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMBF-S-SSL545BF-5A45V
Page 1 of 3
山东晶导微电子有限公司
SSL545BF
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
6.0
5.0
4.0
3.0
2.0
1.0
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 5
10 3
10 2
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1
0.1
0.3
0.4
0.5
0.6
0.7
0.8
100
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
500
Instaneous Forward Voltage (V)
175
25
1000
1.0
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =25°C
10 1
Case Temperature (°C)
100
10
Number of Cycles at 60Hz
2017.01
T J =100°C
10 4
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SSL545BF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMBF
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
Top View
mil
Bottom View
g
A
C
D
E
HE
e
max
1.3
0.26
4.4
3.7
5.5
2.2
min
1.1
0.18
4.2
3.5
5.1
1.9
max
51
10
173
146
216
86
min
43
7
165
138
200
75
UNIT
mm
g
pad
e
E
A
pad
HE
1.0
9°
40
Marking
The recommended mounting pad size
Type number
1.8(71)
3.0(118)
Marking code
1.8(71)
SL545B
2.54(100)
SSL545BF
Unit:mm(mil)
2017.01
703028B0
Page 3 of 3
很抱歉,暂时无法提供与“SSL545BF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68022
- 50+0.54782
- 1000+0.53960
- 2000+0.52341
- 5000+0.49986
- 国内价格
- 5+0.64336
- 50+0.50858
- 150+0.44118
- 500+0.39064
- 2500+0.35025
- 国内价格
- 20+1.59030
- 100+0.94870
- 500+0.66410
- 5000+0.47440
- 10000+0.45070
- 50000+0.41740
