山东晶导微电子股份有限公司
SS34LB
Jingdao Microelectronics co.LTD
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 40V
Forward Current - 3.0 A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: SS34L
Simplified outline SMB and symbol
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 95m g (0.0034oz)
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Parameter
Symbols
SS34LB
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
28
V
Maximum DC Blocking Voltage
V DC
40
V
Maximum Average Forward Rectified Current
I F(AV)
3.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
80
A
Max Instantaneous Forward Voltage at 3 A
VF
0.50
V
Maximum DC Reverse Current T a = 25°C
T a =100°C
IR
0.5
5
mA
Typical Junction Capacitance(1)
Cj
450
pF
Typical Thermal Resistance (2)
RθJA
60
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
at Rated DC Reverse Voltage
Operating Junction Temperature Range
Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2018.10
SMB-S-SS34LB-3A40V
Page 1 of 3
山东晶导微电子股份有限公司
SS34LB
Fig.2 Typical Reverse Characteristics
3.5
3.0
2.4
1.8
1.2
0.6
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
10 4
T J =100°C
10 3
T J =75°C
10
2
10 1
T J =25°C
10 0
Case Temperature (°C)
60
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1.0
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
200
100
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
80
70
60
50
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
500
Instaneous Forward Voltage (V)
90
30
1000
1.8
10
100
Transient Thermal Impedance( °C /W)
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
Fig.3 Typical Forward Characteristic
100
Number of Cycles at 60Hz
2018.10
40
Percent of Rated Peak Reverse Voltage(%)
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
SS34LB
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
2.2
(86)
Type number
Marking code
SS34LB
SS34L
2.4
(94)
2.8
(110)
2.4
(94)
Marking
mm
Unit :
(mil)
2018.10
810095A0
Page 3 of 3
很抱歉,暂时无法提供与“SS34LB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40907
- 100+0.32927
- 600+0.32598
- 1200+0.31946
- 3000+0.30988
- 国内价格
- 10+0.51624
- 100+0.42909
- 300+0.38556
- 3000+0.32238
- 6000+0.29625
- 9000+0.28318
