山东晶导微电子有限公司
SS22B THRU SS220B
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200V
Forward Current - 2.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Simplified outline SMB and symbol
MECHANICAL DATA
• Case : SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight : 0.055g / 0.002oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Parameter
Symbols
SS22B
SS24B
SS26B
SS28B
SS210B
SS212B
SS215B
SS220B
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
A
2.0
55
45
A
Max Instantaneous Forward Voltage at 2 A
VF
Maximum DC Reverse Current T a = 25°C
T a =100°C
IR
0.5
5
0.3
3
mA
Typical Junction Capacitance(1)
Cj
220
110
pF
Typical Thermal Resistance (2)
RθJA
60
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
at Rated DC Reverse Voltage
Operating Junction Temperature Range
Storage Temperature Range
0.55
0.70
0.85
0.95
V
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMB-S-SS22B~SS220B-2A200V
Page 1 of 3
山东晶导微电子有限公司
SS22B THRU SS220B
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
T J =75°C
10
2
SS22B/SS26B
T J =25°C
10 0
80
T J =25°C
Junction Capacitance ( pF)
T J =25°C
1.0
SS22B/SS24B
SS26B/SS28B
SS210B/SS212B
SS215B/SS220B
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
500
200
100
SS22B~SS26B
SS28B~SS220B
10
1.8
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
SS22B-SS28B
SS210B-SS220B
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
1000
Instaneous Forward Voltage (V)
60
10
100
Fig.4 Typical Junction Capacitance
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
SS28B-SS220B
10 1
Case Temperature (°C)
100
Number of Cycles at 60Hz
2017.01
T J =100°C
10 3
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS22B THRU SS220B
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
The recommended mounting pad size
E1
Marking
Type number
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
2017.01
702225A0
Marking code
SS22B
SS22
SS24B
SS24
SS26B
SS26
SS28B
SS28
SS210B
SS210
SS212B
SS212
SS215B
SS215
SS220B
SS220
Page 3 of 3
很抱歉,暂时无法提供与“SS210B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.26620
- 200+0.17160
- 1500+0.14960
- 3000+0.13200
- 国内价格
- 10+0.31569
- 100+0.25920
- 300+0.23091
- 3000+0.20963
