山东晶导微电子有限公司
MB1S-10 THRU MB10S-10
Jingdao Microelectronics
1A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
FEATURES:
PINNING
Glass Passivated Chip Junction
Reverse Voltage - 100 to 1000 V
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
Forward Current - 1 A
High Surge Current Capability
3
Output Anode(+)
Designed for Surface Mount Application
4
Output Cathode(-)
MECHANICAL DATA
• Case: MBS
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 100mg / 0.0035oz
3
4
2
1
MBS Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
MB1S-10
MB2S-10
MB4S-10
MB6S-10
MB8S-10
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
Parameter
Average Rectified Output Current
at T c = 125 °C
MB10S-10 Units
IO
1.0
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
35
A
Maximum Forward Voltage at 1.0 A
VF
1.1
V
IR
5
40
μA
Cj
13
pF
RθJA
RθJC
80
28
°C/W
T j , T stg
-55 ~ +150
°C
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@ T A =25 °C
@ T A =125 °C
Typical Junction Capacitance(Note1)
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
2016.01
MBS-A-MB1S-10~MB10S-10-1A1KV
Page 1 of 3
山东晶导微电子有限公司
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
MBS
A
∠ALL ROUND
C
a
L1
L
d
HE
e
D
e
E
MBS mechanical data
A
C
D
E
HE
d
e
L
L1
a
max
2.6
0.22
5.0
4.1
7.0
2.7
0.7
1.7
1.1
0.2
min
2.2
0.15
4.5
3.6
6.4
2.3
0.5
1.3
0.5
max
102
8.7
197
161
276
106
28
67
43
min
94
5.9
177
142
252
91
UNIT
mm
7°
8
mil
Marking
6.0
236
2.5
100
0.9
35
2.4
94
mm
Unit :
(mil)
Type number
Marking code
MB1S-10
10S1
MB2S-10
10S2
MB4S-10
10S4
MB6S-10
10S6
MB8S-10
10S8
MB10S-10
10S10
10Sxx
2016.01
JD601144B6
Page 3 of 3
很抱歉,暂时无法提供与“MB10S-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19484
- 200+0.15207
- 600+0.12831
- 3000+0.11405
- 12000+0.10174
- 18000+0.09504
- 国内价格
- 20+0.15764
- 300+0.11997
- 1200+0.09904
- 3000+0.08649
