ULBF508 THRU ULBF510
5A SURFACE MOUNT BRIDGE RECTIFIER
FEATURES:
PINNING
• Reverse Voltage - 800 & 1000 V
PIN
• Forward Current - 5.0 A
• High Surge Current Capability
• Designed for Surface Mount Application
MECHANICAL DATA
• Case: ULBF
• Terminals: Solderable per MIL-STD-750, Method 2026
DESCRIPTION
1
Output Anode(+)
2
Output Cathode(-)
3
Input Pin(~)
4
Input Pin(~)
2
1
3
4
(2)
(1)
• A pprox. Weight: 0.461g / 0.0163oz
(3)
(4)
ULBF Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
ULBF508
ULBF510
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
800
1000
V
Maximum RMS voltage
V RMS
560
700
V
Maximum DC Blocking Voltage
V DC
800
1000
V
Parameter
IO
5.0
A
I FSM
180
A
I t
2
134
A 2S
Maximum Forward Voltage at 1.0 A
VF
0.83
(typ.)
V
Maximum Forward Voltage at 5.0 A
VF
1.0
V
IR
5
100
μA
Cj
60
pF
RθJA
RθJC
RθJL
60
10
12
°C/W
T j , T stg
-55 ~ +150
°C
Average Rectified Output Current
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
2
I t Rating for Fusing
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@ T A =25 °C
@ T A =125 °C
Typical Junction Capacitance(Note1)
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
2019.08
ULBF-A- ULBF508~ ULBF510-5A1KV
Page 1 of 3
Fig.2 Typical Reverse Characteristics
7.0
6.0
5.0
4.0
3.0
2.0
1.0
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
120
140
T J =25°C
10
0.1
210
180
150
120
90
60
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
1.0
10
100
Reverse Voltage (V)
100
Transient Thermal Impedance( °C /W)
Peak Forward Surage Current (A)
100
100
2.0
240
Number of Cycles at 60Hz
2019.08
80
1
0.5
Fig.5 Maximum Non-Repetitive Peak
1
60
200
Instaneous Forward Voltage (V)
30
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Fig.6- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
Page 1 of 3
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
ULBF
E
D
e
b
L
C
A
∠ALL ROUND
E1
VM
A
ULBF mechanical data
A
C
D
E
E1
L
e
b
max
1.75
0.55
9.8
8.8
10.2
1.25
5.3
1.55
min
1.35
0.25
9.4
8.4
9.8
0.85
4.9
1.25
max
68
21.6
385
346
401
49
209
61
min
53
9.8
370
330
385
33
193
49
UNIT
mm
10°
mil
The recommended mounting pad size
Marking
Type number
ULBF508
ULBF508
ULBF510
ULBF510
5.1
201
1.8×2. 1
71×83
Marking code
8.7
343
2019.08
Unit: mm
(mil)
PG908149B5
Page 1 of 3
很抱歉,暂时无法提供与“ULBF510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.25283
- 50+0.99058
- 600+0.98067
- 1200+0.96106
- 国内价格
- 5+1.38068
- 50+1.09167
- 150+0.96779
