山东晶导微电子有限公司
ABS1-12 THRU ABS10-12
Jingdao Microelectronics
1.2A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
FEATURES:
PINNING
• Glass Passivated Chip Junction
• Reverse Voltage - 100 to 1000 V
• Forward Current - 1.2A
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
• High Surge Current Capability
3
Output Anode(+)
• Designed for Surface Mount Application
4
Output Cathode(-)
MECHANICAL DATA
• Case: ABS/LBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 88mg / 0.0031oz
3
4
2
1
ABS/LBF Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
ABS1-12
ABS2-12
ABS4-12
ABS6-12
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
Parameter
Average Rectified Output Current
at T c = 125 °C
ABS8-12 ABS10-12 Units
IO
1.2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
40
A
Forward Voltage per element
@I F =1.2A
VF
1.1
V
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@ T A =125 °C
IR
5
100
μA
Cj
18
pF
RθJA
RθJC
70
18
°C/W
T j , T stg
-55 ~ +150
°C
@ T A =25 °C
Typical Junction Capacitance(Note1)
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
2016.01
ABS-A-ABS1-12~ABS10-12-1.2A1KV
Page 1 of 3
山东晶导微电子有限公司
Fig.2 Typical Reverse Characteristics
1.4
1.2
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
CaseTemperature (°C)
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
ABS/LBF
∠ALL ROUND
∠ALL ROUND
C
A
a
L1
d
L
HE
e
D
e
E
ABS/LBF mechanical data
A
C
D
E
HE
d
e
max
1.5
0.22
5.2
4.5
6.4
4.2
0.7
min
1.3
0.15
4.9
4.2
6.0
3.8
0.5
max
59
8.7
205
177
252
165
28
min
51
5.9
193
166
236
150
UNIT
mm
L
L1
a
0.95
0.6
0.2
7°
37
mil
The recommended mounting pad size
8
Marking
6.2
244
4.0
157
1.0
39
24
Type number
Marking code
ABS1-12
12T1
ABS2-12
12T2
ABS4-12
12T4
ABS6-12
12T6
ABS8-12
12T8
ABS10-12
2.0
79
12T10
mm
Unit :
(mil)
12Txx
2016.01
JD512285B0
Page 3 of 3
很抱歉,暂时无法提供与“ABS10-12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.05671
- 100+0.05293
- 300+0.04915
- 500+0.04536
- 2000+0.04347
- 5000+0.04234
- 国内价格
- 50+0.17712
- 500+0.13824
- 1500+0.11664
