山东晶导微电子有限公司
FMSB30B THRU FMSB30M
Jingdao Microelectronics
3A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
FEATURES:
PINNING
• Glass Passivated Chip Junction
PIN
• Reverse Voltage - 100 to 1000 V
DESCRIPTION
1
Output Anode(+)
2
Output Cathode(-)
• Fast reverse recovery time
3
Input Pin(~)
• Designed for Surface Mount Application
4
Input Pin(~)
• Forward Current - 3.0 A
1
MECHANICAL DATA
• Case: UMSB
• Terminals: Solderable per MIL-STD-750, Method 2026
2
4
3
UMSB Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols FMSB30B FMSB30D FMSB30G FMSB30J
Parameter
FMSB30K FMSB30M Units
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
Average Rectified Output Current
at T c = 115 °C
IO
3.0
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
80
A
Maximum Forward Voltage at 3.0 A
VF
1.3
V
IR
5.0
200
μA
Typical Junction Capacitance(Note1)
Cj
40
pF
Typical Thermal Resistance(Note2)
RθJA
30
°C/W
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Maximum Reverse Recovery Time (Note3)
Operating and Storage Temperature Range
t rr
250
150
T j , T stg
-55 ~ +150
500
ns
°C
Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
3 . Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
2017.04
UMSB-F-FMSB30B~FMSB30M-3A1KV
Page 1 of 3
山东晶导微电子有限公司
Fig.2 Typical Reverse Characteristics
4.0
3.0
2.0
1.0
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
CaseTemperature (°C)
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.04
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
UMSB
E
C
A
e
D
b
L
∠ALL ROUND
E1
VM
A
M2 mechanical data
A
C
D
E
E1
L
e
b
max
1.5
0.29
7.0
7.6
8.9
1.6
5.3
1.15
min
1.3
0.17
6.2
7.1
8.4
1.0
4.9
0.95
max
59
12
276
299
350
55
209
45
min
51
7
244
280
331
31.5
193
37
UNIT
mm
10°
mil
Marking
Type number
2017.04
Marking code
FMSB30B
FMB30B
FMSB30D
FMB30D
FMSB30G
FMB30G
FMSB30J
FMB30J
FMSB30K
FMB30K
FMSB30M
FMB30M
JD705208B0
Page 3 of 3
很抱歉,暂时无法提供与“FMSB30M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+1.59030
- 200+0.94870
- 800+0.66410
- 3000+0.47440
- 6000+0.45070
- 30000+0.41740
- 国内价格
- 5+0.60502
- 50+0.47520
- 150+0.41019
- 国内价格
- 5+0.76390
- 50+0.59062
- 600+0.58176
- 1200+0.56431
- 3000+0.53892
- 国内价格
- 5+0.54900
- 50+0.43120
- 600+0.42689
- 1200+0.41835
