UMSB40M
UMSB40M
    JINGDAO(晶导微电子)
    UMSB
    4A表面安装玻璃钝化桥式整流器 VR=1KV IR=5μA UMSB
UMSB40M 数据手册
UMSB40B THRU UMSB40M 4A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: PINNING • Glass Passivated Chip Junction PIN • Reverse Voltage - 100 to 1000 V • Forward Current - 4.0 A DESCRIPTION 1 Output Anode(+) 2 Output Cathode(-) • Fast reverse recovery time 3 Input Pin(~) • Designed for Surface Mount Application 4 Input Pin(~) 1 (1) (2) - MECHANICAL DATA • Case: UMSB • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.234g / 0.00825oz + 2 4 ~ ~ (4) (3) 3 UMSB Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols Parameter UMSB40B UMSB40D UMSB40G UMSB40J UMSB40K UMSB40M Units Maximum Repetitive Peak Reverse Voltage V RRM 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 100 200 400 600 800 1000 V Average Rectified Output Current at Tc = 115 °C IO 4.0 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) I FSM 95 A Maximum Forward Voltage at 4.0 A VF Maximum DC Reverse Current Ta = 25 °C at Rated DC Blocking Voltage T a=125 °C 1.0 1.4 1.6 V IR 5.0 100 μA Typical Junction Capacitance(Note1) Cj 50 pF Typical Thermal Resistance(Note2) RθJA 40 °C/W Maximum Reverse Recovery Time (Note3) t rr Tj, Tstg Operating and Storage Temperature Range 50 75 -55 ~ +150 ns °C Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. Mounted on glass epoxy PC board with 4×1.5"x1.5"(3.81*3.81cm)copper pad. 3 . Measured with IF= 0.5 A, IR = 1 A, Irr = 0.25 A . 2017-04 UMSB-U-UMSB40B~UMSB40M-4A1KV Page 1 of 3 Average Rectified Output Current (A) 5.0 4.0 3.0 2.0 1.0 Resistive or Inductive Load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current( μ A) Fig.2 Typical Reverse Characteristics Fig.1 Average Rectified Output Current Derating Curve 100 T J =125 °C 10 1.0 T J =25 °C 0.1 00 Fig.3 Typical Instaneous Forward Characteristics pF) JunctionCapacitance ( Instaneous Forward Current (A) T J =25 °C pulse with 300μs 1% duty cycle 1.0 0.1 UMSB40B/UMSB40D UMSB40G UMSB40J~UMSB40M 0.01 0.0 40 60 80 100 120 140 Reverse Voltage (%) Fig.4 Typical Junction Capacitance 20 10 20 percent of Rated Peak Case Temperature (°C) 100 T J =25 °C 10 1 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) 0.1 1.0 10 100 Reverse Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2017-04 www.sdjingdao.com Page 2 of 3 UMSB40B THRU UMSB40M PACKAGE OUTLINE Plastic surface mounted package; 4 leads UMSB E C A e D b L ∠ALL ROUND E1 VM A M2 mechanical data A C D E E1 L e b max 1.5 0.29 7.0 7.6 8.9 1.6 5.3 1.15 min 1.3 0.17 6.2 7.1 8.4 1.0 4.9 0.95 max 59 12 276 299 350 55 209 45 min 51 7 244 280 331 31.5 193 37 UNIT ∠ mm 10° mil The recommended mounting pad size Marking Type number 5.1 201 1.3×1.8 51×71 Unit: mm (mil) 2017-04 JD705209B5 Marking code UMSB40B UMB40B UMSB40D UMB40D UMSB40G UMB40G UMSB40J UMB40J UMSB40K UMB40K UMSB40M UMB40M Page 3 of 3
UMSB40M
物料型号: - UMSB40B - UMSB40D - UMSB40G - UMSB40J - UMSB40K - UMSB40M
器件简介: - 产品为表面贴装玻璃钝化芯片桥式整流器。 - 具有快速反向恢复时间,设计用于表面贴装应用。
引脚分配: - 1号引脚:输出阳极(+) - 2号引脚:输出阴极(-) - 3号引脚:输入引脚(~) - 4号引脚:输入引脚(~)
参数特性: - 最大重复峰值反向电压:100V至1000V - 最大有效值电压:70V至700V - 最大直流阻断电压:100V至1000V - 平均整流输出电流在115°C时:4.0A - 峰值正向浪涌电流:95A(UMSB40G) - 最大正向电压在4.0A时:1.0V至1.6V - 最大直流反向电流在额定直流阻断电压下:5.0uA至100uA - 典型结电容:50pF - 典型热阻:40°C/W - 最大反向恢复时间:50ns至75ns - 工作和存储温度范围:-55°C至+150°C
功能详解: - 整流器的典型应用包括整流交流电。 - 整流器的反向特性和瞬态特性在文档中有详细说明。
应用信息: - 适用于电阻性或感性负载的单相半波60Hz电路。 - 对于电容性负载,电流需要根据额定峰值电压的百分比进行降额。
封装信息: - 封装类型:UMSB - 引脚:可焊性符合MIL-STD-750方法2026 - 重量:约0.234g或0.00825oz - 推荐安装垫尺寸:1.3×1.8mm(51×71mil)
UMSB40M 价格&库存
很抱歉,暂时无法提供与“UMSB40M”相匹配的价格&库存,您可以联系我们找货
UMSB40M
  • 1+1.19750
  • 100+1.11760
  • 300+1.03780
  • 500+0.95790
  • 2000+0.87820
  • 5000+0.79830
库存:2874
UMSB40M
  • 5+0.87044
  • 50+0.69404
  • 600+0.68710
  • 1200+0.67336
  • 3000+0.65316
库存:2874
UMSB40M
    • 1+0.76300
    库存:5
    UMSB40M
    • 1+1.47400
    • 100+1.18800
    • 750+1.06040
    • 1500+0.99990
    • 3000+0.94710
    库存:5
