MB24F
MB24F
    JINGDAO(晶导微电子)
    MBF
    2A表面安装肖特基电桥
MB24F 数据手册
山东晶导微电子有限公司 MB24F THRU MB220F Jingdao Microelectronics 2A SURFACE MOUNT SCHOTTKY BRIDGE PINNING FEATURES: Reverse Voltage - 40 to 200 V PIN DESCRIPTION 1 Input Pin(~) 2 Input Pin(~) Forward Current - 2 A High Surge Current Capability 3 Output Anode(+) Designed for Surface Mount Application 4 Output Cathode(-) MECHANICAL DATA • Case: MBF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 75mg 0.0026oz 3 4 2 1 MBF Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols MB24F MB26F MB28F MB210F MB220F Units Maximum Repetitive Peak Reverse Voltage V RRM 40 60 80 100 200 V Maximum RMS voltage V RMS 28 42 56 70 140 V Maximum DC Blocking Voltage V DC 40 60 80 100 200 V Parameter Maximum Average Forward Rectified Current at Tc = 90 °C Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) Max Instantaneous Forward Voltage at 2 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance 1) Typical Thermal Resistance 2) Operating Junction Temperature Range Storage Temperature Range I F(AV) 2.0 I FSM VF 50 0.55 0.70 0.5 10 IR Cj A 40 A 0.85 V 0.3 5 220 80 mA pF °C/W RθJA 75 Tj -55 ~ +125 °C T stg -55 ~ +150 °C Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with4×1.5"×1.5"(3.81×3.81 cm)copper pad. 2016.01 MBF-S-MB24F~MB220F-2A200V Page 1 of 3 山东晶导微电子有限公司 MB24F THRU MB220F Jingdao Microelectronics Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =100°C 10 3 T J =75°C 10 2 MB24F/MB26F MB28F-MB220F 10 1 T J =25°C 10 0 0 Case Temperature (°C) 60 80 100 Fig.4 Typical Junction Capacitance 500 T J =25°C Junction Capacitance ( pF) 20 10 1.0 MB24F MB26F MB28F/MB220F 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 50 MB24F 20 MB26F-MB220F 10 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance MB24F-MB26F MB28F-MB220F 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 100 Instaneous Forward Voltage (V) 60 10 200 1.8 10 100 Transient Thermal Impedance( °C /W) Peak Forward Surage Current (A) Instaneous Forward Current (A) Fig.3 Typical Forward Characteristic 1000 100 10 Number of Cycles at 60Hz 2016.01 40 20 Percent of Rated Peak Reverse Voltage(%) 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 MB24F THRU MB220F Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 4 leads MBF ∠ALL ROUND C A a L1 L d HE e D e E MBF mechanical data A C D E HE d e L L1 a max 1.6 0.22 5.0 4.1 7.0 2.7 0.8 1.7 1.1 0.2 min 1.2 0.15 4.5 3.6 6.4 2.3 0.5 1.3 0.5 max 63 8.7 197 161 276 106 31 67 43 min 47 5.9 177 142 252 91 20 51 20 UNIT ∠ mm 7° 8 mil Marking Type number 6.0 236 2.5 100 0.9 35 2.4 94 Marking code MB24F MB24F MB26F MB26F MB28F MB28F MB210F MB210F MB220F MB220F mm Unit : (mil) MBxxF 2016.01 XTH601064A0 Page 3 of 3
MB24F 价格&库存
很抱歉,暂时无法提供与“MB24F”相匹配的价格&库存,您可以联系我们找货
MB24F
    MB24F
    • 1+1.22100
    • 100+0.94050
    • 1250+0.78320
    • 2500+0.71170
    • 5000+0.66110
    库存:5
    MB24F
    • 5+0.97265
    • 50+0.77102
    • 150+0.67025
    • 500+0.59454
    库存:545
