1N4749A
1N4749A
    ST(先科)
    DO-41(DO-204AL)
    二极管配置:独立式 稳压值(标称值):24V 精度:±5% 功率:1W 反向电流(Ir):5μA@18.2V 阻抗(Zzt):25Ω 24V 1W
1N4749A 数据手册
1N4727A...1N4761A Silicon Planar Power Zener Diodes for use in stabilizing and clipping circuits with high power rating. Max. 0.7 Min. 25.4 Max. 2.8 Black Cathode Band Black Part No. Black "ST" Brand XXX Max. 4.2 ST Min. 25.4 Glass Case DO-41 Dimensions in mm Absolute Maximum Ratings (Ta = 25 OC) Parameter Power Dissipation Ptot Junction Temperature Storage Temperature Range 1) Symbol Value 1 1) Unit W Tj 200 O Tstg - 65 to + 200 O C C Valid provided that leads at a distance of 8 mm from case are kept at ambient temperature. Characteristics at Ta = 25 OC Parameter Thermal Resistance Junction to Ambient Air Forward Voltage at IF = 200 mA 1) Symbol RthA VF Max. Unit 1) K/W 170 1.2 V Valid provided that leads at a distance of 8 mm from case are kept at ambient temperature. ® Dated : 03/08/2011 Rev: 01 1N4727A...1N4761A Characteristics at Ta = 25 OC Zener Voltage Range Type 1N4727A 1N4728A 1N4729A 1N4730A 1N4731A 1N4732A 1N4733A 1N4734A 1N4735A 1N4736A 1N4737A 1N4738A 1N4739A 1N4740A 1N4741A 1N4742A 1N4743A 1N4744A 1N4745A 1N4746A 1N4747A 1N4748A 1N4749A 1N4750A 1N4751A 1N4752A 1N4753A 1N4754A 1N4755A 1N4756A 1N4757A 1N4758A 1N4759A 1N4760A 1N4761A 3) VZnom VZT at lZT (V) (V) (mA) 3 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 2.85…3.15 3.13…3.47 3.42…3.78 3.7…4.1 4.08…4.52 4.46…4.94 4.84…5.36 5.32…5.88 5.89…6.51 6.46…7.14 7.12…7.88 7.79…8.61 8.64…9.56 9.5…10.5 10.45…11.55 11.4…12.6 12.35…13.65 14.25…15.75 15.2…16.8 17.1…18.9 19…21 20.9…23.1 22.8…25.2 25.65…28.35 28.5…31.5 31.35…34.65 34.2…37.8 37.05…40.95 40.85…45.15 44.65…49.35 48.45…53.55 53.2…58.8 58.9…65.1 64.6…71.4 71.25…78.75 83 76 69 64 58 53 49 45 41 37 34 31 28 25 23 21 19 17 15.5 14 12.5 11.5 10.5 9.5 8.5 7.5 7 6.5 6 5.5 5 4.5 4 3.7 3.3 Dynamic Resistance 1) ZZT Max. (Ω) 10 10 10 9 9 8 7 5 2 3.5 4 4.5 5 7 8 9 10 14 16 20 22 23 25 35 40 45 50 60 70 80 95 110 125 150 175 ZZK Max. (Ω) 400 400 400 400 400 500 550 600 700 700 700 700 700 700 700 700 700 700 700 750 750 750 750 750 1000 1000 1000 1000 1500 1500 1500 2000 2000 2000 2000 at IZK (mA) 1 1 1 1 1 1 1 1 1 1 0.5 0.5 0.5 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 Reverse Current IR at VR Max. (V) (µA) 150 1 150 1 100 1 100 1 50 1 10 1 10 1 10 2 10 3 10 4 10 5 10 6 10 7 10 7.6 5 8.4 5 9.1 5 9.9 5 11.4 5 12.2 5 13.7 5 15.2 5 16.7 5 18.2 5 20.6 5 22.8 5 25.1 5 27.4 5 29.7 5 32.7 5 35.8 5 38.8 5 42.6 5 47.1 5 51.7 5 56 Maximum Surge Current 4) IZSM (mA) 1375 1375 1260 1190 1070 970 890 810 730 660 605 550 500 454 414 380 344 304 285 250 225 205 190 170 150 135 125 115 110 95 90 80 70 65 60 Maximum Regulator Current 2) Temperature coefficient at IZT IZM (mA) %/ OC 275 275 252 234 217 193 178 162 146 133 121 110 100 91 83 76 69 61 57 50 45 41 38 34 30 27 25 23 22 19 18 16 14 13 12 -0.08 to -0.05 -0.08 to -0.05 -0.08 to -0.05 -0.07 to -0.02 -0.07 to -0.01 -0.03 to +0.04 -0.01 to +0.04 0.10 to +0.045 +0.01 to +0.055 +0.015 to +0.06 +0.02 to +0.065 0.03 to 0.07 0.035 to 0.075 0.04 to 0.08 0.045 to 0.08 0.045 to 0.085 0.05 to 0.085 0.055 to 0.09 0.055 to 0.09 0.06 to 0.09 0.06 to 0.09 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 0.06 to 0.095 1) The dynamic resistance is derived from the 60 Hz AC voltage which results when an AC current having an RMS value equal to 10% of the Zener Current (IZT or IZK) is superimposed on IZT or IZK. Dynamic resistance is measured at two points to insure a sharp knee on the breakdown curve and to eliminate unstable units. 2) Valid provided that leads at a distance of 8 mm from case are kept at ambient temperature. 3) Tested with pulses tp = 20 ms. 4) The rating listed in the electrical characteristics table is maximum peak, non-repetitive, reverse surge current of 1/2 square wave or equivalent sine wave pulse of 1/120 second duration superimposed on the test current IZT. ® Dated : 03/08/2011 Rev: 01 0 10 20 20 30 40 50 60 70 8 10 80 9 90 IN4764 7 IN4738 IN4737 IN4741 IN4740 IN4739 30 IN4763 6 IN4762 5 IN4761 40 IN4736 50 IN4760 30 4 IN4758 0 IN4757 50 3 IN4755 2 IN4735 IN4734 IN4733 IN4731 IN4732 IN4730 IN47 29 60 IN4759 Iz IN4727 IN4728 70 IN4750 IN4751 IN4752 80 IN4756 40 1 IN4746 IN4747 IN4748 IN4749 90 IN4753 IN4754 mA IN4743 IN4744 0 IN4745 Iz IN4742 1N4727A...1N4761A Tj =constant(pulsed) Breakdowm characteristics mA 100 IN... Tj =25 oC 20 10 10 100 11 110 12 Vz IN... Tj =25 oC 0 120 Vz ® Dated : 03/08/2011 Rev: 01 1.0 250 0.8 200 Thermal Resistance Junction to Ambient (°C/W) Pd. Total Power Dissipation (W) 1N4727A...1N4761A 0.6 0.4 100 50 R JA 0.2 150 0 0 0 100 200 0 5 10 15 20 25 30 I, Lead Length (mm) Fig. 2 Typical Thermal Resistance vs. Lead Length Ω TA, Ambient Temperature Fig. 1 Power Dissipation vs Ambient Temperature 1000 Differential Zener Impedance ( ) 1000 Cj , Diode Capacitance (pF) f=1MHz TA=25°C 100 VR=0V VR=2V VR=5V VR=20V VR=30V 10 1 0 10 20 30 40 50 60 Vz, Zener Voltage (V) Fig. 3 Junction Capacitance vs Zener Voltage Iz=1mA 2mA 100 5mA 10mA 20mA 10 1 1 10 100 Vz, Zener Voltage (V) Fig. 4 Typical Zener Impedance vs. Zener Voltage ® Dated : 03/08/2011 Rev: 01
1N4749A 价格&库存
很抱歉,暂时无法提供与“1N4749A”相匹配的价格&库存,您可以联系我们找货
