2N5400 / 2N5401
PNP Silicon Epitaxial Planar Transistors
for general purpose, high voltage amplifier applications.
As complementary types the NPN transistors
2N5550 and 2N5551 are recommended.
On special request, these transistors can be
manufactured in different pin configurations.
1. Emitter 2. Base 3. Collector
TO-92 Plastic Package
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Collector Base Voltage
Collector Emitter Voltage
Symbol
2N5400
2N5401
2N5400
2N5401
Emitter Base Voltage
-VCBO
-VCEO
Value
130
160
120
150
Unit
V
V
-VEBO
5
V
Collector Current
-IC
600
mA
Power Dissipation
Ptot
625
mW
Tj
150
O
Tstg
- 55 to + 150
O
Junction Temperature
Storage Temperature Range
C
C
SEMTECH ELECTRONICS LTD.
Dated: 12/08/2016 Rev:01
2N5400 / 2N5401
Characteristics at Ta = 25 OC
Parameter
DC Current Gain
at -VCE = 5 V, -IC = 1 mA
at -VCE = 5 V, -IC = 10 mA
at -VCE = 5 V, -IC = 50 mA
Collector Base Cutoff Current
at -VCB = 100 V
at -VCB = 120 V
Emitter Base Cutoff Current
at -VEB = 3 V
Collector Base Breakdown Voltage
at -IC = 100 µA
Collector Emitter Breakdown Voltage
at -IC = 1 mA
Emitter Base Breakdown Voltage
at -IE = 10 µA
Collector Emitter Saturation Voltage
at -IC = 10 mA, -IB = 1 mA
at -IC = 50 mA, -IB = 5 mA
Base Emitter Saturation Voltage
Symbol
Min.
Max.
Unit
2N5400
2N5401
2N5400
2N5401
2N5400
2N5401
hFE
hFE
hFE
hFE
hFE
hFE
30
50
40
60
40
50
180
240
2N5400
2N5401
-ICBO
100
50
nA
-IEBO
50
nA
2N5400
2N5401
-V(BR)CBO
130
160
V
2N5400
2N5401
-V(BR)CEO
120
150
V
-V(BR)EBO
5
V
-VCE(sat)
0.2
0.5
V
-VBE(sat)
1
1
V
fT
100
400
MHz
Cob
6
pF
Gain Bandwidth Product
at -VCE = 10 V, -IC = 10 mA, f = 100 MHz
Collector Output Capacitance
at -VCB = 10 V, f = 1 MHz
2N5400 / 2N5401
IC - VBE
Collector Current Ic (mA)
Power Dissipation Ptot (mW)
Ptot-Ta
Ambient Temperature Ta ( ℃ )
Base Emitter Voltage VBE (V)
fT - IC
Transition Frequency
V C E ( s a t ) , V B E ( s at ) ( m V )
V CE(sat), V BE(sat) - I
C o l l e c t o r C u r r e n t IC ( m A )
C
VBE(sat)
VCE(sat)
Collector Output Capacitance Cob (pF)
Cob - VCB
Collector Base Voltage VCB (V)
很抱歉,暂时无法提供与“2N5401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25348
- 200+0.19926
- 1000+0.17280
- 2000+0.15477
- 国内价格
- 20+0.23235
- 100+0.22886
- 400+0.18265
- 1000+0.15840
- 5000+0.15682
- 国内价格
- 20+0.51840
- 100+0.38770
- 500+0.30060
- 1000+0.21780
- 2000+0.20700
- 10000+0.19170
