X2P2333KN1B0130110050ES0 数据手册
MPX/X2 Metallized Polypropylene Film Interference Suppresion Capacitors (Class X2)
Suppresion Capacitors (Class X2) Data Sheet
Feature
■Wide capacitance range from 0.001uF to 2.2uF.
■Operating Temperature: -40℃~110℃.
■Storage Temperature: 15℃~35℃.
■Withstanding over-voltage stressing.
■Excellent active and passive flame resistant abilities (UL94V-0).
Applications
■Widely used in across-the-line,interference suprression circuit.ect.
Applicable Standard
Approval
Organization
Safety Standards
Certificate No.
USA
Canada
UL/CUL
UL60384
E208107
Germany
VDE
EN60384-14
40034679
EU
ENEC
EN60384-14
40034679
SU03031-12001
Korea
KTL
K60384
SU03031-12002
SU03031-12003
SU03031-12004
China
CQC
GB/T 6346.14-2015
CQC08001024360
IEC
IEC-CB
IEC60384-14
CN11932
Email: info@songtian.cn
Website: http://www.songtian-ste.com
Revision: 2018-04-29
1
Part Number Code
X2
P2
Songtian
X2
104
K
Capacitance
103:10nF
104:100nF
105:1.0μF
225:2.2μF
Voltage
P2:275VAC
Q2:305VAC
Q3:310VAC
Q
1
B0
Pitch
N:10.0mm
Q:15.0mm
T:22.5mm
V:27.5mm
180
060
Width
060:6.0mm
180:18.0mm
E
Thickness
060:6.0mm
120:12.0mm
S
Inner
Management
Client
Catagoryt
S:Yellow
E:Grey
Height
060:6.0mm
120:12.0mm
Foot Type
1:Long Straight
2:Inside Kink Lead
5:Straight Lead
Taping
6:Inner Crimped
Tapping
Tolerence
K:±10%
120
Environmental
Standard
E:RoHS
F:RoHS+Halogen-Free
Lead Length
30~39:3.0~3.9mm
40~49:4.0~4.9mm
50~59:5.0~5.9mm
60~69:6.0~6.9mm
70~79:7.0~7.9mm
80~89:8.0~8.9mm
90~99:9.0~9.9mm
Lead Length
A0~A9:11.0~19.0mm
B0~B9:20.0~29.0mm
C0~C9:30.0~39.0mm
Specifications
Climatic Category
Rated Voltage
Dissipation Factor(tanδ)
40/110/56
275VAC、305VAC、310VAC
≤0.1%
Between terminals to case:
Withstand Voltage
2UR+1500VAC Minimum of 2000VAC
Between terminals:4.3UR(DC)/5S
CR≤0.33μF,IR≥15000MΩ
Insulation Resistance (I.R.)
CR>0.33μF,IR≥6000S
Note:T[s]=I.R.[MΩ]*CN [μF]
2
20℃、100V、60S
Dimensions (mm) and Approval
Capacitance
(uF)
0.001
0.0022
0.0033
0.0039
0.0047
0.01
0.022
0.033
Size (mm)
Rated Voltage
W±0.5
H±0.5
T±0.5
P±1.0
d±0.05
275VAC
13 . 0
11 . 0
5. 0
10 . 0
0.6
305VAC
13 . 0
11 . 0
5. 0
10 . 0
0.6
310VAC
13 . 0
11 . 0
5. 0
10 . 0
0.6
275VAC
13.0
11.0
5.0
10.0
0.6
305VAC
13.0
11.0
5.0
10.0
0.6
310VAC
13.0
11.0
5.0
10.0
0.6
275VAC
13.0
11.0
5.0
10.0
0.6
305VAC
13.0
11.0
5.0
10.0
0.6
310VAC
13.0
11.0
5.0
10.0
0.6
275VAC
13.0
11.0
5.0
10.0
0.6
305VAC
13.0
11.0
5.0
10.0
0.6
310VAC
13.0
11.0
5.0
10.0
0.6
275VAC
13.0
11.0
5.0
10.0
0.6
305VAC
13.0
11.0
5.0
10.0
0.6
310VAC
13.0
11.0
5.0
10.0
0.6
275VAC
13.0
11.0
5.0
10.0
0.6
305VAC
13.0
11.0
5.0
10.0
0.6
310VAC
13.0
11.0
5.0
10.0
0.6
275VAC
13.0
11.0
5.0
10.0
0.6
305VAC
13.0
11.0
5.0
10.0
0.6
310VAC
13.0
11.0
5.0
10.0
0.6
275VAC
13.0
11.0
5.0
10.0
0.6
305VAC
13.0
11.0
5.0
10.0
0.6
310VAC
13.0
11.0
5.0
10.0
0.6
3
Capacitance
(uF)
Size (mm)
Rated Voltage
W±0.5
H±0.5
T±0.5
P±1.0
d±0.05
275VAC
13 . 0
11 . 0
5. 0
10 . 0
0.6
305VAC
13 . 0
11 . 0
5. 0
10 . 0
0.6
310VAC
13 . 0
11 . 0
5. 0
10 . 0
0.6
275VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
305VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
310VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
275VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
305VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
310VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
275VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
305VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
310VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
0.15
275VAC
13 . 0
12 . 0
6. 0
10 . 0
0.6
0.22
275VAC
13.0
15.0
8.0
10 . 0
0.6
275VAC
18.0
11.0
5.0
15 . 0
0.8
305VAC
18.0
11.0
5.0
15 . 0
0.8
310VAC
18.0
11.0
5.0
15 . 0
0.8
275VAC
18.0
11.0
5.0
15 . 0
0.8
305VAC
18.0
11.0
5.0
15 . 0
0.8
310VAC
18.0
11.0
5.0
15 . 0
0.8
275VAC
18.0
11.0
5.0
15 . 0
0.8
305VAC
18.0
11.0
5.0
15 . 0
0.8
310VAC
18.0
11.0
5.0
15 . 0
0.8
275VAC
18.0
12.0
6.0
15 . 0
0.8
305VAC
18.0
12.0
6.0
15 . 0
0.8
310VAC
18.0
12.0
6.0
15 . 0
0.8
275VAC
18.0
12.0
6.0
15 . 0
0.8
305VAC
18.0
12.0
6.0
15 . 0
0.8
310VAC
18.0
12.0
6.0
15 . 0
0.8
275VAC
18.0
12.0
6.0
15 . 0
0.8
305VAC
18.0
12.0
6.0
15 . 0
0.8
310VAC
18.0
12.0
6.0
15 . 0
0.8
275VAC
18.0
14.5
8.5
15 . 0
0.8
305VAC
18.0
14.5
8.5
15 . 0
0.8
310VAC
18.0
14.5
8.5
15 . 0
0.8
0.047
0.068
0.082
0.1
0.033
0.047
0.068
0.082
0.1
0.15
0.22
4
Capacitance
(uF)
0.33
0.47
0.56
0.68
0.22
0.27
0.33
0.47
0.56
0.68
0.82
1.0
Size (mm)
Rated Voltage
W±0.5
H±0.5
T±0.5
P±1.0
d±0.05
275VAC
18.0
14.5
8.5
15 . 0
0.8
305VAC
18.0
16.0
10.0
15 . 0
0.8
310VAC
18.0
16.0
10.0
15 . 0
0.8
275VAC
18.0
16.0
10.0
15 . 0
0.8
305VAC
18.0
16.0
10.0
15 . 0
0.8
310VAC
18.0
16.0
10.0
15 . 0
0.8
275VAC
18.0
16.0
10.0
15 . 0
0.8
305VAC
18.0
16.0
10.0
15 . 0
0.8
310VAC
18.0
16.0
10.0
15 . 0
0.8
275VAC
18.0
19.0
11.0
15 . 0
0.8
305VAC
18.0
19.0
11.0
15 . 0
0.8
310VAC
18.0
19.0
11.0
15 . 0
0.8
275VAC
26.5
16.5
7.0
22 . 5
0.8
305VAC
26.5
16.5
7.0
22 . 5
0.8
310VAC
26.5
16.5
7.0
22 . 5
0.8
275VAC
26.5
16.5
7.0
22 . 5
0.8
305VAC
26.5
16.5
7.0
22 . 5
0.8
310VAC
26.5
16.5
7.0
22 . 5
0.8
275VAC
26.5
17.0
8.5
22 . 5
0.8
305VAC
26.5
17.0
8.5
22 . 5
0.8
310VAC
26.5
17.0
8.5
22 . 5
0.8
275VAC
26.5
19.0
10.0
22 . 5
0.8
305VAC
26.5
19.0
10.0
22 . 5
0.8
310VAC
26.5
19.0
10.0
22 . 5
0.8
275VAC
26.5
19.0
10.0
22 . 5
0.8
305VAC
26.5
19.0
10.0
22 . 5
0.8
310VAC
26.5
19.0
10.0
22 . 5
0.8
275VAC
26.5
17.0
8.5
22 . 5
0.8
305VAC
26.5
17.0
8.5
22 . 5
0.8
310VAC
26.5
17.0
8.5
22 . 5
0.8
275VAC
26.5
19.0
10.0
22 . 5
0.8
305VAC
26.5
19.0
10.0
22 . 5
0.8
310VAC
26.5
19.0
10.0
22 . 5
0.8
275VAC
26.5
17.0
8.5
22 . 5
0.8
305VAC
26.5
20.0
11.0
22 . 5
0.8
310VAC
26.5
20.0
11.0
22 . 5
0.8
5
Capacitance
(uF)
1.2
1.5
0.68
0.82
1.0
1.2
1.5
2.0
2.2
Size (mm)
Rated Voltage
W±0.5
H±0.5
T±0.5
P±1.0
d±0.05
275VAC
26.5
19.0
10.0
22 . 5
0.8
305VAC
26.5
22.0
12.5
22 . 5
0.8
310VAC
26.5
22.0
12.5
22 . 5
0.8
275VAC
26.5
20.0
11.0
22 . 5
0.8
305VAC
26.5
22.0
12.5
22 . 5
0.8
310VAC
26.5
22.0
12.5
22 . 5
0.8
275VAC
32.0
20.0
11.0
27 . 5
0.8
305VAC
32.0
20.0
11.0
27 . 5
0.8
310VAC
32.0
20.0
11.0
27 . 5
0.8
275VAC
32.0
20.0
11.0
27 . 5
0.8
305VAC
32.0
20.0
11.0
27 . 5
0.8
310VAC
32.0
20.0
11.0
27 . 5
0.8
275VAC
32.0
20.0
11.0
27 . 5
0.8
305VAC
32.0
20.0
11.0
27 . 5
0.8
310VAC
32.0
20.0
11.0
27 . 5
0.8
275VAC
32.0
20.0
11.0
27 . 5
0.8
305VAC
32.0
20.0
11.0
27 . 5
0.8
310VAC
32.0
20.0
11.0
27 . 5
0.8
275VAC
32.0
22.0
13.0
27 . 5
0.8
305VAC
32.0
22.0
13.0
27 . 5
0.8
310VAC
32.0
22.0
13.0
27 . 5
0.8
275VAC
32.0
22.0
13.0
27 . 5
0.8
305VAC
32.0
25.0
14.0
27 . 5
0.8
310VAC
32.0
25.0
14.0
27 . 5
0.8
275VAC
32.0
22.0
13.0
27 . 5
0.8
305VAC
32.0
25.0
14.0
27 . 5
0.8
310VAC
32.0
25.0
14.0
27 . 5
0.8
6
Lead Configuration
Lead Length
L (mm)
Coating Lead Length
H1(mm)
Long Straight
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
Inner Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
Pitch P>10mm:H1<6.0mm
Pitch P≤10mm:H1<5.0mm
Lead Style
Drawing
7
Taping And Dimensions (mm)
Fig.1
Fig.2
Fig.2
Fig.3
Fig.3
P=5.0
P=7.5
P=10
P=15
P=20/22.5
P3
12.7
12.7
12.7
25.4
30.0
±1.0
P2
6.35
±1.3
P0
12.7
12.7
12.7
12.7
15.0
±0.3
P1
3.85
±0.7
F
5.0
7.5
10.0
15.0
20.0/22.5
±1.0
H
20.0
20.0
20.0
20.0
20.0
±1.0
H0
16.5
16.5
16.5
16.5
16.5
±0.5
Δh
±2.0
W
18.0
18.0
18.0
18.0
18.0
+1.0/-0.5
W0
12.0
12.0
12.0
12.0
12.0
±1.0
W1
9.0
9.0
9.0
9.0
9.0
±0.5
W2
3.0
3.0
3.0
3.0
3.0
Max
D0
4.0
4.0
4.0
4.0
4.0
±0.3
d
0.5
0.6
0.6
0.8
0.8
±0.05
t
1.0
1.1
1.1
1.4
1.4
±0.2
t0
0.38
0.38
0.38
0.47
0.47
±0.04
Symbol
8
Tolerance
X2P2333KN1B0130110050ES0 价格&库存
很抱歉,暂时无法提供与“X2P2333KN1B0130110050ES0”相匹配的价格&库存,您可以联系我们找货
