規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
: 贴片式电磁无源蜂鸣器(外部驱动)
型 號
TYPE
: GSC9045YB-16R2700
DESCRIPTION : φ9.0 x H4.5 mm 2700Hz 16Ω
客戶料號
CUSTOMER NO. :
規 格 書 號
≥80dB 正发音 PPS 材质
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.0
2018-4-18
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
審核
承認
TESTED BY
CHECKED BY
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
審查
確認
ISSUED BY
CHECKED BY
APPROVED BY
周明
刘承成
1/6
地址:廣東省東莞市虎门镇怀德社区雅瑶工业区
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
A. SCOPE
This specification applies magnetic buzzer, GSC9045YB-16R2700
B. SPECIFICATION
No.
Item
Unit
Specification
Condition
1
Oscillation Frequency
Hz
2700
Vo-p=1/2duty , square
wave
2
Operating Voltage
Vo-p
2.0 ~ 5.0
3
Rated Voltage
Vo-p
3.0
4
Current Consumption
mA
MAX. 80
at Rated Voltage
5
Sound Pressure Level
dB
Min.75
at 10cm at Rated
Voltage
6
Coil Resistance
Ω
16±3
7
Operating Temperature
-20 ~ +80
8
Storage Temperature
-30 ~ +85
9
Dimension
mm
φ9.0 x H4.5
10
Environmental
Protection Regulation
C. APPEARANCE DRAWING
See appearance
drawing
RoHS
Tol : ± 0.3
Unit: mm
2/6
D:TEST METHOD:
E:FREQUENCY RESPONSE:
3/6
4/6
F: RELIABLY TEST:
NO. ITEM
1
2
High temp.
storage life
Low
temp.
storage life
3
Temp. Cycle
4
Humidity Test
5
6
Vibration Test
Shock
7
Drop Test
8
Lead pull
9
Recommended
temp. Profile
for Reflow
Oven
TESTING CONDITION
VARIANCE AFTER TEST
The part shall be capable of withstanding a
storage temperature is +80℃ for 120 hours
storage temperature is -30℃ for 120 hours
Total 5 cycles,
1 cycle consisting of -30±2℃, 30 minutes
20±5℃ 15 minutes
80±2℃,
30 minutes
20±5℃ 15 minutes
After the test the part
30±2℃, 90~95% RH, 120 hours
shall meet
The part shall be subjected to a vibration cycle is 10Hz specifications without
in a period of 1 minute. Total peak amplitude shall be
any degradation in
1.52mm(9.3g).
appearance and
The vibration test shall consist of 2 hours per performance except SPL
plane in each three mutually perpendicular shall be initial value±
10dB or more.
planes for a total time of 6 hours.
Sounder shall be measured after being
applied shock (980m/s²) for each three
mutually perpendicular directions to each of
3 times by half sine wave.
Dropped naturally from 700mm height onto
the surface of 10mm thick wooden board. 2
directions-upper and side of the part are to be
applied.
The part shall be pushed with a force of 9.8N After the test part shall meet
for 10±1 seconds behind the part.
specifications without any
degradation in appearance
and performance.
Shown in Fig.1
5/6
G: Recommended Temp. Profile for Reflow Oven (Fig.1)
Profile Feature
Average ramp-up rate(TL to Tp)
Preheat
-Temperature Min.(Tsmin)
-Temperature Min.(Tsmax)
-Temperature Min.(ts)
Tsmax to TL
-Ramp-up Rate
Time maintained above:
- Temperature(TL)
-Time(TL)
Peak temperature(Tp)
Time within 5℃of actual Peak temperature (tp)
Ramp-down Rate
Time 25℃ to Peak Temperature
Pb-Free Assembly
3℃/second max.
150℃
200℃
60~180 seconds
3℃/second max.
217℃
60~150 seconds
250℃+0/-5℃
6 seconds max.
6℃/second max.
8 minutes max.
6/6
H:PACKING:
Tapping Direction
1 : 1
1 : 8
7/6
PACKING:
NOTES:
1.800 PCS per box
2.Total 10 boxes per carton
3.Total 8000 PCS carton
8/7
很抱歉,暂时无法提供与“GSC9045YB-16R2700”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.76320
- 10+3.02820
- 30+2.65580
- 国内价格
- 1+4.14720
- 10+3.33720
- 30+2.92680
- 100+2.51640
