SMD5050-090NA
SMD5050-090NA
    RUILON(瑞隆源)
    SMD,5x4.2mm
    电极数:2 直流击穿电压:90V 精度:±30% 脉冲放电电流:5kA 极间电容:0.8pF
SMD5050-090NA 数据手册
Gas Discharge Tubes(GDT) SMD5050 Series Description Gas discharge tubes (GDT) use noble gasses enclosed in ceramic tubes to provide an alternate circuit path for voltage spikes. The ceramic envelope and with nickel connectors allow for high loads. SMD5050 Gas Discharge Tubes (GDT) series has a surge rating of 5kA, 8/20μs.Offered in a Squared Surface Mount package, which helps to make pick and place on PCB process easier. This GDT series is perfectly suited for broadband equipment applications. The GDT’s low off-state capacitance is compatible with high bandwidth applications and this capacitance loading value does not vary if the voltage across the GDT changes. Electrical symbol SMD5050 Gas Discharge Tube (GDT) series are specifically designed for protection of electrical, multimedia, and communication equipment against over voltage transients in surface mount assembly applications. Features Applications l l l l l l l l l l l l l l l l l l l Excellent response to fast rising transients Stable breakdown voltage GHz working frequency 8/20μs Impulse current capability:5KA Surface Mount package Non-Radioactive Ultra Low capacitance (
SMD5050-090NA 价格&库存
很抱歉,暂时无法提供与“SMD5050-090NA”相匹配的价格&库存,您可以联系我们找货
SMD5050-090NA
  • 1+2.18620
  • 10+1.94330
  • 50+1.74900
  • 100+1.58990
  • 500+1.45750
  • 1000+1.24930
库存:3609
SMD5050-090NA
  • 50+0.78309
  • 500+0.76445
库存:755
SMD5050-090NA
库存:5042
SMD5050-090NA
  • 5+2.14537
  • 50+1.75231
  • 150+1.58394
  • 1000+1.16718
  • 2000+1.07361
  • 5000+1.01739
库存:17437
SMD5050-090NA
    • 1+1.26560
    • 50+0.96954
    • 1000+0.89383
    库存:8002
