Gas Discharge Tube
2R1000~2R7500(T,S)-8 Series
GDTs (Gas Discharge Tubes) are placed in front of, and in
parallel with, sensitive telecom equipment such as power lines,
communication lines, signal lines and data transmission lines
to help protect them from damage caused by transient surge
voltages that may result from lightning strikes and equipment
switching operations.These devices do not influence the signal
in normal operation. However, in the event of an overvoltage
surge, such as a lightning strike, the GDT switches to a low
impedance state and diverts the energy away from the sensitive
equipment.
Dimension
unit:(mm)
GDTs offer a high level of surge protection, a broad voltage
range, low capacitance, and many form factors including
new surface mount devices, which makes them suitable for
applications such as MDF (Main Distribution Frame) modules,
high data-rate telecom applications (e.g. ADSL, VDSL), and
surge protection on power lines. Their low capacitance also
results in less signal distortion. When used in a coordinated
circuit protection solution with PTC devices, TSS thyristor surge
protection devices, and MOV (Metal Oxide Varistor) devices,
they can help equipment manufacturers meet
(T)Series
(S)Series
Features
• Compact, small form factor suitable for efficient
assembly
• Helps provide overvoltage fault protection against
high energy surges
• Suitable for high-frequency applications
• 8.0*6.0mm devices
• Broad voltage range from 1000V-7500V
• Various form factors: surface mount, axial leads, no
leads
• Low capacitance and insertion loss
• RoHS compliant
• Devices tested per ITU K.12 recommendations
• Non-radioactive materials
Applications
• Communication equipment
• CATV equipment
• Test equipment
• Data lines
• Power supplies
• Telecom SLIC protection
• Telecommunications
- MDF modules, xDSL equipment, RF system
protection, antenna, base station
• Broadband equipment
• ADSL equipment including ADSL2+
• XDSL equipment
• Satellite and CATV equipment
• General telecom equipment
• Industrial and consumer electronics, such as
- Surge protectors
- Alarm system
GDT 01
Electriacl Characteristics
Type Number
Impulse
Spark-over
Voltage
Maximum
Impulse
Discharge
Voltage
Maximum
Surge
Discharge
Current
AC
Discharge
Current
Impulse
Life
100v/s
1kv/μs
8/20μs,10times
50hz,1sec
10/1000μs,100A
Maximum
Insulation
Resistance
Maximum
Electrode
Capacitance
TestVoltage
1MHZ
(GΩ)
(V)
(V)
2R1000(T,S)-8
1000±20%
1500
2R1100(T,S)-8
1100±20%
1700
2R1200(T,S)-8
1200±20%
1800
2R1600(T,S)-8
1600±20%
2000
2R2000(T,S)-8
2000±20%
2300
2R2500(T,S)-8
2500±20%
2750
2R2700(T,S)-8
2700±20%
3500
2R3000(T,S)-8
3000±20%
4000
2R3300(T,S)-8
3300±20%
4200
2R3600(T,S)-8
3600±20%
4700
2R4000(T,S)-8
4000±20%
6000
2R4500(T,S)-8
4500±20%
6500
2R5000(T,S)-8
5000±20%
8000
2R6200(T,S)-8
6200±20%
9500
2R6500(T,S)-8
6500±20%
10000
2R7500(T,S)-8
7500±20%
11000
GDT 02
(KA)
(A)
5KA
5A
(Times)
300 times
3KA
3A
DC(V)
DC 1000V
>1
(pF)
1.5 pF
Pb – Free assembly
Pre Heat
s(min)
- Temperature Max (T
s(max)
- Time (Min to Max) (t
s
150°C
60 – 180 secs
Average ramp up rate (Liquidus Temp
(TL) to peak
3°C/second max
TS(max) to TL - Ramp-up Rate
5°C/second max
- Temperature (T L) (Liquidus)
217°C
- Temperature (t L)
60 – 150 seconds
260+0/-5 °C
Time within 5°C of actual peak
Temperature (t p )
10 – 30 seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (T
tL
Ramp-down
Preheat
TS(min)
25
Peak Temperature (T P)
Critical Zone
TL to T P
Ramp-up
TL
TS(max)
200°C
Tem p er at u r e
- Temperature Min (T
tP
TP
tS
time to peak temperature
(t 25ºC to peak)
Time
8 minutes Max.
P
Do not exceed
260°C
Soldering Parameters - Wave Soldering (Thru-Hole Devices)
Recommended Process Parameters:
280
Wave Parameter
260
Preheat:
240
220
(Depends on Flux Activation Temperature)
200
180
160
140
120
100
80
60
Lead-Free Recommendation
(Typical Industry Recommendation)
Temperature Minimum:
100° C
Temperature Maximum:
Preheat Time:
150° C
60-180 seconds
Solder Pot Temperature:
280° C Maximum
Solder Dwell Time:
2-5 seconds
40
240
230
220
210
200
190
180
170
160
150
140
130
120
110
90
100
80
70
60
50
40
Temperature (°C) - Measured on bottom side of board
300
Time (Seconds)
Cooling Time
Preheat Time
Dwell Time
Soldering Parameters - Hand Soldering
Solder Iron Temperature: 350° C +/- 5°C
Heating Time: 5 seconds max.
GDT 03
Packaging Dimensions
For 'LTR' Option Code Axial Lead Items
很抱歉,暂时无法提供与“2R3000T-8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.87361
- 20+0.85801
- 100+0.82681
- 国内价格
- 50+1.14978
- 500+1.13113
- 国内价格
- 1+3.69360
- 10+2.93436
- 30+2.55474
- 100+2.17512
- 500+1.87758
- 800+1.75446
- 国内价格
- 1+2.55200
- 50+1.96900
- 800+1.81500
