Positive Thermal Coefficent (PTC)
SMD1210 Series
Description
The 1210 series provides miniature surface mount
over-current protection with holding current from 0.05A
to 2.60A. This series is suitable for wide range of
applications in modern electronics where space is limited
Features
Applications
l I(hold): 0.05~2.60A
l USB peripherals
l PDAs / digital cameras
l Very high voltage surge capabilities
l Disk drives
l Game console port
l Available in lead-free version
l CD-ROMs
l Fast response to fault current
l General electronics
l RoHS compliant, Lead- Free and Halogen-Free
l Disk drives
for motherboards and
l Low resistance
l Set-top-box and HDMI
peripherals
l Compact design saves board space
l Mobile Internet Device
l Compatible with high temperature solders
protection
l Plug and play protection
l Mobile phones - battery
and port protection
(MID)
Part Number Code
S
M
D
1
Surface Mount
Device
2
1
Device size
code
P
Polytronics
Symbol
X
X
X
Current Rating
T
F
T: Thin Version
(Optional)
Special Voltage
Rating (Optional)
F: Lead-free
Environmental Specifications
Test
Conditions
Resistance change
Passive aging
+85℃,1000 hrs
±5% typical
Humidity aging
+85℃,85%R.H.,168 hours
±5% typical
Thermal shock
+85℃ to -40℃,20times
±33% typical
Resistance to solvent
MIL-STD-202,Method 215
No change
Vibration
MIL-STD-202,Method 201
No change
Ambient operating conditions : - 40 °C to +85 °C
Maximum surface temperature of the device in the tripped state is 125 °C
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2019-11-28
Page:1
SMD1210 Series
Performance Specification
Max.
Time to Trip
Ihold
Itrip
Vmax
Imax
Pd typ
Rimin
R1max
A
A
VDC
Current
A
Tmax
S
A
W
Ω
Ω
SMD1210P005TF
0.05
0.15
30
0.25
1.50
30
0.6
2.8
50
1210
SMD1210P010TF
0.10
0.30
30
0.50
0.60
30
0.6
0.8
15
1210
SMD1210P010TF/60
0.10
0.30
60
0.50
0.60
30
0.6
0.8
15
1210
SMD1210P020TF
0.20
0.40
30
8.00
0.02
30
0.6
0.4
5
1210
SMD1210P035TF
0.35
0.75
6
8.00
0.20
30
0.6
0.2
1.3
1210
SMD1210P035TF/13.2
0.35
0.75
13.2
8.00
0.20
30
0.6
0.2
1.3
1210
SMD1210P035TF/16
0.35
0.75
16
8.00
0.20
30
0.6
0.2
1.3
1210
SMD1210P050TF
0.50
1.00
13.2
8.00
0.10
30
0.6
0.18
0.9
1210
SMD1210P050TF/16
0.50
1.00
16
8.00
0.10
30
0.6
0.18
0.9
1210
SMD1210P050TF/24
0.50
1.00
24
8.00
0.10
30
0.6
0.18
0.9
1210
SMD1210P050TF/30
0.50
1.00
30
8.00
0.10
30
0.6
0.18
0.9
1210
SMD1210P075TF
0.75
1.50
6
8.00
0.10
30
0.6
0.07
0.4
1210
SMD1210P075TF/16
0.75
1.50
16
8.00
0.10
30
0.6
0.07
0.4
1210
SMD1210P100TF
1.00
2.20
6
8.00
0.30
35
0.6
0.05
0.21
1210
SMD1210P110TF
1.10
2.20
6
8.00
0.30
35
0.6
0.05
0.21
1210
SMD1210P110TF/16
1.10
2.20
16
8.00
0.30
35
0.6
0.05
0.21
1210
SMD1210P150TF
1.50
3.00
6
8.00
0.50
35
0.6
0.03
0.11
1210
SMD1210P150TF/12
1.50
3.00
12
8.00
0.50
35
0.6
0.03
0.11
1210
SMD1210P150TF/16
1.50
3.00
16
8.00
0.50
35
0.6
0.03
0.11
1210
SMD1210P175TF
1.75
3.50
6
8.00
0.60
35
0.8
0.02
0.08
1210
SMD1210P200TF
2.00
4.00
6
8.00
1.00
35
0.8
0.015
0.07
1210
SMD1210P260TF
2.60
5.20
6
8.00
2.00
35
0.8
0.01
0.06
1210
Type Number
Package
V max = Maximum operating voltage device can withstand without damage at rated current (Imax).
I max = Maximum fault current device can withstand without damage at rated voltage (V max).
I hold = Hold Current. Maximum current device will not trip in 25°C still air.
I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air.
Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage.
Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C.
R1max = Maximum device resistance is measured one hour post reflow.
Revised: 2019-11-28
Page:2
SMD1210 Series
Thermal Derating Chart-Ih(A)
Ambient Operation Temperature
Part Number
-40 ºC
-20 ºC
0 ºC
25 ºC
40 ºC
50 ºC
60 ºC
70 ºC
85 ºC
SMD1210P005TF
0.08
0.07
0.06
0.05
0.04
0.04
0.03
0.03
0.02
SMD1210P010TF
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.03
SMD1210P010TF/60
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.03
SMD1210P020TF
0.29
0.26
0.22
0.20
0.16
0.14
0.13
0.11
0.08
SMD1210P035TF
0.47
0.45
0.40
0.35
0.33
0.28
0.24
0.21
0.18
SMD1210P035TF/13.2
0.47
0.45
0.40
0.35
0.33
0.28
0.24
0.21
0.18
SMD1210P035TF/16
0.47
0.45
0.40
0.35
0.33
0.28
0.24
0.21
0.18
SMD1210P050TF
0.76
0.67
0.58
0.50
0.43
0.40
0.36
0.32
0.28
SMD1210P050TF/16
0.76
0.67
0.58
0.50
0.43
0.40
0.36
0.32
0.28
SMD1210P050TF/24
0.76
0.67
0.58
0.50
0.43
0.40
0.36
0.32
0.28
SMD1210P050TF/30
0.76
0.67
0.58
0.50
0.43
0.40
0.36
0.32
0.28
SMD1210P075TF
1.00
0.97
0.86
0.75
0.64
0.59
0.54
0.48
0.40
SMD1210P075TF/16
1.00
0.97
0.86
0.75
0.64
0.59
0.54
0.48
0.40
SMD1210P100TF
1.69
1.48
1.29
1.00
0.88
0.76
0.65
0.57
0.43
SMD1210P110TF
1.69
1.48
1.29
1.10
0.94
0.86
0.80
0.70
0.58
SMD1210P110TF/16
1.69
1.48
1.29
1.10
0.94
0.86
0.80
0.70
0.58
SMD1210P150TF
2.13
1.92
1.71
1.50
1.26
1.14
1.01
0.89
0.71
SMD1210P150TF/12
2.13
1.92
1.71
1.50
1.26
1.14
1.01
0.89
0.71
SMD1210P150TF/16
2.13
1.92
1.71
1.50
1.26
1.14
1.01
0.89
0.71
SMD1210P175TF
2.54
2.30
2.02
1.75
1.47
1.33
1.18
1.05
0.86
SMD1210P200TF
2.90
2.63
2.31
2.00
1.68
1.52
1.35
1.20
0.98
SMD1210P260TF
3.43
3.22
2.93
2.60
2.23
2.03
1.87
1.57
1.35
Thermal Derating Curve
Average Time-Current Curve
Average Time Current Curves
100
0.05A
0.10A
0.20A
0.35A
0.50A
0.75A
1.10A
1.50A
1.75A
2.00A
2.60A
160
140
Time In Seconds
Percentage of Derated Current
Derating Curves for SMD1210 Series
120
100
80
60
40
10
1
0.1
-20
60
80
0.01
0.1
Temperature (°C)
1
10
Current in Amperes
Revised: 2019-11-28
Page:3
SMD1210 Series
Soldering Parameters
Reflow Condition
TP
Critical Zone
TL to TP
Ramp-up
Pre
Heat
TL
-Temperature Min (Ts(min))
150°C
-Temperature Max (Ts(max))
200°C
- Time (min to max) (ts)
Average ramp up rate ( Liquids Temp
TL) to peak
TS(max)
Temperature
Pb - Free assembly
Ramp-down
TS(max) to TL - Ramp-up Rate
TS(min)
Reflo
w
Preheat
25
Time to peak temperature
(t 25℃ to peak)
Time
60 -180 Seconds
3°C/second max
3°C/second max
- Temperature (TL) (Liquids)
217°C
60 -150 Seconds
Peak Temperature (TP)
260 +0/-5°C
Time within 5°C of actual peak
Temperature (tp)
20 - 40 Seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max
Do not exceed
260°C
Recommended Pad Layout (mm.)
Lead style code
Dimensions
Package Dimensions (mm)
Type Number
A
B
Package Dimensions (in)
C
D
A
B
C
D
min
max
min
max
min
max
min
min
max
min
max
min
max
min
SMD1210P005TF
3
3.5
2.35
2.8
0.6
1.2
0.3
0.118
0.138
0.093
0.110
0.024
0.047
0.012
SMD1210P010TF
3
3.5
2.35
2.8
0.6
1.2
0.3
0.118
0.138
0.093
0.110
0.024
0.047
0.012
SMD1210P010TF/60
3
3.5
2.35
2.8
0.6
1.2
0.3
0.118
0.138
0.093
0.110
0.024
0.047
0.012
SMD1210P020TF
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P035TF
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P035TF/13.2
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P035TF/16
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P050TF
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P050TF/16
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P050TF/24
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P050TF/30
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P075TF
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
Revised: 2019-11-28
Page:4
Type Number
A
B
SMD1210 Series
C
D
A
B
C
D
min
max
min
max
min
max
min
min
max
min
max
min
max
min
SMD1210P075TF/16
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P100TF
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P110TF
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P110TF/16
3
3.5
2.35
2.8
0.5
1.1
0.3
0.118
0.138
0.093
0.110
0.020
0.043
0.012
SMD1210P150TF
3
3.5
2.35
2.8
0.5
1.2
0.3
0.118
0.138
0.093
0.110
0.020
0.047
0.012
SMD1210P150TF/12
3
3.5
2.35
2.8
0.5
1.2
0.3
0.118
0.138
0.093
0.110
0.020
0.047
0.012
SMD1210P150TF/16
3
3.5
2.35
2.8
0.5
1.2
0.3
0.118
0.138
0.093
0.110
0.020
0.047
0.012
SMD1210P175TF
3
3.5
2.35
2.8
0.8
1.4
0.3
0.118
0.138
0.093
0.110
0.031
0.055
0.012
SMD1210P200TF
3
3.5
2.35
2.8
0.8
1.4
0.3
0.118
0.138
0.093
0.110
0.031
0.055
0.012
SMD1210P260TF
3
3.5
2.35
2.8
1.0
1.6
0.3
0.118
0.138
0.093
0.110
0.039
0.063
0.012
Taping and Reel Specifications
Symbol
Millimeters
Inches
W
8.15±0.3
0.321±0.012
P
4.0±0.1
0.157±0.004
F
3.5±0.05
0.138±0.002
E
1.75±0.1
0.069±0.004
D
1.55±0.05
0.061±0.002
P0
4.0±0.1
0.157±0.004
P2
2.0±0.05
0.079±0.002
D1(max.)
178
7.007
D2(min.)
60
2.362
W1
9±0.5
0.354±0.02
Part Number
Halogen
Free
Packaging
Option
Quantity
Quantity &
Packaging Codes
SMD1210PxxxTF
Yes
Tape and Reel
4000
YR
Revised: 2019-11-28
Page:5
很抱歉,暂时无法提供与“SMD1210P005TF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.50373
- 100+0.39990
- 800+0.30905
- 1600+0.30441
- 4000+0.23748
- 国内价格
- 10+0.54953
- 100+0.43626
- 300+0.37962
- 1000+0.33715
- 4000+0.25907
- 8000+0.24214
- 国内价格
- 1+0.39552
- 200+0.25441
- 2000+0.22248
- 4000+0.19673
