ESD5V0D9B
ESD5V0D9B
    YINT(音特电子)
    SOD-923
    ESD VRWM=5V VBR(Min)=6V VC=18.6V Ppp=150W SOD923
ESD5V0D9B 数据手册
ESD Protection Diode ESD5V0D9B Trustworthy electronic circuit protection expert ESD5V0D9B Description ESD5V0D9B is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Features ●150 Watts Peak Pulse Power per Line (tp=8/20µs) Functional Diagram ●Operating voltage: 5V ●Low leakage current ●Package: SOD-923 ●Low clamping voltage ●Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV Applications ●Cellular Phones ●Portable Devices ●Digital Cameras ●Power Supplies Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Unit PPP 150 Watts ±15 KV ±8 KV VESD ESD per IEC 61000−4−2 (Contact) Lead Soldering Temperature TL 260 (10 sec) °C Operating Temperature Range TJ -55 to +125 °C Storage Temperature Range TSTJ -55 to +150 °C www.yint.com.cn 1 Rev:19.3 ESD Protection Diode ESD5V0D9B Trustworthy electronic circuit protection expert Electrical Characteristics (TA = 25 °C unless otherwise noted) Parameter Reverse Stand-off Voltage Reverse Breakdown Voltage Reverse Leakage Current Symbol Conditions Min. VRWM VBR IR It = 1mA VR =VRWM 6 Typ. Max. Units 5 V 8 V 1 μA Clamping Voltage VC @IPP 18.6 V Junction Capacitance CJ VR=0V, f = 1MHz 15 pF Characteristics Curves Figure 1- Power Derating Curve Figure 2- ESD Pulse Waveform (according to IEC 61000-4-2) Figure3- 8/20µs Pulse Waveform www.yint.com.cn 2 Rev:19.3 ESD Protection Diode ESD5V0D9B Trustworthy electronic circuit protection expert ACKAGE OUTLINE DIMENSIONS in millimeters (inches) : Inches Millimeters Dim MIN MAX MIN MAX A 0.030 0.033 0.75 0.85 B 0.022 0.026 0.55 0.65 C 0.037 0.041 0.95 1.05 D 0.014 0.017 0.36 0.43 E 0.006 0.010 0.15 0.25 F 0.002 0.006 0.05 0.15 H 0.003 0.007 0.07 0.17 Mounting Pad Layout(mm) Disclaimer Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. www.yint.com.cn 3 Rev:19.3
ESD5V0D9B
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-55至125度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制等领域。
7. 封装信息:采用DIP6封装。
ESD5V0D9B 价格&库存
很抱歉,暂时无法提供与“ESD5V0D9B”相匹配的价格&库存,您可以联系我们找货
