BCX56-16
BCX56-16
    LGE(鲁光)
    SOT89-3
    NPN 硅AF晶体管 SOT89-3 1A 100MHz 1W
BCX56-16 数据手册
BCX54-BCX56 NPN Silicon AF Transistors SOT-89 4.6 4.4 1.8 1.4 1.6 1.4 B Features — — 2.6 4.25 2.4 3.75 For AF driver and output stages 0.8 MIN High collector current 0.44 0.37 — Low collector-emitter saturation voltage — Complementary types:BCX51…BCX53(PNP) 0.13 B 0.53 0.48 0.40 2x) 0.35 1.5 3.0 Dimensions in inches and (millimeters) Ordering Information Type No. Marking BCX54 BCX54-10 BCX54-16 BCX55 BCX55-10 BCX55-16 BCX56 BCX56-10 BCX56-16 Package Code BA BC BD BE BG BM BH BK BL SOT-89 SOT-89 SOT-89 SOT-89 SOT-89 SOT-89 SOT-89 SOT-89 SOT-89 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Symbol Parameter Collector-Base Voltage VCBO Collector-Emitter Voltage VCEO Value Unit BCX54 BCX55 BCX56 45 60 100 V BCX54 BCX55 BCX56 45 60 80 V VEBO Emitter-Base Voltage 5 V IC DC Collector Current 1 A ICM Peak Collector Current 1.5 A IB Base current 100 mA IBM Peak base current 200 mA Ptot Total power dissipation,TS=130℃ 1 W Tj,Tstg Junction and Storage Temperature -65 to+150 ℃ Revision:20170701-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com BCX54-BCX56 NPN Silicon AF Transistors ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Parameter Symbol Test conditions IC=100μA IB=0 Collector-base breakdown voltage V(BR)CBO IC=10mA IB=0 Collector-emitter breakdown voltage V(BR)CEO Emitter-base breakdown voltage V(BR)EBO Collector cut-off current ICBO DC current gain hFE MIN MAX UNIT BCX54 BCX55 BCX56 45 60 100 V BCX54 BCX55 BCX56 45 60 80 V 5 V IE=10μA IC=0 VCB=30V IE=0 100 nA VCB=30V IE=0,TA=150℃ 20 μA VCE=2V IC=5mA VCE=2V IC=150mA VCE=2V IC=500mA VCE=2V IC=150mA -10 -16 25 40 25 250 63 100 160 250 Collector-emitter saturation voltage VCE(sat) IC=500mA IB=50mA 0.5 V Base-emitter voltage VBE IC=500mA ,VCE=2V 1 V Transition frequency fT VCE=10V, IC=50mA, f=20MHz 100 MHz TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Revision:20170701-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com BCX54-BCX56 NPN Silicon AF Transistors Revision:20170701-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com BCX54-BCX56 NPN Silicon AF Transistors Revision:20170701-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com
BCX56-16 价格&库存
很抱歉,暂时无法提供与“BCX56-16”相匹配的价格&库存,您可以联系我们找货
BCX56-16
  • 5+0.59195
  • 50+0.47790
  • 150+0.42088
  • 1000+0.36029
  • 2000+0.32606
  • 5000+0.30888
库存:9084
BCX56-16
  • 1+0.26450
  • 10+0.24150
  • 30+0.23690
