US2MBG
US2MBG
    SK(時科)
    SMB(DO-214AA)
    表面贴装超快恢复整流器 -55℃~+150℃@(Tj) 5uA@1kV 2A 1.65V@2A 75ns Single 1kV SMB
US2MBG 数据手册
US2ABG THRU US2MBG SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER Reverse Voltage - 50 to 1000 V Forward Current - 2 A PINNING FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • High efficiency • Lead free in comply with EU RoHS 2011/65/EU directives PIN DESCRIPTION 1 Cathode 2 Anode 2 MECHANICAL DATA • Case: SMB • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz 1 Top View Marking Code: US2A~US2M Simplified outline SMB and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols US2AB G US2BB G Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Parameter US2DB US2GB G G US2JB G US2KB US2MB Units G G Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 50 A Maximum Instantaneous Forward Voltage at 2 A VF Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Typical Junction Capacitance at V R =4V, f=1MHz Operating and Storage Temperature Range 1.0 1.65 5 100 IR t rr V μA 75 50 ns RθJA 60 °C/W Cj 20 pF T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. REV.08 1.3 1 of 3 US2ABG THRU US2MBG Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 2.4 2.0 1.6 1.2 0.8 0.4 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Peak Forward Surage Current (A) Instaneous Forward Current (A) 10 T J =25°C 1.0 US2ABG ~US2DBG US2GBG US2JBG ~US2MBG 0.01 0.001 0 0.5 1.0 1.5 2.0 60 80 100 120 140 70 60 50 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 2.5 Instaneous Forward Voltage (V) REV.08 40 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Fig.3 Typical Forward Characteristics 0.1 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 10 Number of Cycles 2 of 3 100 US2ABG THRU US2MBG PACKAGE OUTLINE SMB Plastic surface mounted package; 2 leads L A A1 C A b D E E1 VM A SMB mechanical data UNIT mm mil A1 L C b 5.59 0.20 1.5 0.305 2.2 3.3 5.08 0.05 0.8 0.152 1.9 155 220 7.9 59 12 87 200 2.0 32 6 75 A E D max 2.44 4.70 3.94 min 2.13 4.06 max 96 185 min 84 130 160 The recommended mounting pad size 2.2 (86) Marking 2.4 (94) 2.8 (110) 2.4 (94) mm Unit : (mil) REV.08 E1 3 of 3 Type number Marking code US2ABG US2A US2BBG US2B US2DBG US2D US2GBG US2G US2JBG US2J US2KBG US2K US2MBG US2M
US2MBG 价格&库存
很抱歉,暂时无法提供与“US2MBG”相匹配的价格&库存,您可以联系我们找货
US2MBG
库存:15000
US2MBG
  • 3000+0.09400
  • 9000+0.09140
  • 66000+0.08870
库存:15000
US2MBG
    • 3000+0.08142
    库存:1800
    US2MBG
      • 3000+0.08142
      US2MBG
      • 1+0.14850
      • 100+0.13860
      • 300+0.12870
      • 500+0.11880
      • 2000+0.11385
      • 5000+0.11088
      US2MBG
        • 3000+0.08142
        库存:162000
        US2MBG
          • 3000+0.08142
          库存:12600
