PMEG6010ER
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 6 0 V Forward Current - 1. 0 A
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
MECHANICAL DATA
• Case: SOD-123FL
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight:15mg 0.00048oz
PINNING
PIN
DESCRIPTION
1
Cathode
2
Anode
1
2
Weight:17mg,0.0006 oz
Simplified outline SOD-123FL and symbol
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
V
Maximum RMS voltage
V RMS
42
V
Maximum DC Blocking Voltage
V DC
60
V
Maximum Average Forward Rectified Current
I F(AV)
1.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
40
A
VF
0.70
V
IR
0.3
10
mA
Cj
80
pF
RθJA
115
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
Max Instantaneous Forward Voltage at 1 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance 1)
Typical Thermal Resistance
2)
Operating Junction Temperature Range
Storage Temperature Range
1) Measured
2)
at 1MHz and applied reverse voltage of 4 V D.C.
P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas.
REV.08
1 of 3
PMEG6010ER
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
Single phase half-wave 60 Hz
0.2
0.0
25
50
75
100
125
150
10 4
10 3
T J =100°C
10 2
T J =75°C
10 1
T J =25°C
10
Ambient Temperature (°C)
80
100
Fig.4 Typical Junction Capacitance
500
Junction Capacitance ( pF)
1.0
PMEG6010ER
0.1
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
100
50
PMEG6010ER
10
1
0.1
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
8.3 ms Single Half Sine Wave
(JEDEC Method)
40
30
00
1
T J =25°C
200
1.8
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Peak Forward Surage Current (A)
60
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
10
100
Number of Cycles at 60Hz
REV.08
40
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2 of 3
100
PMEG6010ER
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD123FL
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
1.2
(47)
1.2
(47)
2.0
(79)
Unit: mm
(mil)
REV.08
7°
The recommended mounting pad size
1.2
(47)
g
pad
e
E
A
pad
HE
3 of 3
很抱歉,暂时无法提供与“PMEG6010ER”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 45+0.18183
- 90+0.17587
- 180+0.17289
- 360+0.16395
- 国内价格
- 1+0.23540
- 200+0.15180
- 1500+0.13200
- 3000+0.11660
- 国内价格
- 20+0.14851
- 100+0.13501
- 500+0.12601
- 1000+0.11701
- 5000+0.10621
- 10000+0.10171
