2SD1623
2SD1623
    SK(時科)
    SOT89-3
    硅通用晶体管 100nA 25V 1W 160@100mA,1V 1.5A 100MHz 500mV@800mA,80mA NPN +150℃@(Tj) SOT-89-3
2SD1623 数据手册
2SD1623 NPN-Silicon General use Transistors 1W 、1.5A、25V Applications:Can be used for switching and amplifying in various 4 electrical and electronic circuit. Maximum ratings 2 1 Parameters 3 SOT-89 Symbol Rating Collector-emitter voltage (IB=0) VCEO 25 Unit V Collector-base voltage(IE=0) VCBO 40 V Marking Emitter-base voltage(IC=0) VEBO 6 V IC 1.5 A 2SD1623=DFS2N Ptot 1 W Junction temperature Tjm 150 ℃ Storage temperature Tstg -55~150 ℃ Collector current Total dissipation * power(TA=25℃) * Device is mounted on a printed circuit board. Electrical characteristics(Unless otherwise specified,TA=25℃) Parameters Test condition Min. typ Max. Unit Collector-emitter breakdown voltage V(BR)CEO IC=2mA,IB=0 25 — — V Collector-base breakdown voltage V(BR)CBO IC=100µA,IE=0 40 — — V Emitter-base breakdown voltage V(BR)EBO IE=100µA,IC=0 6 — — V Forward current transfer ratio 2SD1623 Collector-base current Collector-emitter saturation voltage Characteristic frequency REV.08 Symbol hFE VCE=1V;IC=100mA 160 — 300 — ICBO VCB=35V,IE=0 — — 100 nA VCE(sat) IC=800mA,IB=80mA — — 0.5 V fT IC=50mA,VCE=10V, f=100MHz — 100 — MHz 1 of 3 2SD1623 Outline Dimensions Unit:mm Dimensions Symbol A b b1 b2 c D E e e1 HE L LE α Typical characteristics REV.08 2 of 3 min 1.4 0.35 0.4 SOT-89 type max 1.6 0.55 0.65 1.6 0.35 4.4 2.35 0.45 4.6 2.55 1.5 3 4.15 2.7 1.0 5o 2SD1623 REV.08 3 of 3
2SD1623 价格&库存
很抱歉,暂时无法提供与“2SD1623”相匹配的价格&库存,您可以联系我们找货
2SD1623
    • 1000+0.12659
    库存:29400
    2SD1623
    • 5+0.13200
    • 20+0.12980
    • 100+0.12540
    库存:120
    2SD1623
      • 1000+0.12659
      库存:2400
