RB160M-30
RB160M-30
    SK(時科)
    SMF(SOD-123FL)
    肖特基二极管 30V 550mV@1A 1A SOD-123
RB160M-30 数据手册
Surface Mount Schottky Barrier Rectifier Reverse Voltage - 30 to 90 Forward Current - 1.0 A FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability PIN DESCRIPTION 1: Cathode 2: Anode • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications Simplified outline SOD-123FL 123FL and symbol MECHANICAL DATA • Case: SOD-123FL • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight:15mg 0.00048oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25℃ ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load, derate by 20 % 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. 2) P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. 1 of 3 2 of 3 PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL 123FL 3 of 3
RB160M-30 价格&库存
很抱歉,暂时无法提供与“RB160M-30”相匹配的价格&库存,您可以联系我们找货
RB160M-30
    • 3000+0.08800
    库存:36000
    RB160M-30
    • 10+0.17361
    • 100+0.16241
    • 500+0.15121
    • 2000+0.13441
    • 5000+0.12881
    • 10000+0.12545
    库存:1761
    RB160M-30
      • 3000+0.08656
      库存:73800
