WCM3216F2SF-601T03
WCM3216F2SF-601T03
    TAI-TECH(台庆)
    CHOKE_3.2X1.6MM_SM
    共模电感 Original 300mA 800mΩ 600Ω CHOKE_3.2X1.6MM_SM
WCM3216F2SF-601T03 数据手册
P1 TAI-TECH Wire Wound Type Common Mode Filter WCM3216F2SF-SERIES ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 18/04/26 新發行 楊祥忠 林志鴻 張展耀 備 註 www.tai-tech.com.tw P2 TAI-TECH Wire Wound Type Common Mode Filter WCM3216F2SF-SERIES 1. Features Halogen Pb Halogen-free Pb-free 1. High common mode impedance at high frequency cause excellent noise suppression performance. 2. WCM3216F2SF series realizes small size and low profile. 3.2x1.6x2.0 mm. 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Dimension Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 3216F2SF 3.2±0.2 1.6±0.2 2.0±0.2 0.65±0.1 0.64±0.1 0.15±0.1 Units: mm 3. Part Numbering WCM 3216 A B F 2 S F C D E F A: Series B: Dimension C: Material D: Number of Lines E: Type F: Lead free type G: Impedance H: Packaging I: Rated Current - 900 T 04 G H I Ferrite Core 2=2 lines S=Shielded , N=Unshielded 900=90Ω T=Taping and Reel 04=400mA 4. Specification TAI-TECH Part Number DC Common mode Impedance Test Frequency Resistance (MHz) (Ω) (Ω) max. Rated Current (mA)max. Withstand IR Rated Volt. (Vdc)max. Volt. (Vdc) (Ω) min. Max. WCM3216F2SF-900T04 90±25% 100 0.30 400 50 125 10M WCM3216F2SF-121T03 120±25% 100 0.30 350 50 125 10M WCM3216F2SF-161T03 160±25% 100 0.40 350 50 125 10M WCM3216F2SF-221T03 220±25% 100 0.45 300 50 125 10M WCM3216F2SF-261T03 260±25% 100 0.50 300 50 125 10M WCM3216F2SF-361T03 360±25% 100 0.60 300 50 125 10M WCM3216F2SF-601T03 600±25% 100 0.80 300 50 125 10M WCM3216F2SF-102T02 1000±25% 100 1.00 200 50 125 10M WCM3216F2SF-222T02 2200±25% 100 1.20 200 50 125 10M www.tai-tech.com.tw P3 TAI-TECH Typical Impedance v.s. Frequency Curve WCM3216F2SF-900 WCM3216F2SF-121 1000 100 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 Common Mode 10 Normal Mode 1 0.1 1 10 100 1000 100 Common Mode 10 Normal Mode 1 0.1 10000 1 10 FREQUENCY(MHz) WCM3216F2SF-161 1000 1000 10000 WCM3216F2SF-221 10000 1000 100 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 100 FREQUENCY(MHz) Common Mode 10 Normal Mode 1 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 0.1 10000 1 FREQUENCY(MHz) IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 1000 10 Normal Mode 1 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM3216F2SF-601 10000 100 1000 10000 FREQUENCY(MHz) FREQUENCY(MHz) WCM3216F2SF-222 10000 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 WCM3216F2SF-361 10000 Common Mode 100 100 FREQUENCY(MHz) WCM3216F2SF-261 1000 10 Common Mode 100 Normal Mode 10 1 Common Mode 1000 100 Normal Mode 10 1 1 10 100 1000 10000 1 FREQUENCY(MHz) 10 100 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 P4 TAI-TECH WCM3216F2SF-102 IMPEDANCE(Ohm) 10000 1000 Common Mode 100 Normal Mode 10 1 1 10 100 1000 10000 FREQUENCY(MHz) 5. Schematic Diagram 6. Materials No. Description Specification a. Upper Plate Ferrite b. Core Ferrite Core c Termination Tin (Pb Free) d Wire Enameled Copper Wire www.tai-tech.com.tw P5 TAI-TECH 7. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test Z(common mode) DCR Agilent-4291A+ Agilent -16197A Refer to standard electrical characteristics list. I.R. Temperature Rise Test Agilent-4338B Agilent4339 Rated Current < 1A ∆T 20℃Max 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Rated Current ≧ 1A ∆T 40℃Max Reliability Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles) Temperature:125±2℃ Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪R.H, Load Humidity Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Moisture Resistance Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:25±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs Oscillation Frequency: 10~2K~10Hz for 20 minutes Vibration Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 www.tai-tech.com.tw P6 TAI-TECH Item Performance Bending Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
WCM3216F2SF-601T03 价格&库存
很抱歉,暂时无法提供与“WCM3216F2SF-601T03”相匹配的价格&库存,您可以联系我们找货
WCM3216F2SF-601T03
  • 1+0.55220
  • 50+0.36740
  • 2000+0.33330
库存:1970
WCM3216F2SF-601T03
库存:2000
WCM 3216F2SF-601T03
  • 2000+1.633852000+0.21090
  • 4000+1.533054000+0.19789
  • 6000+1.477256000+0.19069
  • 10000+1.4100910000+0.18202
  • 14000+1.3676814000+0.17654
  • 20000+1.3242420000+0.17094
库存:3395
WCM3216F2SF-601T03
  • 10+0.50760
  • 100+0.40450
  • 300+0.35270
  • 2000+0.32060
  • 4000+0.28990
  • 10000+0.27450
库存:77
WCM 3216F2SF-601T03
  • 1+3.391201+0.43774
  • 10+2.6958410+0.34798
  • 25+2.4656325+0.31827
  • 50+2.3092250+0.29808
  • 100+2.16127100+0.27898
  • 250+1.98273250+0.25593
  • 500+1.85795500+0.23983
  • 1000+1.742011000+0.22486
库存:3395
WCM3216F2SF-601T03
  • 20+1.37800
  • 100+0.82200
  • 500+0.57550
  • 2000+0.41100
  • 4000+0.41100
  • 20000+0.41100
库存:399
