ESD9X7V
ESD9X7V
1-Line, Uni-directional, Normal capacitance Transient
http//:www.sh-willsemi.com
Voltage Suppressor
Descriptions
The ESD9X7V is a transient voltage suppressor (TVS)
which provides a very high level protection for sensitive
FBP-02C
electronic components that may be subjected to
electrostatic discharge (ESD). It is designed to replace
multilayer varistors (MLV) in consumer equipment
Pin1
Pin2
applications such as mobile phone, notebook, PAD, STB,
LCD TV etc.
The ESD9X7V was past ESD transient voltage up to
±30kV
(contact)
according
to
IEC61000-4-2
Pin configuration (Top view)
and
withstand peak current up to 9.5A for 8/20µs pulse
according to IEC61000-4-5.
*J
The ESD9X7V is available in FBP-02C package.
Standard products are Pb-free and Halogen-free.
= Month (A~Z)
J
= Device code
Marking (Top View)
Features
Working voltage
: 7V
Peak power (tp=8/20µs)
: 161W
ESD protection
IEC61000-4-2 (Contact)
: ±30kV
IEC61000-4-2 (Air)
: ±30kV
Low leakage current
Small package
Order information
Device
Package
Shipping
ESD9X7V-2/TR
FBP-02C
10000/Tape&Reel
Applications
Mobile phone
PAD
Notebook
STB
LCD TV
Digital camera
Other electronic equipment
Will Semiconductor Ltd.
1
Revision 2.3, 2016/07/06
ESD9X7V
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
161
W
Peak pulse current (tp = 8/20μs)
Ipp
9.5
A
ESD according to IEC61000-4-2 air discharge
±30
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
kV
±30
TSTG
125
o
-40~85
o
260
o
-55~150
o
C
C
C
C
Electronics characteristics (Ta=25 oC, unless otherwise noted)
Parameter
Symbol
Reverse stand-off voltage
VRWM
Reverse leakage current
IR
Condition
Min.
Typ.
VRWM=7V
Max.
Unit
7
V
0.05
µA
Reverse breakdown voltage
VBR
IT=1mA
7.5
8.0
8.8
V
Forward voltage
VF
IF=10mA
0.55
0.9
1.25
V
Clamping voltage
VC
Ipp=1A, tp=8/20µs
10
V
Ipp=9.5A, tp=8/20µs
17
V
Junction capacitance
CJ
65
pF
f=1MHz, VR=0V
2
49
ESD9X7V
characteristics (Ta=25 C, unless otherwise noted)
100
90
Front time: T1= 1.25 T = 8s
100
90
Time to half-value: T2= 20s
Current (%)
Peak pulse current (%)
Typical
o
50
T2
10
tr = 0.7~1ns
Time (s)
T1
8/20µs waveform per IEC61000-4-5
C - Junction capacitance (pF)
VC - Clamping voltage (V)
Pulse waveform: tp=8/20μs
15
10
5
6
Time (ns)
Contact discharge current waveform per IEC61000-4-2
t
60ns
30ns
T
9
60
40
30
12
f = 1MHz
VAC = 50mV
50
2
3
4
5
6
Ipp - Peak pulse current (A)
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
7
100
% of Rated power
Peak Pulse Power (W)
1000
100
80
60
40
10
100
Pulse time (μs)
1000
25
50
75
100
125
150
o
TA - Ambient temperature ( C)
Non-repetitive peak pulse power vs. Pulse time
Power derating vs. Ambient temperature
3
ESD9X7V
Typical
o
10V/div
10V/div
20ns/div
20ns/div
ESD Clamping
ESD Clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
4
ESD9X7V
Package outline dimensions
FBP-02C
L
D1
D
L2
b
b1
E
E1
L3
L1
e1
e
Top View
Bottom View
Dimensions In Millimeters
Min.
Typ.
Max.
A
0.450
0.500
0.550
A1
0.010
0.100
D
0.950
1.000
1.050
E
0.550
0.600
0.650
A
A1
Symbol
Side View
D1
0.470 Ref.
E1
0.420 Ref.
b
0.270
0.320
0.370
b1
0.250
0.300
0.350
e
0.555
0.605
0.655
e1
L
Recommend land pattern (Unit: mm)
0.250
L1
L2
0.40
L3
0.40
0.230 Ref.
0.300
0.350
0.030 Ref.
0.370
0.420
0.470
0.040 Ref.
Notes:
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
0.62
0.18
0.50
group to ensure your PCB design guidelines are met.
5
很抱歉,暂时无法提供与“ESD9X7V-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18860
- 1000+0.13058
- 4000+0.12927
- 10000+0.12668
- 国内价格
- 20+0.20574
- 200+0.16902
- 600+0.14246
- 2000+0.12042
- 国内价格
- 1+0.40700
- 500+0.13530
- 5000+0.09042
- 10000+0.07403
