ESD5451Z-2/TR
ESD5451Z-2/TR
    WILLSEMI(韦尔)
    DFN0603-2
    ESD抑制器/TVS二极管 双向 5V 8A 80W DFN0603-2L
ESD5451Z-2/TR 数据手册
ESD5451Z ESD5451Z 1-Line, Bi-directional, Transient Voltage Suppressor http//:www.sh-willsemi.com Descriptions The ESD5451Z is a bi-directional TVS (Transient Voltage Suppressor). It is specifically designed to protect sensitive electronic components which are connected to low speed data lines and control lines from over-stress caused by ESD (Electrostatic Discharge), EFT (Electrical Fast Transients) DFN0603-2L (Bottom View) and Lightning. The ESD5451Z may be used to provide ESD protection up to ±30kV (contact and air discharge) according to IEC61000-4-2, and withstand peak pulse current up to 8A Pin1 Pin2 (8/20μs) according to IEC61000-4-5. The ESD5451Z is available in DFN0603-2L package. Standard products are Pb-free and Halogen-free. Circuit diagram Features  Reverse stand-off voltage: ±5V Max.  Transient protection for each line according to IEC61000-4-2 (ESD): ±30kV (contact and air discharge) *E Pin1 IEC61000-4-4 (EFT): 40A (5/50ns) Pin2 IEC61000-4-5 (surge): 8A (8/20μs)  Capacitance: CJ = 17.5pF typ.  Low leakage current: IR < 1nA typ.  Low clamping voltage: VCL = 9V typ. @ IPP = 16A (TLP)  Small package E = Device code * = Month code Marking (Top View) Applications  Cellular handsets  Tablets  Laptops  Other portable devices  Network communication devices Will Semiconductor Ltd. Order information Device Package Shipping ESD5451Z-2/TR DFN0603-2L 10000/Tape&Reel 1 Revision 1.8, 2018/06/19 ESD5451Z Absolute maximum ratings Parameter Symbol Rating Unit Peak pulse power (tp = 8/20μs) Ppk 80 W Peak pulse current (tp = 8/20μs) IPP 8 A ESD according to IEC61000-4-2 air discharge VESD ESD according to IEC61000-4-2 contact discharge Junction temperature TJ Operating temperature TOP Lead temperature TL Storage temperature TSTG ±30 kV ±30 125 o -40~85 o 260 o -55~150 o C C C C Electrical characteristics (TA=25 oC, unless otherwise noted) I VRWM Reverse stand-off voltage IR Reverse leakage current VCL Clamping voltage IPP Peak pulse current IPP IHOLD VCL VTRIG VHOLD VBR VRWM IBR ITRIG IR IR ITRIG IBR VRWM VBR VHOLD VTRIG VCL V IHOLD VTRIG Reverse trigger voltage ITRIG Reverse trigger current VBR Reverse breakdown voltage IBR Reverse breakdown current VHOLD Reverse holding voltage IPP IHOLD Reverse holding current Definitions of electrical characteristics Will Semiconductor Ltd. 2 Revision 1.8, 2018/06/19 ESD5451Z o Electrical characteristics (TA=25 C, unless otherwise noted) Parameter Symbol Reverse stand-off voltage VRWM Reverse leakage current IR Reverse breakdown voltage Reverse holding voltage VBR VHOLD Condition Min. VRWM = 5.0V Typ.
ESD5451Z-2/TR 价格&库存
很抱歉,暂时无法提供与“ESD5451Z-2/TR”相匹配的价格&库存,您可以联系我们找货
ESD5451Z-2/TR
  • 5+0.04251
  • 20+0.04173
  • 100+0.04017
库存:1000
