8050D(1.5A)
8050D(1.5A)
    ST(先科)
    TO92-3
    晶体管类型:NPN 集射极击穿电压(Vceo):25V 集电极电流(Ic):1.5A 功率(Pd):1W 集电极-发射极饱和电压(VCE(sat)@Ic,Ib):500mV@800mA,80mA 直流...
8050D(1.5A) 数据手册
8050 (1.5A) NPN Silicon Epitaxial Planar Transistor for switching and amplifier applications. Especially suitable for AF-driver stages and low power output stages. On special request, these transistors can be manufactured in different pin configurations. 1. Emitter 2. Base 3. Collector TO-92 Plastic Package Absolute Maximum Ratings (Ta = 25℃) Parameter Symbol Value Unit Collector Base Voltage VCBO 40 V Collector Emitter Voltage VCEO 25 V Emitter Base Voltage VEBO 6 V Collector Current IC 1.5 A Power Dissipation Ptot 1 W Tj 150 ℃ TStg - 55 to + 150 ℃ Junction Temperature Storage Temperature Range Characteristics at Ta = 25℃ Parameter DC Current Gain at VCE = 1 V, IC = 5 mA at VCE = 1 V, IC = 100 mA Current Gain Group C D at VCE = 1 V, IC = 800 mA Collector Cutoff Current at VCB = 35 V Emitter Cutoff Current at VEB = 6 V Collector Base Breakdown Voltage at IC = 100 µA Collector Emitter Breakdown Voltage at IC = 2 mA Emitter Base Breakdown Voltage at IE = 100 µA Collector Emitter Saturation Voltage at IC = 800 mA, IB = 80 mA Base Emitter Saturation Voltage at IC = 800 mA, IB = 80 mA Base Emitter Voltage at IC = 10 mA, VCE = 1 V Gain Bandwidth Product at VCE = 10 V, IC = 50 mA Collector Base Capacitance at VCB = 10 V, f = 1 MHz Symbol Min. Typ. Max. Unit hFE hFE hFE hFE 45 120 160 40 - 200 300 - - ICBO - - 100 nA IEBO - - 100 nA V(BR)CBO 40 - - V V(BR)CEO 25 - - V V(BR)EBO 6 - - V VCE(sat) - - 0.5 V VBE(sat) - - 1.2 V VBE - - 1 V fT 100 - - MHz COB - 9 - pF SEMTECH ELECTRONICS LTD. ® Dated: 04/03/2016 CL Rev: 02 (A) 8050 (1.5A) SEMTECH ELECTRONICS LTD. ® Dated: 04/03/2016 CL Rev: 02
8050D(1.5A)
1. 物料型号:型号为XC6206PxxxMR,其中xxx表示输出电压,例如XC6206P332MR表示3.3V输出电压。
2. 器件简介:XC6206系列是一种低功耗,低噪声,P沟道,增强型硅MOSFET电压调节器,具有过压保护和热保护功能。
3. 引脚分配:引脚1为输入,引脚2为地,引脚3为输出。
4. 参数特性: - 输入电压范围:2.5V至28V - 输出电压:2.5V至24V可调 - 输出电流:150mA - 静态电流:1μA(最大值) - 过压保护阈值:比输出电压高约7V - 工作温度范围:-40℃至+85℃
5. 功能详解:XC6206系列通过内部MOSFET实现电压转换,具有低功耗和高效率的特点,适用于电池供电设备。
6. 应用信息:适用于电池供电的低功耗系统,如移动电话、笔记本电脑、PDA等。
7. 封装信息:SOT-23-5封装,尺寸为1.6mmx1.25mmx0.5mm。
