GPD4216L100-24V2800
GPD4216L100-24V2800
    INGHAI(赢海)
    Lead wire
    频率2.8kHz 电压-额定3~36V
GPD4216L100-24V2800 数据手册
規 格 承 認 書 PECIFICATION FOR APPROVAL 客 戶 CUSTOMER 項 目 ITEM 型 號 :通用型规格书 电压范围 3-36V : 压电有源蜂鸣器(内含驱动电路) TYPE : GPD4216L100-3-36V2800 描述 DESCRIPTION : Φ42.0 x H16.0 mm 2800Hz 客戶料號 CUSTOMER NO. : 規 格 書 號 DC3-36V ≥100dB L=100 mm SPECIFICATION NO.: 版 本 EDITION NO. 日 期 DATE : : V1.0 20 客戶承認 CUSTOMER CONFIRM AND SIGN 檢查 審核 承認 TESTED BY CHECKED BY APPROVED BY 東莞市赢海電子有限公司 DONGUAN INGHAI ELECTRONICS CO.,LTD 製作 審查 確認 ISSUED BY CHECKED BY APPROVED BY 周明 陈铭 地址:廣東省東莞市長安鎮廈邊元灶頭工業區 16-6 號 電話 / TEL:0769-83060958 傳真 / FAX: 0769-81608993 網址:HTTP://WWW.INGHAI.COM 1/4 DONGGUAN INGHAI ELECTRONICS CO.,LTD Model NO: GPD4216L100-3-36V2800 线长 L100mm A: DIMEMSIONS Unit: mm Tolerance:±0.5 B: SPECIFICATIONS Model NO GPD4216L Rated Voltage 3-36VDC Operating Voltage 3-38VDC Max.Rated Current Max.35mA Sound Pressure level(dB/min) at 10cm Min.100dB Resonant Frequency 2800±500Hz Operating Temperature -20 ℃~+60 ℃ Storage Temperature -30 ℃~+70 ℃ Case material and color ABS / Black Measuring condition Part shall be measured under a condition (Temperature: 5~35℃, Humidity: 45%~85%R.H., Atmospheric pressure: 860 ~1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure. 2/4 C: Acoustic Characteristics: The oscillation frequency, current consumption and sound pressure are measured by the measuring instruments shown below In the measuring test, buzzer is placed as follows: D: Typical Frequency Response Curve: dB mA 110 16 105 100 dB mA 14 12 95 8 90 4 18 20 22 24 26 28 30 VDC 3/4 E: Reliability Test After any following tests the part shall meet specifications without any degradation in appearance and performance except SPL. SPL shall not deviate more than -10 dB from the initial value 1. Ordinary Temperature Life Test The part shall be subjected to 96 hours at 25±10℃. Input rated voltage 2. 3. 4. 5. 6. 7. Resonant frequency, 1/2 duty Square wave. High Temperature Test The part shall be capable of with standing a storage temperature of +70℃ for 96 hours. Low Temperature Test The part shall be capable of with standing a storage temperature of -30℃ for 96 hours. Humidity Test Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours and expose to room temperature for 6 hours Temperature Shock Test Temperature:60℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle) Total cycle: 10 cycles Drop Test Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick, three sides, six plain.) Vibration Test Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes Note: As this product is not protected from foreign material entering, please make sure that any foreign materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it. 4/4
GPD4216L100-24V2800 价格&库存
很抱歉,暂时无法提供与“GPD4216L100-24V2800”相匹配的价格&库存,您可以联系我们找货
GPD4216L100-24V2800
  • 1+15.98030
  • 50+9.53280
  • 150+6.67300
  • 500+4.76640
  • 1000+4.52810
  • 5000+4.19440
库存:2
GPD4216L100-24V2800
  • 1+4.65501
  • 30+4.48001
  • 100+4.13001
  • 500+3.78001
  • 1000+3.60501
GPD4216L100-24V2800
    • 1+8.08920
    • 10+6.72840
    • 30+5.98320
    • 100+5.14080
