規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
型 號
通用型规格书 电压范围 3-24V
压电有源蜂鸣器(内含驱动电路)
TYPE
: GPD30245L100-3-36V3500
DESCRIPTION :
φ29.5 x H24.5 mm 3500Hz 3-36V ≥110dB
客戶料號
CUSTOMER NO. :
規 格 書 號
L=100mm
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.0
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
TESTED BY
審核
CHECKED BY
承認
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
ISSUED BY
審查
CHECKED BY
周明
李林
確認
APPROVED BY
地址:廣東省東莞市長安鎮上沙第五工业区新春 1 路新春科技园
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
1/3
DONGGUAN INGHAI ELECTRONICS CO.,LTD
Model NO: GPD30245L100-3-36V3500
A: DIMEMSIONS Unit:mm
Tolerance:±0.5
线长 L100mm
B: SPECIFICATIONS
Model NO
GPD30245L100
Rated Voltage
3-36VDC
Operating Voltage
3-38VDC
Max.Rated Current
Max.50mA
sound Pressure level(dB/min)at10cm
Min.110dB
Resonant Frequency
3500±500Hz
Operating Temperature
-20 ℃~+60 ℃
Storage Temperature
-30 ℃~+70 ℃
Measuring condition
Part shall be measured under a condition (Temperature: 5~ 35℃, Humidity: 45% ~ 85%R.H., Atmospheric
pressure: 860 ~ 1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H.
Atmospheric pressure: 860 ~1060hPa) is regulated to measure.
2/3
NO.
ITEM
1
High Temperature
Test (Storage)
2
Low Temperature
Test (Storage)
3
Humidity Test
TEST CONDITION AND REQUIREMENT
After being placed in a chamber with60±2ºC for 48 hours and then
being placed in normal condition for 2 hours.
Allowable variation of SPL after test: ±10dB.
After being Placed in a chamber with -20±2ºC for 48 hours and then
After being Placed in a chamber with 90-95% R.H. at 40±2ºC for 48
hours and then being placed in normal condition for 2 hours.
The part shall be subjected to 5 cycles. One cycle shall be consist of:
+60ºC
+25ºC
4
Temperature Cycle
Test
+25ºC
-20℃
5
Solderability
Test
Lead terminals are immersed in rosin for 3 seconds and then
immersed in solder bath of +300ºC for 3seconds .
90% min. lead terminals shall be wet with solder
(Except the edge of terminals).
3/3
GPD30245L100-9V3500 价格&库存
很抱歉,暂时无法提供与“GPD30245L100-9V3500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.34020
- 10+6.10540
- 30+5.42920
